I am trying to infer from this model in deepstream and the values i get from the output are very different from the values I get when I infer with keras on python or TensorRt on python.
For a measure of the difference I am considering the RMSE (root mean square error)value of a set of 740 frames.
DeepStream vs TensorRT on Python
avg rmse of 740 frames=1.96015
max rmse of 740 frames=2.54657
_____________________________________
Keras python vs TensorRT on Python
avg rmse of 740 frames=0.0087
max rmse of 740 frames=0.016
nvposrt mobilenet - Google Drive this the link to the drive folder with the deepstream app, model file, engine and inference scripts. It also contains the TRT engine conversion script by the name dottrtbuild.py.
hello,
I have set the netscalefactor=1 and offsets=0;0;0 that is no preprocessing but still the RMSE is high. Even in the TensorRT case there is no preprocessing and raw rgb inputs are being fed to the engine.
To check what is being fed to the model i made a dummy neural network like this
which return the input as output. I converted it to TensorRT engine and deployed it in all the scripts and got the output images from keras, tensorrt and deepstream.
Keras and tensorrt gave the exact same image and their rmse was 0.
Deepstream had a very large rmse of 2000+ when compared with both. The image from Deepstream was different as well. note: the netscalingfactor=1 and offsets=0;0;0 in this case as well.
On TensorRT
We have checked your source and found out you are using the NHWC ONNX model.
Please note that Deepstream expects model to be NCHW format.
(While TensorRT can support both NCHW and NHWC format)
Could you convert the model into NCHW format and try it again?
This can be done by the --inputs_as_nchw config in tf2onnx .
If the issue goes on, since TensorRT doesn’t support portability, could you share the ONNX model with us as well?
I have been using NCHW for deepstream all along since the previous drive link was for the moblenetv2 model and since then i have tried the the simple model where input is the same as output i am attaching a new drive link inputoutputdiscrepency - Google Drive
this contains
1.Deepstream app with simple model
2.simple model .h5, .onnx, .trt
3. DSTRTBS1.txt the model output file from deepstream
4. frametest.py the scrip to view the output from DSTRTBS1.txt
5. keras inference
6. tensorrt inference
note: the deepstream script uses videotestsrc for input.
@AastaLLL if it speeds the debugging i can make a new post with the observation from the simple model.
I believe its this issue which is causing the the high rms of the mobilenetv2 model. So if we can answer the simple model then i will get an answer to the mobilenetv2 high rmse issue.
Do you use the same TensorRT engine for TensorRT and Deepstream?
In your TRTInferance.py, the buffer is arranged in the NHWC format.
#function to get image from local directory
def get_img_tensor(i):
a=np.array(i).astype(np.float32)
newsize = (224, 224,3)
a = np.resize(a,newsize)
a=a.reshape((1,224,224,3))
return a
while success:
trt_predictions = predict(get_img_tensor(image)).astype(np.float32)
That’s why we think the engine require NHWC format to output the correct result.
