What do these errors mean?
Few days ago, it can work.
I just copy the “Hello robot” codes in the tutorial.
In version 2023.1.1, the ArticulationRootAPI is changed.
So I think you should change ‘/World/Fancy_Robot’. For example ‘/World/Fancy_Robot/base_link’.
Up until version 2023.1.0, the URDF importer assigned the ArticulationRootAPI to the top-level prim of the articulation structure. The root link was then identified by PhysX through an analysis of the kinematic tree. This practice was revised in version 2023.1.1, whereby the ArticulationRootAPI is now directly associated with the actual root link. For example, in version 2023.1.0, when importing a Franka URDF, the ArticulationRootAPI would be placed on /World/Franka, and PhysX might designate an…
system
Closed
April 5, 2024, 11:01pm
3
