When I plug in my HDMI Cable, my PC crashes.
nvidia-bug-report.log.gz (91.8 KB)
Initial dmesg logs look like so:
[ 274.034821] [drm] [nvidia-drm] [GPU ID 0x00000100] Framebuffer memory not appropriate for scanout
[ 274.034826] [drm] [nvidia-drm] [GPU ID 0x00000100] Framebuffer memory not appropriate for scanout
[ 274.957433] BUG: unable to handle page fault for address: 0000000000001938
[ 274.957447] #PF: supervisor read access in kernel mode
[ 274.957452] #PF: error_code(0x0000) - not-present page
[ 274.957456] PGD 0 P4D 0
[ 274.957463] Oops: 0000 [#1] PREEMPT SMP NOPTI
[ 274.957470] CPU: 8 PID: 1943 Comm: nvidia-modeset/ Tainted: P OE 6.6.9-200.fc39.x86_64 #1
[ 274.957477] Hardware name: Razer Blade 15 (2022) - RZ09-0421/CH580, BIOS 2.02 01/10/2023
[ 274.957480] RIP: 0010:_nv018901rm+0x18d/0x310 [nvidia]
[ 274.958940] Code: ff e8 a7 10 fc ff 48 89 c7 48 c7 c6 a0 e1 d7 c4 e8 c8 2f 65 00 48 8b 4d 00 44 8b 91 3c 19 00 00 41 83 fa 02 0f 84 33 01 00 00 <44> 8b 80 38 19 00 00 41 ba 01 00 00 00 44 0f b6 4d 1d 41 8d 54 24
[ 274.958946] RSP: 0018:ffffac9b01807b90 EFLAGS: 00010293
[ 274.958953] RAX: 0000000000000000 RBX: ffff93ae39c25008 RCX: ffff93ae36854008
[ 274.958958] RDX: 0000000000000009 RSI: 0000000000272cdd RDI: 0000000000000000
[ 274.958961] RBP: ffff93ae84a62b60 R08: 0000000000000000 R09: 0000000000000001
[ 274.958965] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000003
[ 274.958968] R13: 0000000000000000 R14: ffff93ae36854010 R15: ffffac9b0edc5008
[ 274.958972] FS: 0000000000000000(0000) GS:ffff93b19d800000(0000) knlGS:0000000000000000
[ 274.958977] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 274.958980] CR2: 0000000000001938 CR3: 0000000313222000 CR4: 0000000000f50ee0
[ 274.958985] PKRU: 55555554
But full dmesg output is here:
dmesg.txt (128.7 KB)
More system info:
alex@fedora:~$ inxi -F
System:
Host: fedora Kernel: 6.6.9-200.fc39.x86_64 arch: x86_64 bits: 64
Desktop: GNOME v: 45.3 Distro: Fedora release 39 (Thirty Nine)
Machine:
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
serial: <superuser required>
Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
v: 2.02 date: 01/10/2023
Battery:
ID-1: BAT0 charge: 44.6 Wh (60.4%) condition: 73.9/80.2 Wh (92.1%)
CPU:
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12800H bits: 64
type: MST AMCP cache: L2: 11.5 MiB
Speed (MHz): avg: 473 min/max: 400/4700:4800:3700 cores: 1: 400 2: 400
3: 400 4: 400 5: 467 6: 400 7: 400 8: 622 9: 400 10: 1577 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400
Graphics:
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: nvidia
v: 545.29.06
Device-3: IMC Networks [] driver: uvcvideo type: USB
Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB
Display: wayland server: X.Org v: 23.2.3 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: fbdev,nouveau,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 vendor: intel mesa v: 23.3.2 renderer: Mesa Intel
Graphics (ADL GT2)
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Audio:
Device-1: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB
Device-4: HP [] driver: hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.6.9-200.fc39.x86_64 status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active
Network:
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi
IF: wlo1 state: up mac: 4c:44:5b:81:97:dc
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp9s0u1u3u3 state: down mac: 30:8d:99:11:77:49
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: 4C:44:5B:81:97:E0 bt-v: 5.3
Drives:
Local Storage: total: 953.87 GiB used: 307.62 GiB (32.2%)
ID-1: /dev/nvme0n1 model: NVMe CA6-8D1024 size: 953.87 GiB
Partition:
ID-1: / size: 18.15 GiB used: 11.7 GiB (64.4%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 1.8 GiB used: 303.9 MiB (16.5%) fs: ext4
dev: /dev/nvme0n1p10
ID-3: /boot/efi size: 96 MiB used: 73 MiB (76.1%) fs: vfat
dev: /dev/nvme0n1p2
ID-4: /home size: 600 GiB used: 283.32 GiB (47.2%) fs: btrfs
dev: /dev/nvme0n1p8
ID-5: /var size: 18.63 GiB used: 12.23 GiB (65.7%) fs: btrfs
dev: /dev/nvme0n1p12
Swap:
ID-1: swap-1 type: partition size: 3.73 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p16
ID-2: swap-2 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Processes: 480 Uptime: 7m Memory: total: 16 GiB note: est.
available: 15.3 GiB used: 3.26 GiB (21.3%) Shell: Bash inxi: 3.3.31
