PCB Footpring for Jetson Orin NX
I am looking for a footprint for the Jetson Orin NX that includes the connector and more specifically, the spacing for the mounting holes. Preferably an Altium footprint if possible. Thanks!
Its the same as the NANO. so you can just download the NANO PCB reference and pull the connector. BTW, its a 260pin edge connector for a DDR SOM. I believe AMP/TE connectivity makes one: 2309409-2
Thanks for the reply. I have the connector part number as described in the design guide however, the connector footprint is specific only to the connector and does not account for the location of the mounting holes for the NX or Nano (as with any connector). In order to not guess the location of the holes, there needs to be a custom footprint that includes the TE connector as well as the mounting hole locations. If carrier boards exist, then there’s got to be a footprint out there for these cards somewhere. I can’t seem to find it anywhere… :)
Please refer to the carrier board design files package in DLC for the info of PCB board. And refer to the module data sheet for module mechanical info.
This is exactly what I was looking for, thank you! I’ve looked in the DLC and found design guides but didn’t think of searching for “design files”. Much appreciated.
