I have made a custom carrier board for the Jetson AGX Xavier.This is my hardware design.
When the board is powered up, it can’t find pcie device(FPGA,7K325T-xilinx) and there is no pex_clk_100m.
please help me!
Here is how it can be root-caused.
Remove “nvidia,enable-power-down” DT entry from the respective controller’s node.
I can’t find where to remove “nvidia,enable-power-down”.
can you tell me where the DT file is?
Download the kernel source from l4t archive.
Follow below page to build dtbs.
I mean there is so much DT files, i want to know which file i should modify.
Turn on your AGX, type command dmesg, grep “dts” inside it and it will tell you the answer.
You need to trace down the code.
I have downloaded and compiled kernel driver code, then i find “tegra194-p2888-0001-p2822-0000-common.dtsi” file.
But i mean there is no “nvidia,enable-power-down” in this file.
Did i make something wrong?
You can study the device tree structure first. Your comment just revealed that you don’t know how device tree works…
