Hi
After updating my sources to 35.1 and Jetpack 5.0.2, my PCIe is not comming up.
[ 6.683670] tegra194-pcie 141a0000.pcie: Adding to iommu group 10
[ 6.686154] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 7.439561] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 68.741549] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 68.741735] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 68.741911] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 68.742076] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 69.852104] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 69.854589] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 69.855177] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 69.856254] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 69.857385] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 69.858187] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 69.859806] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 69.862437] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 69.881057] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 69.881284] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 69.882774] pcieport 0005:00:00.0: Adding to iommu group 10
[ 69.883914] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 69.884785] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 69.886401] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 69.887211] pci 0005:00:00.0: Removing from iommu group 10
[ 69.887463] pci_bus 0005:00: busn_res: [bus 00-ff] is released
any ideas why this might happen?
A lspci shows no device, but under /proc/device-tree i can see the pcie device
