I have been trying to compile PCL with CUDA capabilities for my Ubuntu 14.04LTS for quite some time now. I have managed to work around a few problems but I am now stuck at this error:
As soon as the compiling hits the gpu folder, cmake throws a lot of errors at first, I would get this one:
[ 45%] Built target pcl_ground_based_rgbd_people_detector
[ 45%] Built target pcl_gpu_containers
[ 45%] Building NVCC intermediate link file gpu/utils/CMakeFiles/pcl_gpu_utils.dir/./pcl_gpu_utils_intermediate_link.o
nvcc fatal : nvcc supports '--relocatable-device-code=true (-rdc=true)', '--device-c (-dc)', and '--device-link (-dlink)' only when targeting sm_20 or higher
make[2]: *** [gpu/utils/CMakeFiles/pcl_gpu_utils.dir/./pcl_gpu_utils_intermediate_link.o] Error 255
make[1]: *** [gpu/utils/CMakeFiles/pcl_gpu_utils.dir/all] Error 2
make: *** [all] Error 2
To fix this problem (I don’t know if it solved the root of the issue) I added this to my makefile to tell nvcc to use a specific architecture for my gpu:
-arch=compute_30
Now, that error does not show up but immediately after the intermediate link file is generated another error is thrown. I don’t understand what is going on with this error and it is a complete roadblock for what I am trying to do.
Here is the error:
Linking CXX shared library ../../lib/libpcl_gpu_utils.so
/usr/bin/ld: CMakeFiles/pcl_gpu_utils.dir/./pcl_gpu_utils_intermediate_link.o: relocation R_X86_64_32S against '__nv_module_id' can not be used when making a shared object; recompile with -fPIC
CMakeFiles/pcl_gpu_utils.dir/./pcl_gpu_utils_intermediate_link.o: error adding symbols: Bad value
collect2: ld returned 1 exit status
make[2]: *** [lib/libpcl_gpu_utils.so.1.7.2] Error 1
I don’t know what PCL is, but the error message in your second build seems to be quite clear. In order to build a DSO, you need to compile the source code with -fPIC (this is a gcc compiler flag).
PIC stands for “position-independent code” and as far back as I can recall (ca. 2003) compilation with -fPIC has been either a requirement or at least a highly recommended practice for DSOs on x86 platforms. The following document by Ulrich Drepper (updated by the author every once in a while) covers in detail everything developers on Linux have to know about building DSOs: [url]http://www.akkadia.org/drepper/dsohowto.pdf[/url]
[Later:]
You might want to ask your question on a relevant PCL mailing list, there is probably more expertise there on how to build it. Best I can tell, you can sign up for one of the mailing list following the links on this page: [url]http://pointclouds.org/contact.html[/url]
