I have been experimenting with a few GStreamer pipelines and noticed that decoding mp4 videos seem unexpectedly slow on the Jetson Nano. Consider the following pipeline that runs using hardware acceleration
GST_DEBUG=3 gst-launch-1.0 filesrc location="Big_Buck_Bunny_1080_10s_30MB.mp4" ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! omxh264dec ! fakesink
This pipeline executes in 10.82 seconds for a 10 second sample file[1].
Comparatively using a CPU based decoding pipeline,
GST_DEBUG=3 gst-launch-1.0 filesrc location="Big_Buck_Bunny_1080_10s_30MB.mp4" ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! avdec_h264 ! fakesink
This runs in 10.62 seconds.
On my laptop computer the same pipeline runs in 1.78 seconds. Now I understand that a laptop is much more powerful than the Jetson however the laptop test-run demonstrates that it is not the GStreamer clock that is forcing the pipeline to run in real-time as opposed to “fast-as-possible”.
Is there something that I am doing wrong or have I just run into the hardware limitation of the Jetson Nano.
Regards,
Sample Video:
[1] https://test-videos.co.uk/vids/bigbuckbunny/mp4/h264/1080/Big_Buck_Bunny_1080_10s_30MB.mp4
omx plugins are being deprecated on Jetson. On recent releases, you would try nvv4l2decoder instead.
For reference, using R32.4.2 on Xavier:
gst-launch-1.0 filesrc location="Big_Buck_Bunny_1080_10s_30MB.mp4" ! qtdemux ! h264parse ! nvv4l2decoder ! fakesink
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is PREROLLING ...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:00.849612045
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Please use nvv4l2decoder as Honey_Patouceul suggests. And set fakesink sync=false.
Thanks @Honey_Patouceul and @DaneLLL,
I didn’t realise that the OMX plugins were going to be deprecated.
I tried the nvv4l2decoder and get the following warning repeated many times.
0x5596edc6d0 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
The command I am using is
GST_DEBUG=3 gst-launch-1.0 filesrc location="Big_Buck_Bunny_1080_10s_30MB.mp4" ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! nvjpegenc ! fakesink sync=false
It is important to put GST_DEBUG=3 at the start of the line in order to see the warning message.
The full output is
GST_DEBUG=3 gst-launch-1.0 filesrc location="Big_Buck_Bunny_1080_10s_30MB.mp4" ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! fakesink sync=false
0:00:00.541980205 1894 0x558a2be6f0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.542082552 1894 0x558a2be6f0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x558a2b77f0 Failed to determine interlace mode
0:00:00.543582283 1894 0x558a2be6f0 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<filesrc0> pad not activated yet
0:00:00.545602028 1894 0x558a25d6d0 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type pasp
0:00:00.545697656 1894 0x558a25d6d0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<demux> failed to find fragment defaults for stream 1
0:00:00.677182592 1894 0x558a25d770 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.677281449 1894 0x558a25d770 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x558a2b77f0 Failed to determine interlace mode
0:00:00.677818652 1894 0x558a25d770 WARN v4l2videodec gstv4l2videodec.c:1557:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:00.678715188 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1062:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.694347565 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.713794063 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.731318787 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.736637066 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.742124880 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.747774678 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.758356598 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.763841808 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.769488117 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.774918846 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.785524568 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.791503335 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.797871018 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.803967652 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.817337360 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.823463006 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.835100893 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.835213292 1894 0x7f8c003630 WARN v4l2bufferpool gstv4l2bufferpool.c:1526:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:00.847924336 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.853481840 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.860060311 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.866080484 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.869851270 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.879286177 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.882866228 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.886685453 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.891232928 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.895357734 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.899269826 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.928420250 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.932274892 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.936126253 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.940173870 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.943448026 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.947637418 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.955432799 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.959649014 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.963081144 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.966731198 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.970580475 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.974321208 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.981993981 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.985920240 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.990236302 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.995026649 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:00.998202365 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.011913646 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.022903806 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.024740838 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.027610296 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.041570698 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.045083404 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.048807574 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.056512483 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.060209777 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.064193434 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.067824840 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.072172362 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.080793704 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.084980283 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.088554500 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.091965432 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.096047529 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.099699926 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.118321296 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.132370659 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.136363535 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.140072340 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.143834583 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.147690319 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.155973787 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.160267036 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.164163190 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.169351881 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.171505850 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.175228665 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.183304731 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.187390474 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.191595179 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.195200960 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.199026799 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.202714926 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.213407422 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.215373624 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.239608073 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.243322711 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.247055996 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.250878606 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.259296245 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.263144324 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.266803701 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.270586674 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.274471786 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.278454297 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.286244990 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.290390005 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.294209178 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.297780948 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.301738978 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.316377681 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.334985353 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.349422019 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.363457320 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.377450588 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.391268694 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.396471917 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.404495378 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.418890428 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.423239824 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.426855449 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.430968901 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.434793074 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.445508226 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.449364848 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.452985108 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.456875794 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.466662065 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.470712963 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.474679536 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.478378184 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.482223451 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.491154959 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.494904963 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.498708510 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.512488646 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.520714300 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.525401154 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.529268609 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.532847410 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.536561684 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.545899036 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.549654301 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.553325917 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.557073681 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.567137149 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.571050803 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.574804297 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.578599771 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.587790608 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.592045523 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.595729119 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.600826922 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.618944944 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.623875711 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.627652070 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.631682446 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.640881514 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.645122365 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.648895911 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.652465702 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.656624155 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.666294746 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.670621277 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.674532432 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.678177380 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.681995407 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.685890728 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.695373136 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.699567476 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.713613610 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.717375489 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.721263935 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.725281186 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.733983937 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.738081086 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.742502568 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.746401899 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.750194248 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.754334888 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.763447755 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.767466048 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.771254646 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.774925221 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.778795905 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.782612213 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.791456062 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.796099685 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.800334807 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.813691026 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.817423165 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.822647534 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.831690138 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.845601945 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.849439921 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.853185966 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.857084933 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.860941398 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.871374303 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.875649166 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.879532038 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.883672730 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.887668731 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.891048985 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.900320241 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.926741055 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.929088258 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.932884617 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.936551546 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.946992420 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.950853417 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.954801499 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.958451917 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.962620631 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.967833802 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.976235034 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.980489375 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.984359330 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.988119699 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.992118148 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.996579162 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.006474916 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.020421672 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.025103161 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.030714729 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.042410847 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.047445315 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.055803056 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.060037501 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.064349969 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.067951323 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.072879642 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.076719336 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.086115544 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.090164984 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.095188566 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.098686323 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.113207731 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.127090475 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.135264409 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.139207335 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.143694027 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.147365383 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.151041999 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.155646715 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.167359917 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.171209195 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.175139829 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.179332137 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.188814390 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.192918883 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.196876914 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.200811611 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.204311711 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.212742840 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.216749049 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.240974435 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.244565424 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.253048481 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.257293968 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.261116317 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.265166174 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.269317283 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.286463142 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.293814708 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.301343571 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.313830233 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.327549170 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.341614158 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.359374827 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.371913313 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.385864392 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.389122403 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.396633713 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.400445750 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.413993588 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.417774843 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.421845638 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.429169234 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.432524747 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.436130476 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.439875428 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.448201501 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.452107083 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.455936256 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.459727615 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.463467254 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.470923510 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.475337284 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.478564720 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.483715077 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.492117403 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.496055902 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.499576211 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.503251369 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.517054163 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.525610608 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.528561161 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.532116420 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.535725534 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.542860896 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.546937733 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
0:00:02.551009413 1894 0x558a25d770 WARN v4l2bufferpool gstv4l2bufferpool.c:1482:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 1008 bytes used but memory is only 0B. This is probably a driver bug.
Got EOS from element "pipeline0".
Execution ended after 0:00:01.758519383
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The print is harmless and you can eliminate it. Please check
Hi @DaneLLL,
Thanks for the reply. If it is harmless then I’ll just ignore it.
Regards,
