Performance varies greatly with different nvcc compilers
I wrote a cuda kernel, compiled it using nvcc, and tested the performance using Nsight Compute. At the beginning my cuda version is 11.1, and I thought I may upgrade my cuda to the latest version 11.6 to further improve the performance. However, after upgrading my cuda and re-compile the kernel (with the same code without change), Nsight Compute shows that the performance drops severly (about 25% more time cost). I can’t understand it at all why the newer compiler results in degraded performance. Below are the profile results for different compilers. My GPU is RTX 3090 (Compute Capability 8.6). The driver version is 510.47.03.
CUDA 11.1
    Section: GPU Speed Of Light Throughput
    DRAM Frequency                                                           cycle/nsecond                           9.48
    SM Frequency                                                             cycle/nsecond                           1.39
    Elapsed Cycles        cycle                     41,671,978
    Memory [%]        %                          56.99
    DRAM Throughput        %                           5.03
    Duration        msecond                          29.90
    L1/TEX Cache Throughput                                                              %                          59.47
    L2 Cache Throughput        %                          14.40
    SM Active Cycles        cycle                  39,924,119.98
    Compute (SM) [%]        %                          74.59
    WRN   Compute is more heavily utilized than Memory: Look at the Compute Workload Analysis section to see what the
          compute pipelines are spending their time doing. Also, consider whether any computation is redundant and
          could be reduced or moved to look-up tables.
    INF   The ratio of peak float (fp32) to double (fp64) performance on this device is 64:1. The kernel achieved 32%
          of this device's fp32 peak performance and 0% of its fp64 peak performance. See the Kernel Profiling Guide
          (https://docs.nvidia.com/nsight-compute/ProfilingGuide/index.html#roofline) for mode details on roofline
          analysis.
    Section: Compute Workload Analysis
    Executed Ipc Active                                                         inst/cycle                           3.11
    Executed Ipc Elapsed                                                        inst/cycle                           2.98
    Issue Slots Busy        %                          77.83
    Issued Ipc Active                                                           inst/cycle                           3.11
    SM Busy        %                          77.83
          No compute pipeline is over-utilized.
    Section: Memory Workload Analysis
    Memory Throughput                                                         Gbyte/second                          45.77
    Mem Busy        %                          29.13
    Max Bandwidth        %                          56.99
    L1/TEX Hit Rate        %                           0.01
    L2 Compression Success Rate                                                          %                              0
    L2 Compression Ratio        0
    L2 Hit Rate        %                          88.32
    Mem Pipes Busy        %                          56.99
    Section: Scheduler Statistics
    One or More Eligible        %                          77.83
    Issued Warp Per Scheduler        0.78
    No Eligible        %                          22.17
    Active Warps Per Scheduler                                                        warp                           3.84
    Eligible Warps Per Scheduler                                                      warp                           2.13
    Section: Warp State Statistics
    Warp Cycles Per Issued Instruction                                               cycle                           4.94
    Warp Cycles Per Executed Instruction                                             cycle                           4.94
    Avg. Active Threads Per Warp        32
    Avg. Not Predicated Off Threads Per Warp        26.59
    WRN   On average, each warp of this kernel spends 1.7 cycles being stalled due to not being selected by the
          scheduler. This represents about 35.1% of the total average of 4.9 cycles between issuing two instructions.
          Not selected warps are eligible warps that were not picked by the scheduler to issue that cycle as another
          warp was selected. A high number of not selected warps typically means you have sufficient warps to cover
          warp latencies and you may consider reducing the number of active warps to possibly increase cache coherence
          and data locality.
    INF   Check the Source Counters section for the top stall locations in your source based on sampling data. The
          Kernel Profiling Guide (https://docs.nvidia.com/nsight-compute/ProfilingGuide/index.html#sampling) provides
          more details on each stall reason.
    Section: Instruction Statistics
    Avg. Executed Instructions Per Scheduler                                          inst                  31,074,586.93
    Executed Instructions                                                             inst                 10,192,464,512
    Avg. Issued Instructions Per Scheduler                                            inst                  31,074,644.35
    Issued Instructions                                                               inst                 10,192,483,346
    WRN   This kernel executes 3715891200 fused and 2893749760 non-fused FP32 instructions. By converting pairs of
          non-fused instructions to their fused
          (https://docs.nvidia.com/cuda/floating-point/#cuda-and-floating-point), higher-throughput equivalent, the
          achieved FP32 performance could be increased by up to 22% (relative to its current performance). Check the
          Source page to identify where this kernel executes FP32 instructions.
    Section: Launch Statistics
    Block Size        256
    Function Cache Configuration        cudaFuncCachePreferNone
    Grid Size        864
    Registers Per Thread                                                   register/thread                            127
    Shared Memory Configuration Size                                                 Kbyte                         102.40
    Driver Shared Memory Per Block                                             Kbyte/block                           1.02
    Dynamic Shared Memory Per Block                                             byte/block                              0
    Static Shared Memory Per Block                                             Kbyte/block                          39.68
    Threads        thread                        221,184
    Waves Per SM        5.27
    Section: Occupancy
    Block Limit SM        block                             16
    Block Limit Registers                                                            block                              2
    Block Limit Shared Mem                                                           block                              2
    Block Limit Warps        block                              6
    Theoretical Active Warps per SM                                                   warp                             16
    Theoretical Occupancy        %                          33.33
    Achieved Occupancy        %                          32.02
    Achieved Active Warps Per SM                                                      warp                          15.37
    WRN   This kernel's theoretical occupancy (33.3%) is limited by the number of required registers This kernel's
          theoretical occupancy (33.3%) is limited by the required amount of shared memory See the CUDA Best Practices
          Guide (https://docs.nvidia.com/cuda/cuda-c-best-practices-guide/index.html#occupancy) for more details on
          optimizing occupancy.
    Section: Source Counters
    Branch Instructions Ratio                                                            %                           0.00
    Branch Instructions                                                               inst                     32,140,672
    Branch Efficiency        %                            100
    Avg. Divergent Branches        0
    WRN   This kernel has uncoalesced shared accesses resulting in a total of 2322432 excessive wavefronts (0% of the
          total 692586496 wavefronts). Check the L1 Wavefronts Shared Excessive table for the primary source
          locations. The CUDA Best Practices Guide
           (https://docs.nvidia.com/cuda/cuda-c-best-practices-guide/index.html#shared-memory-in-matrix-multiplication-c
          -aa) has an example on optimizing shared memory accesses.
CUDA 11.6
    Elapsed Cycles        cycle                     52,519,743
    Memory [%]        %                          45.42
    DRAM Throughput        %                           3.78
    Duration        msecond                          37.70
    L1/TEX Cache Throughput                                                              %                          47.73
    L2 Cache Throughput        %                          11.42
    SM Active Cycles        cycle                  49,963,566.56
    Compute (SM) [%]        %                          58.01
    WRN   This kernel exhibits low compute throughput and memory bandwidth utilization relative to the peak performance
          of this device. Achieved compute throughput and/or memory bandwidth below 60.0% of peak typically indicate
          latency issues. Look at Scheduler Statistics and Warp State Statistics for potential reasons.
    INF   The ratio of peak float (fp32) to double (fp64) performance on this device is 64:1. The kernel achieved 25%
          analysis.
    Executed Ipc Active                                                         inst/cycle                           2.44
    Executed Ipc Elapsed                                                        inst/cycle                           2.32
    Issue Slots Busy        %                          60.97
    Issued Ipc Active                                                           inst/cycle                           2.44
    SM Busy        %                          60.97
    Memory Throughput                                                         Gbyte/second                          34.43
    Mem Busy        %                          23.22
    Max Bandwidth        %                          45.42
    L1/TEX Hit Rate        %                           0.05
    L2 Hit Rate        %                          88.90
    Mem Pipes Busy        %                          45.42
    One or More Eligible        %                          60.95
    Issued Warp Per Scheduler        0.61
    No Eligible        %                          39.05
    Eligible Warps Per Scheduler                                                      warp                           1.18
    Warp Cycles Per Issued Instruction                                               cycle                           6.30
    Warp Cycles Per Executed Instruction                                             cycle                           6.30
    Avg. Not Predicated Off Threads Per Warp        26.47
    Avg. Executed Instructions Per Scheduler                                          inst                  30,458,590.83
    Executed Instructions                                                             inst                  9,990,417,792
    Avg. Issued Instructions Per Scheduler                                            inst                  30,462,031.41
    Issued Instructions                                                               inst                  9,991,546,301
    Block Size        256
    Grid Size        864
    Registers Per Thread                                                   register/thread                            128
    Waves Per SM        5.27
    Section: Occupancy
    WRN   This kernel's theoretical occupancy (33.3%) is limited by the required amount of shared memory This kernel's
          theoretical occupancy (33.3%) is limited by the number of required registers See the CUDA Best Practices
    Branch Instructions                                                               inst                     36,557,440
I can also provide a minimal reproducible code (although the code is a bit complicated). The compiler command is as follows: /usr/local/cuda-11.1/bin/nvcc -arch compute_86 -code sm_86 tmp.cu.
const int WARP_SIZE = 32;
#define CONST_PTR const float* __restrict__
#define PTR float* __restrict__
#define ASSERTION_FAILS "static assertion fails"
#define INF 1e10f
__device__ __forceinline__ float fast_exp2(float x) { return exp2f(x); }
float2 update_forward(float mean, float diff, float w, float wp, float b) {
    float t = mean * w + b;
    return { fast_exp2(-wp * diff + t), fast_exp2(wp * diff + t) };
float2 update_forward(float mean, float diff, float w, float wp, float b, float maxL, float maxU) {
    return { fast_exp2(t - (wp * diff + maxL)), fast_exp2(wp * diff + t - maxU) };
template <typename... T> __device__ __forceinline__
float2 update_backward(float mean, float diff, float w, float wp, float b, float gL, float gU, T... o) {
    float2 t = update_forward(mean, diff, w, wp, b, o...);
    float2 t2 = { t.x * gL, t.y * gU };
    return { t2.x + t2.y, t2.y - t2.x };
// threadIdx.x: WARP_SIZE / GROUP_BCO; threadIdx.y: BLOCK_CI_SIZE
template <int GROUP_CI, int GROUP_BCO, int GROUP_BCO_SUB, int BLOCK_CI_SIZE, bool has_hw, bool stable> __global__
__launch_bounds__(BLOCK_CI_SIZE * WARP_SIZE / GROUP_BCO)
void logsumexp_bound_backward_input_weight_kernel(CONST_PTR grad_outputL, CONST_PTR grad_outputU, CONST_PTR inputL,
                                                  CONST_PTR inputU, CONST_PTR weight, CONST_PTR bias, CONST_PTR outputL,
                                                  CONST_PTR outputU, int B, int CO_div_G, int CI_div_G, int HW, int G,
                                                  PTR grad_inputL, PTR grad_inputU, PTR grad_weight, PTR grad_bias) {
    const int THREAD_X = WARP_SIZE / GROUP_BCO;
    int threadIdx_low, threadIdx_high;
    if (THREAD_X == BLOCK_CI_SIZE) {
        threadIdx_low = threadIdx.x;
        threadIdx_high = threadIdx.y;
    else {
        int id = threadIdx.y * THREAD_X + threadIdx.x;
        threadIdx_low = id & (BLOCK_CI_SIZE - 1);
        threadIdx_high = id / BLOCK_CI_SIZE;
    if (!has_hw) HW = 1;
    int b_hw = blockIdx.x * WARP_SIZE + (has_hw ? threadIdx.x : threadIdx_high);
    int b[GROUP_BCO], hw[GROUP_BCO];
    #pragma unroll
    for (int j = 0; j < GROUP_BCO; j++) {
        int b_hw_j = b_hw + j * THREAD_X;
        if (has_hw) { b[j] = b_hw_j / HW; hw[j] = b_hw_j % HW; }
        else { b[j] = b_hw_j; hw[j] = 0; }
    int write_ci = blockIdx.y * (BLOCK_CI_SIZE * GROUP_CI) + (has_hw ? threadIdx.y : threadIdx_low);
    int read_w_ci = blockIdx.y * (BLOCK_CI_SIZE * GROUP_CI) + threadIdx_low;
    static_assert(!(GROUP_BCO & (GROUP_BCO - 1)) && !(GROUP_BCO_SUB & (GROUP_BCO_SUB - 1)), ASSERTION_FAILS);
    __shared__ float blockOL[WARP_SIZE][WARP_SIZE]; // has_hw ? CO * B : B * CO
    __shared__ float blockOU[WARP_SIZE][WARP_SIZE]; // has_hw ? CO * B : B * CO
    __shared__ float blockGL[WARP_SIZE][WARP_SIZE]; // has_hw ? CO * B : B * CO
    __shared__ float blockGU[WARP_SIZE][WARP_SIZE]; // has_hw ? CO * B : B * CO
    __shared__ float blockW[GROUP_CI][THREAD_X][BLOCK_CI_SIZE + WARP_SIZE / THREAD_X]; // CO * CI
    __shared__ float blockB[GROUP_CI][THREAD_X][BLOCK_CI_SIZE + WARP_SIZE / THREAD_X]; // CO * CI
    __shared__ float blockIM[GROUP_CI][GROUP_BCO][BLOCK_CI_SIZE][THREAD_X]; // CI * B
    __shared__ float blockID[GROUP_CI][GROUP_BCO][BLOCK_CI_SIZE][THREAD_X]; // CI * B
    // To reduce shared memory cost, does not avoid bank conflict for blockIM and blockID.
    // Warning: bank conflict for blockW, blockB iff BLOCK_CI_SIZE < 32
    #pragma unroll
    for (int i = 0; i < GROUP_CI; i++) {
        #pragma unroll
            int channel = write_ci + i * BLOCK_CI_SIZE;
            int offset = ((b[j] * G + blockIdx.z) * CI_div_G + channel) * HW + hw[j];
            float xL = b[j] < B && channel < CI_div_G ? inputL[offset] : 0;
            float xU = b[j] < B && channel < CI_div_G ? inputU[offset] : 0;
            float tmp1 = (xL + xU) * 0.5, tmp2 = (xU - xL) * 0.5;
            if (has_hw) {
                blockIM[i][j][threadIdx.y][threadIdx.x] = tmp1;
                blockID[i][j][threadIdx.y][threadIdx.x] = tmp2;
            else {
                blockIM[i][j][threadIdx_low][threadIdx_high] = tmp1;
                blockID[i][j][threadIdx_low][threadIdx_high] = tmp2;
    float grad_x1[GROUP_CI][GROUP_BCO][GROUP_BCO_SUB], grad_x2[GROUP_CI][GROUP_BCO][GROUP_BCO_SUB];
    #pragma unroll
        #pragma unroll
            #pragma unroll
            for (int s = 0; s < GROUP_BCO_SUB; s++) {
                grad_x1[i][j][s] = grad_x2[i][j][s] = 0;
    for (int k = 0; k < CO_div_G; k += WARP_SIZE) {
        #pragma unroll
        for (int i = 0; i < WARP_SIZE; i += BLOCK_CI_SIZE * THREAD_X / WARP_SIZE) {
            int threadIdx32x = id & (WARP_SIZE - 1);
            int threadIdx32y = id / WARP_SIZE;
            int read_output_co = k + (has_hw ? threadIdx32y + i: threadIdx32x);
            int read_output_b_hw = blockIdx.x * WARP_SIZE + (has_hw ? threadIdx32x : threadIdx32y + i);
            int read_b = has_hw ? read_output_b_hw / HW : read_output_b_hw;
            int read_hw = has_hw ? read_output_b_hw % HW : 0;
            int offset = ((read_b * G + blockIdx.z) * CO_div_G + read_output_co) * HW + read_hw;
            float value_oL = read_b < B && read_output_co < CO_div_G ? outputL[offset] : INF;
            float value_oU = read_b < B && read_output_co < CO_div_G ? outputU[offset] : INF;
            float value_gL = read_b < B && read_output_co < CO_div_G ? grad_outputL[offset] : 0;
            float value_gU = read_b < B && read_output_co < CO_div_G ? grad_outputU[offset] : 0;
            if (stable) {
                blockOL[threadIdx32y + i][threadIdx32x] = value_oL;
                blockOU[threadIdx32y + i][threadIdx32x] = value_oU;
                blockGL[threadIdx32y + i][threadIdx32x] = value_gL;
                blockGU[threadIdx32y + i][threadIdx32x] = value_gU;
            else {
                blockGL[threadIdx32y + i][threadIdx32x] = value_gL * fast_exp2(-value_oL);
                blockGU[threadIdx32y + i][threadIdx32x] = value_gU * fast_exp2(-value_oU);
        for (int j_co = 0; j_co < GROUP_BCO; j_co++) {
            float grad_w[GROUP_CI], grad_b[GROUP_CI];
            #pragma unroll
                grad_w[i] = grad_b[i] = 0;
            #pragma unroll
                int in_channel = read_w_ci + i * BLOCK_CI_SIZE;
                int out_channel = k + threadIdx_high + j_co * THREAD_X;
                int w_offset = (blockIdx.z * CO_div_G + out_channel) * CI_div_G + in_channel;
                bool valid = in_channel < CI_div_G && out_channel < CO_div_G;
                blockW[i][threadIdx_high][threadIdx_low] = valid ? weight[w_offset] : 0;
                blockB[i][threadIdx_high][threadIdx_low] = valid ? bias[w_offset] : 0;
            __syncthreads();
            #pragma unroll
            for (int t = 0; t < THREAD_X / GROUP_BCO_SUB; t++) {
                #pragma unroll
                    float sum_res_w1, sum_res_w2, sum_res_b;
                    int co_ = threadIdx.x ^ t, co = co_ ^ (j_co * THREAD_X);
                    float w = blockW[i][co_][threadIdx.y], wp = abs(w);
                    float bias = blockB[i][co_][threadIdx.y];
                    #pragma unroll
                    for (int j_b = 0; j_b < GROUP_BCO; j_b++) {
                        #pragma unroll
                            int b_ = threadIdx.x ^ (THREAD_X / GROUP_BCO_SUB * s), b = b_ ^ (j_b * THREAD_X);
                            float x_mean = blockIM[i][j_b][threadIdx.y][b_];
                            float x_diff = blockID[i][j_b][threadIdx.y][b_];
                            float gL = has_hw ? blockGL[co][b] : blockGL[b][co];
                            float gU = has_hw ? blockGU[co][b] : blockGU[b][co];
                            float2 res_pair;
                            if (stable) {
                                float oL = has_hw ? blockOL[co][b] : blockOL[b][co];
                                float oU = has_hw ? blockOU[co][b] : blockOU[b][co];
                                res_pair = update_backward(x_mean, x_diff, w, wp, bias, gL, gU, oL, oU);
                            else res_pair = update_backward(x_mean, x_diff, w, wp, bias, gL, gU);
                            if (j_b == 0 && s == 0) {
                                sum_res_w1 = res_pair.x * x_mean;
                                sum_res_w2 = res_pair.y * x_diff;
                                sum_res_b = res_pair.x;
                            else {
                                sum_res_w1 += res_pair.x * x_mean;
                                sum_res_w2 += res_pair.y * x_diff;
                                sum_res_b += res_pair.x;
                            grad_x1[i][j_b][s] += res_pair.x * w;
                            grad_x2[i][j_b][s] += res_pair.y * wp;
                    float sgn = w > 0 ? 1.0f : -1.0f;
                    float sum_res_w = __shfl_xor_sync(0xffffffff, sum_res_w1 + sgn * sum_res_w2, t); // grad at co=threadIdx.x
                    sum_res_b = __shfl_xor_sync(0xffffffff, sum_res_b, t); // grad at co=threadIdx.x
                    grad_w[i] += sum_res_w;
                    grad_b[i] += sum_res_b;
            __syncthreads();
            #pragma unroll
                blockW[i][threadIdx.x][threadIdx.y] = grad_w[i];
                blockB[i][threadIdx.x][threadIdx.y] = grad_b[i];
            __syncthreads();
            #pragma unroll
                if (in_channel < CI_div_G && out_channel < CO_div_G) {
                    atomicAdd(&grad_weight[w_offset], blockW[i][threadIdx_high][threadIdx_low]);
                    atomicAdd(&grad_bias[w_offset], blockB[i][threadIdx_high][threadIdx_low]);
            __syncthreads();
    #pragma unroll
        #pragma unroll
            #pragma unroll
            for (int s = 1; s < GROUP_BCO_SUB; s++) {
                grad_x1[i][j][0] += __shfl_xor_sync(0xffffffff, grad_x1[i][j][s], THREAD_X / GROUP_BCO_SUB * s);
                grad_x2[i][j][0] += __shfl_xor_sync(0xffffffff, grad_x2[i][j][s], THREAD_X / GROUP_BCO_SUB * s);
    if (!has_hw) {
        #pragma unroll
            #pragma unroll
                blockIM[i][j][threadIdx.y][threadIdx.x] = grad_x1[i][j][0];
                blockID[i][j][threadIdx.y][threadIdx.x] = grad_x2[i][j][0];
        __syncthreads();
        #pragma unroll
            #pragma unroll
                grad_x1[i][j][0] = blockIM[i][j][threadIdx_low][threadIdx_high];
                grad_x2[i][j][0] = blockID[i][j][threadIdx_low][threadIdx_high];
    #pragma unroll
        if (b[j] < B) {
            #pragma unroll
                if (channel < CI_div_G) {
                    grad_inputL[offset] = (grad_x1[i][j][0] - grad_x2[i][j][0]) * 0.5f;
                    grad_inputU[offset] = (grad_x1[i][j][0] + grad_x2[i][j][0]) * 0.5f;
void backward_input_weight(const float* grad_outputL, const float* grad_outputU, const float* inputL,
                           const float* inputU, const float* weight, const float* bias,
                           const float* outputL, const float* outputU, int B, int CO, int CI, int G, int HW,
                           float* grad_inputL, float* grad_inputU, float* grad_weight, float* grad_bias) {
    const int GROUP_CI = 3;
    const int GROUP_BCO = 4;
    const int GROUP_BCO_SUB = 1;
    const int BLOCK_CI_SIZE = 32;
    int CI_div_G = CI / G, CO_div_G = CO / G;
    dim3 dimBlock(WARP_SIZE / GROUP_BCO, BLOCK_CI_SIZE);
    dim3 dimGrid((B * HW - 1) / WARP_SIZE + 1, (CI_div_G - 1) / (BLOCK_CI_SIZE * GROUP_CI) + 1, G);
    cudaMemset(grad_weight, 0, CO * CI_div_G * sizeof(float));
    cudaMemset(grad_bias, 0, CO * CI_div_G * sizeof(float));
    logsumexp_bound_backward_input_weight_kernel<GROUP_CI, GROUP_BCO, GROUP_BCO_SUB, BLOCK_CI_SIZE, false, false><<<dimGrid, dimBlock>>>(
        grad_outputL, grad_outputU, inputL, inputU, weight, bias, outputL, outputU, B, CO_div_G, CI_div_G, HW, G,
        grad_inputL, grad_inputU, grad_weight, grad_bias);
void test(int B, int CI, int CO) {
	int HW = 1;
    float *y_lower = new float[B * CO * HW];
    float *y_upper = new float[B * CO * HW];
    float *x_lower = new float[B * CI * HW];
    float *x_upper = new float[B * CI * HW];
    float *weight = new float[CO * CI];
    float *bias = new float[CO * CI];
    float *grad_y_lower = new float[B * CO * HW];
    float *grad_y_upper = new float[B * CO * HW];
    for (int i = 0; i < B * CI * HW; i++) {
        float mean = ((float)rand() - 0.5) / RAND_MAX;
        float diff = (float)rand() / RAND_MAX;
        x_lower[i] = mean - diff;
        x_upper[i] = mean + diff;
    for (int i = 0; i < CO * CI; i++)
        weight[i] = ((float)rand() - 0.5) / RAND_MAX;
        bias[i] = ((float)rand() - 0.5) / RAND_MAX;
    for (int i = 0; i < B * CO * HW; i++) {
        y_lower[i] = ((float)rand() - 0.5) / RAND_MAX;
        y_upper[i] = ((float)rand() - 0.5) / RAND_MAX;
        grad_y_lower[i] = ((float)rand() - 0.5) / RAND_MAX;
        grad_y_upper[i] = ((float)rand() - 0.5) / RAND_MAX;
    float *x_lower_cuda, *x_upper_cuda, *weight_cuda, *bias_cuda, *y_lower_cuda, *y_upper_cuda,
          *grad_y_lower_cuda, *grad_y_upper_cuda, *grad_x_lower_cuda, *grad_x_upper_cuda, *grad_weight_cuda, *grad_bias_cuda;
    cudaMallocManaged(&y_lower_cuda, B * CO * HW * sizeof(float));
    cudaMallocManaged(&y_upper_cuda, B * CO * HW * sizeof(float));
    cudaMallocManaged(&x_lower_cuda, B * CI * HW * sizeof(float));
    cudaMallocManaged(&x_upper_cuda, B * CI * HW * sizeof(float));
    cudaMallocManaged(&weight_cuda, CO * CI * sizeof(float));
    cudaMallocManaged(&bias_cuda, CO * CI * sizeof(float));
    cudaMallocManaged(&grad_y_lower_cuda, B * CO * HW * sizeof(float));
    cudaMallocManaged(&grad_y_upper_cuda, B * CO * HW * sizeof(float));
    cudaMallocManaged(&grad_x_lower_cuda, B * CI * HW * sizeof(float));
    cudaMallocManaged(&grad_x_upper_cuda, B * CI * HW * sizeof(float));
    cudaMallocManaged(&grad_weight_cuda, CO * CI * sizeof(float));
    cudaMallocManaged(&grad_bias_cuda, CO * CI * sizeof(float));
    cudaMemcpy(x_lower_cuda, x_lower, B * CI * HW * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(x_upper_cuda, x_upper, B * CI * HW * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(y_lower_cuda, y_lower, B * CO * HW * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(y_upper_cuda, y_upper, B * CO * HW * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(weight_cuda, weight, CO * CI * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(bias_cuda, bias, CO * CI * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(grad_y_lower_cuda, grad_y_lower, B * CI * HW * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(grad_y_upper_cuda, grad_y_upper, B * CI * HW * sizeof(float), cudaMemcpyHostToDevice);
    backward_input_weight(grad_y_lower_cuda, grad_y_upper_cuda, x_lower_cuda, x_upper_cuda,
        weight_cuda, bias_cuda, y_lower_cuda, y_upper_cuda, B, CO, CI, 1, HW, grad_x_lower_cuda, grad_x_upper_cuda, grad_weight_cuda, grad_bias_cuda);
    cudaDeviceSynchronize();
    cudaFree(y_lower_cuda);
    cudaFree(y_upper_cuda);
    cudaFree(x_lower_cuda);
    cudaFree(x_upper_cuda);
    cudaFree(weight_cuda);
    cudaFree(bias_cuda);
    cudaFree(grad_x_lower_cuda);
    cudaFree(grad_x_upper_cuda);
    cudaFree(grad_weight_cuda);
    cudaFree(grad_y_lower_cuda);
    cudaFree(grad_y_upper_cuda);
    cudaFree(grad_bias_cuda);
    delete[] y_lower;
    delete[] y_upper;
    delete[] x_lower;
    delete[] x_upper;
    delete[] weight;
    delete[] bias;
    delete[] grad_y_lower;
    delete[] grad_y_upper;
int main() {
    test(512, 5120, 5120);
my suggestion is to file a bug.
Thank you. I have reported the bug accordingly. See Performance varies greatly with different nvcc compilers | NVIDIA Developer.
