I am trying to compile some legacy code that has been finicky in the past, but did work with the PGI workstation package for me on a different platform.
The code assumes 32 bit pointers where as the 64 bit system (AMD Opteron Chip with Ubuntu 64 bit Linux) I am using is producing 64 bit pointers. The solution was to compile the code with a 32 bit flag called e.g. pgf77 -tp k8-32.
While this worked for me in the past, I am now getting this error
“pgf77-Fatal–tp k8-32 is not supported in this installation”
I’m wondering if -tp k8-32 is deprecated or why this is not working? I have tried -tp p7, which the compiler accepts, but it does not solve the issue as it did last time. I am using an evaluation license and will buy the software if this works, so am wondering if I have encountered a limitation of the evaluation package or if something else has changed?
Thanks for any help you can provide.
