While compiling a fortran code with pgi directives I am experiencing the following error:
PGF90-S-0000-Internal compiler error. unknown reference 437 (/project/s83/lapixa/GPU/turb_standalone_1/src/turbulence_tran.f90: 1476)
Would you have any suggestion on what could be triggering such error ?
The line number 1476 refers to the end of the routine, so it is not very helpful, while I don’t know the meaning of the number 437 (is it a variable or a line number or error code ?).
I tried to had the following option -v -ta=keepgu:
/apps/eiger/pgi-11.8/linux86-64/11.8/bin/pgf902 /tmp/pgf90YuZfwkoGHnbg.ilm -fn /project/s83/lapixa/GPU/turb_standalone_1/src/turbulence_tran.f90 -opt 3 -inform inform -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -vect 60 -y 34 16 -x 34 0x8 -x 32 6291456 -y 19 8 -y 35 0 -x 42 0x30 -x 39 0x40 -x 39 0x80 -x 34 0x400000 -x 149 1 -x 150 1 -x 59 4 -x 59 4 -x 6 0x100 -tp istanbul -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -x 120 0x200 -astype 0 -ieee 1 -inlib /tmp/pgf90suZf2Mnn_iav.ext -x 14 32 -x 124 1 -x 42 0x400000 -x 163 0x10001 -x 176 8 -accel nvidia -x 163 0x40 -x 163 8 -x 180 0x40 -x 176 0x140000 -x 177 0x0202007f -x 176 8448 -quad -x 119 0x10000000 -x 129 0x40000000 -x 129 2 -x 42 0x14200000 -y 39 1 -x 80 0x800000 -x 0 0x1000000 -x 2 0x100000 -x 0 0x2000000 -x 161 16385 -x 162 16385 -cmdline '+pgf90 /project/s83/lapixa/GPU/turb_standalone_1/src/turbulence_tran.f90 -c -I. -I/project/s83/lapixa/GPU/turb_standalone_1/src -I/apps/eiger/mvapich2/1.5.1p1/mvapich2-gnu/include -D__MPICH2 -v -Kieee -Mbyteswapio -Mfree -Mpreprocess -Minform=inform -D__COSMO__ -ta=nvidia,cc20,nofma,keepgpu -Mcache_align -Mflushz -Mlre -Mprefetch -Mpreprocess -Mscalarsse -Mvect=noassoc -Mvect=sse -O3 -Minline -Minfo=inline,accel -o turbulence_tran.o' -asm /tmp/pgf90IuZfM0tu53qg.s
0 inform, 0 warnings, 0 severes, 0 fatal for turbulence_tran
executing /apps/eiger/pgi-11.8/linux86-64/11.8/bin/pgnvd turbulence_tran.001.gpu -computecap=20 -ptx /tmp/pgacc0yZfC_IrR0OB.ptx -o /tmp/pgaccuyZf8X6hlAW2.bin -3.2 -ptxinfo /tmp/pgacc0yZfCbrbUlZA.info
executing /apps/eiger/pgi-11.8/linux86-64/11.8/bin/pgnvd turbulence_tran.011.gpu -computecap=20 -ptx /tmp/pgacc0yZfCBZyRDAb.ptx -o /tmp/pgaccuyZf82oPlRSQ.bin -3.2 -ptxinfo /tmp/pgacc0yZfCUfnUero.info
PGF90-F-0008-Error limit exceeded (/project/s83/lapixa/GPU/turb_standalone_1/src/turbulence_tran.f90: 1476)
PGF90/x86-64 Linux 11.8-0: compilation aborted
pgf90-Fatal-f902 completed with exit code 1
So it seems to be craching when compiling turbulence_tran.011.gpu where the kernel name is turbtran_1143_gpu. I don’t see however anything obvious in the corresponding section in the fortran code.
Thanks for your help,
Xavier
