Hi.
I am trying to specify the inertias for the elements of an imported urdf file. And by inertia i mean the whole inertia matrix, not just the diagonal elements.
I want to do it with a python script so that, together with changing mass and/ or density , i could test differents robots behaviour depending on the real life material.
Using the RigidPrim i can only modify mass and density but not the inertias.
How can i acheve this?
This link can help putting some context here.
Could you script a dynamic value that uses a varying additional mass modifier which uses a quaterion to change the standard gravity direction to represent it? Also look at which physx model you are using.
i’m not super versed in this, but I think i know what you mean… that is not an easy problem.
The mass properties are stored in USD using UsdPhysicsMassAPI:
You could access directly the MassAPI and set the diagonal inertia together with the principalAxes.
Regards,
Ales
