I am trying to import a simple urdf block with Python and giving it a mass. To do so, I am creating a RigidPrim (which has the mass api) from the loaded urdf. However, I keep having this issue:
2022-10-18 13:24:21 [8,739ms] [Error] [omni.physicsschema.plugin] Rigid Body of (/World/box/block_1_base_link) missing xformstack reset when child of rigid body (/World/box) in hierarchy. Simulation of multiple RigidBodyAPI's in a hierarchy will cause unpredicted results. Please fix the hierarchy or use XformStack reset.
I understand the problem (see How to do xformstack reset?) but I cannot found a solution to my issue, loading a urdf and giving it a mass. Has anyone a solution ?
Here is the code to reproduce the issue load_urdf.zip (1.8 KB)
What about setting the mass directly on the rigid object
prim = RigidPrim(prim_path="/World/box/block_1_base_link", mass=1)
instead of applying it on the articulation?
By doing it the RigidPrim will use the current applied rigid body API…
Otherwise, it will apply a rigid body API to the articulation resulting in the nested rigid body problem.
Flatcache allows simulating faster by disconnecting the physics from USD update.
That’s why the block was floating in the air like if no gravity was applied to it
