After I have enabled and tried using RDP (I won’t do that mistake again), all my games with physx can’t use GPU for physx effects. When I turn on Physx indicator, it always stays at CPU.
I have tried using Physx Fluid, and it only uses CPU, with Physx GPU greyed out.
In GPU-Z OpenCL, CUDE, PhysX are not ticked:
Steps I have tried so far:
Uninstalled video drivers using Driver Sweeper tool, rebooted in safe mode, bla-bla.
Installed the latest drivers with Physx ticked. No luck -
Uninstalled with Driver sweeper, did all that, then installed latest drivers only (without Physx, GeForce experience, etc). Installed latest Physx as a stand-alone. No luck.
Uninstalled with Driver Sweeper, installed old drivers (from February). Then installed old Physx as a stand-alone package. No luck.
GPU-Z is still showing no CUDA or PhysX, games with Physx (Metro LL for example) run very bad (10 fps). Of course disabling physx in games solves the problem, but I still want Physx to work and use GPU, and CUDA to work as well. I have since disabled RDP, but that didn’t help. Any way to undo those changes (I don’t have any backups, can’t restore), and replace RDP drivers with NVidia ones?
Thank you very much.
