Hi Forum, New here so bare with me,
I searched the forum and couldn’t find a good answer to this.
Basically I’m having an issue with multi fbx objects (basically a building where one object is the tower and the second object is the base of the building) exported from Max. Upon fracturing, Phy-x creates what appears to be duplicates of the object.
Here are the steps im using to create the desctuctable with picture references to help evaluate the mistake I’m making.
Step 1 Import Multi Object FBX
[url]http://postimg.org/image/fw2d54di9/[/url]
Upon import Phys-x creates depth layer 1 <-seems to be working as intended
Step 2 Apply fracture Map
[url]http://postimg.org/image/hiqsgooz3/[/url]
At this point I’m created a fracture map set to x+ only thickness 100 but ive also tried 50.
Step 3 Fracturing
[url]http://postimg.org/image/3p715dlrj/[/url]
Fracture produces additional fracture depth of 2, and only displays half of the model. This doesn’t look as intended. What I want to create are fractures that go through the entire building.
Step 4 Preview Depth and Playground show Duplicated Objects
[url]http://postimg.org/image/d3p1te3dz/[/url]
When I check out the fracture results at either depth 1 or in playground it appears that each fbx object has been duplicated.
Obviously I know this has something to do with me but i can’t figure it out any suggestions on how I would resolve this. It only happens on multi fbx when I do tests of single FBX objects it works fine.
Thanks in Advance
