Hi everyone, was redirected here from the PhysX Github discussion forum.
In USD Composer, there is an inflatable simulation tutorial. I would like to edit the simulation script (shown below) so that at each timestep of the simulation, the vertices and edges (if there are any) of the cloth/mesh are written to a file - this way I can reconstruct the mesh of the inflatable.
I am aware there exists PxParticleBuffer::getPositionInvMasses()/ PxParticleBuffer::getVelocities() to get the position and velocities of particles in C++, but I’m unsure on how this would be called using the Python API. Specifically, how would I obtain these in Python and obtain them at every time step that the simulation runs?
Does anyone, perhaps someone from the Physics team, know how to do so? I imagine it would be like a callback function that executes with each timestep but unsure.
import carb
import math
from omni.physx.scripts import physicsUtils, particleUtils
from pxr import UsdGeom, Sdf, Gf, PhysxSchema, UsdPhysics
import omni.usd
import omni.physxdemos as demo
from .ParticleDemoBaseDemo import ParticleDemoBase
class ParticleInflatableDemo(demo.Base, ParticleDemoBase):
title = "Particle Inflatable"
category = demo.Categories.PARTICLES
short_description = "Basic demo showing setup of a sphere as a particle inflatable"
description = "A basic sphere mesh is setup as a particle simulation inflatable cloth mesh."
def create(self, stage):
default_prim_path = self.setup_base_scene(stage, zoomAmount = 0.8)
# configure and create particle system
# we use all defaults, so the particle contact offset will be 5cm / 0.05m
# so the simulation determines the other offsets from the particle contact offset
particle_system_path = default_prim_path.AppendChild("particleSystem")
particle_system = PhysxSchema.PhysxParticleSystem.Define(stage, particle_system_path)
particle_system.CreateSimulationOwnerRel().SetTargets([self._scene.GetPath()])
# create material and assign it to the system:
particle_material_path = default_prim_path.AppendChild("particleMaterial")
particleUtils.add_pbd_particle_material(stage, particle_material_path)
physicsUtils.add_physics_material_to_prim(
stage, stage.GetPrimAtPath(particle_system_path), particle_material_path
# create a mesh that is turned into an inflatable
cube_u_resolution = 20
cube_v_resolution = 20
cube_w_resolution = 4
success, tmp_path = omni.kit.commands.execute(
"CreateMeshPrimWithDefaultXform",
prim_type="Cube",
u_patches=cube_u_resolution,
v_patches=cube_v_resolution,
w_patches=cube_w_resolution,
u_verts_scale=1,
v_verts_scale=1,
w_verts_scale=1,
half_scale=60.0,
cloth_mesh_path = Sdf.Path(omni.usd.get_stage_next_free_path(stage, "/Inflatable", True))
omni.kit.commands.execute("MovePrim", path_from=tmp_path, path_to=cloth_mesh_path)
cloth_mesh = UsdGeom.Mesh.Get(stage, cloth_mesh_path)
physicsUtils.setup_transform_as_scale_orient_translate(cloth_mesh)
physicsUtils.set_or_add_translate_op(cloth_mesh, Gf.Vec3f(0.0, 200.0, -20.0))
physicsUtils.set_or_add_orient_op(cloth_mesh, Gf.Quatf(Gf.Rotation(Gf.Vec3d(1,0,0), 10.0).GetQuat()))
physicsUtils.set_or_add_scale_op(cloth_mesh, Gf.Vec3f(1.0, 1.0, 0.04))
# configure as cloth
pressure = 8.0
stretchStiffness = 20000.0
bendStiffness = 100.0
shearStiffness = 100.0
damping = 0.5
particleUtils.add_physx_particle_cloth(
stage=stage,
path=cloth_mesh_path,
dynamic_mesh_path=None,
particle_system_path=particle_system_path,
spring_stretch_stiffness=stretchStiffness,
spring_bend_stiffness=bendStiffness,
spring_shear_stiffness=shearStiffness,
spring_damping=damping,
pressure=pressure,
# configure mass:
particle_mass = 0.1
num_verts = len(cloth_mesh.GetPointsAttr().Get())
mass = particle_mass * num_verts
massApi = UsdPhysics.MassAPI.Apply(cloth_mesh.GetPrim())
massApi.GetMassAttr().Set(mass)
# add render material:
material_path = self.create_pbd_material("OmniPBR")
"BindMaterialCommand", prim_path=cloth_mesh_path, material_path=material_path, strength=None
