When using the default pinmux spreadsheet (V1.08) to generate a pinmux configuration for a TX2i I get the following errors when running pinmux-dts2cf.py.
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt --mandatory_pinmux_file mandatory_pinmux.txt tegra18x-jetson-default-template-pinmux.dtsi tegra18x-jetson-default-template-gpio-default.dtsi 1.0 > ../../../bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg
ERROR: pin dap2_sclk_pc1(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap2_fs_pc4(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dmic1_clk_pm1(0x00004441) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dmic2_dat_pm2(0x00004441) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap4_sclk_pcc0(0x00004440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap4_fs_pcc3(0x00004440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin sdmmc4_dqs(0x00000444) field nvidia,tristate(0x00000010) is not matching, val = 0x00 expected = 0x01
