How can I confirm on a jetson orin nano device that the pinmux settings in the /boot/dtb/kernel_tegra234-p3768-0000-p3767-0005-nv.dtb file are the same as the pinmux settings I generated from Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template.xlsm
KevinFFF
3
Hi chichen345,
Are you using the devkit or custom board for Orin Nano?
Please note that pinmux device tree is not included in kernel dtb.
It is loaded in MB1(early boot).
May I know what’s your use case and requirement?
Related topics
| How to implement Custom Pinmux in Jetpack? | 19 | 633 | February 26, 2025 | |
| Pinmux configuration for Jetson orin nano | 6 | 335 | October 15, 2025 | |
| Question Regarding the Correct Procedure for Applying Pinmux Settings on Jetson Orin Nano (L4T R36.4.4) | 1 | 155 | August 8, 2025 | |
| Issues changing pinmux on jetson orin nano devkit | 2 | 238 | November 30, 2024 | |
| How to chang pinmux of Orin(t234)? | 14 | 2280 | May 11, 2022 | |
| Changing 40 PIN Header PINMUX with editing device tree in Orin Nano | 3 | 1142 | August 11, 2023 | |
| Pinmux functionality on Jetson Orin Nano | 3 | 1631 | June 5, 2024 | |
| Customised changes from the Pinmux tool for Orin Nano yeilds 3 dtsi files. Could you please let us how to build these dtsi files duirng the SDK build | 1 | 82 | November 28, 2024 | |
| Help with Jetpack 5 and Orin PinMux | 5 | 1404 | September 21, 2022 | |
| How do I configure my device tree and where are the source files for my device tree? | 5 | 338 | March 25, 2025 |
