I got black screen after running sudo sh cuda_11.6.0_510.39.01_linux.run
failed and then reboot.
That’s because cuda_11.6.0_510.39.01_linux.run
generated a blacklist to block loading nouveau driver.
Now I’ve to enter rescue mode to delete /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
So, can you generate blacklist ONLY after installing successfully?
P.S. In a installation tip:
Existing package manager installation of the driver found. It is strongly
recommended that you remove this before continuing.
But what’s this
stand for in above tip?
Remove package manager? Remove the driver? Remove which driver exactly?
So it’s better to show what’s this exactly.
Please show it exactly to avoid confusion.
