Please help the Orin NX Ethernet issues
We are currently using the Jetson Orin NX 8GB.
We are using L4T 35.3.1 & JetPack 5.1.1, and we recently applied the LPDDR patch due to PCN210100.
However, only the modules equipped with SEC DDR are experiencing the following issue:
  1. An Ethernet link drop issue, which was not seen on modules with Micron LPDDR, is now occurring.
    Where should we investigate to address this?
  2. The Jetson Orin NX datasheet does not specify the part number of the Ethernet PHY integrated in the module.
    Some say a Realtek PHY is used—where can we find this part number?
Will you see same behavior if you put this module on NV devkit and flash with latest jp5.1.5?
And the PHY here is rtl8111
Dear All,
In case of Orin NX 8GB, can I use below command to disable EEE(energy efficient etherent) function?
If not, could you let me know how I can disable EEE function ?
root@82BF:~# ethtool --show-eee eth0
EEE Settings for eth0:
EEE status: disabled
Tx LPI: disabled
Supported EEE link modes: 100baseT/Full
1000baseT/Full
Advertised EEE link modes: Not reported
Link partner advertised EEE link modes: 100baseT/Full
1000baseT/Full
root@82BF:~#
Hi, Wayne
We disabled EEE (Energy Efficient Ethernet) on the Jetson and conducted tests. According to what we found, all devices on the same network need to have EEE enabled for the link to remain stable. Is this correct? We are not using latest jp.
Hi…
The link below discusses a similar issue to ours.
Orin NX Ethernet disconnect when system over loading - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
JP5.1.1 L4T R35.3.1 Ethernet (eth0) not working - Orin NX - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
We need to confirm whether the problem is solved by upgrading Jetpack to 6.0GA as in the solution in the link above.
Also, we may encounter another issue if we upgrade Jetpack.
Please let me know if there is any other solution besides upgrading Jetpack.
Thanks,
Raymond
Hi…
If we upgrade Jetpack to 6.0GA in the current situation, we will also have to make many modifications to our application code.
In order to solve this Ethernet issue, you need a patch that can be applied to the current LT4 35.4.1, rather than upgrading Jetpack to 6.0GA.
Additionally, it is necessary to check which part of the current problematic patch “overlay_PCN210361_PCN210100_r35.4.1.tbz2” affects the operation of ethernet.
Thanks,
Raymond
Hi all,
Are you guys working together for the current issue?
As Wayne has requested before, please check if you can reproduce the similar issue on Orin Nano devkit(p3768).
You can also clarify which release may fix your issue so that we can help to find the possible fixes.
Please use the Orin Nano devkit to verify with both Jetpack 5.1.2(r35.4.1) and Jetpack 5.1.5(r35.6.1) and share the full dmesg when you hit the issue for further check.
