Issue description :
We have connected a temperature sensor(part number : TE connectivity HPP845E131R5) at the PM_I2C bus in Jetson TX2. We are reading the temperature value from the sensor continuously at the rate of 1 reading per second. And while doing so we find that sometimes we get “arb lost in communicate to add 0x40” error in the range of +8.0 °C to +8.76 °C.
We were not able to probe the signals exactly at that moment when the failure occurs, as the temperature Window is small. We tried to change the I2C bus from PM_I2C to I2C_GP0, in that case we were not able to see the issue in that temp range, so can you please explain this behavior as of why this error occurs in the PM_I2C in the temp range, also please find the logs below for the PM_I2C test case.
Doubts:
There are multiple devices in the PM_I2C bus in the Jetson TX2 SOM, can this issue be due to multiple devices connected in the same bus
Can we use the PM_I2C bus in that temperature range or is there any limitation in doing so?
Note:
We checked PM_I2C with both 100KHZ and 400KHZ clock rates.
Temperature value is 11.02*C
Temperature value is 10.99*C
Temperature value is 10.97*C
Temperature value is 10.93*C
Temperature value is 10.90*C
Temperature value is 10.85*C
Temperature value is 10.81*C
Temperature value is 10.80*C
Temperature value is 10.77*C
Temperature value is 10.72*C
Temperature value is 10.71*C
Temperature value is 10.70*C
Temperature value is 10.68*C
Temperature value is 10.66*C
Temperature value is 10.63*C
Temperature value is 10.62*C
Temperature value is 10.60*C
Temperature value is 10.57*C
Temperature value is 10.53*C
Temperature value is 10.51*C
Temperature value is 10.49*C
Temperature value is 10.46*C
Temperature value is 10.44*C
Temperature value is 10.41*C
Temperature value is 10.39*C
Temperature value is 10.34*C
Temperature value is 10.30*C
Temperature value is 10.28*C
Temperature value is 10.24*C
Temperature value is 10.20*C
Temperature value is 10.19*C
Temperature value is 10.14*C
Temperature value is 10.09*C
Temperature value is 10.07*C
Temperature value is 10.04*C
Temperature value is 10.00*C
Temperature value is 9.98*C
Temperature value is 9.95*C
Temperature value is 9.92*C
Temperature value is 9.88*C
Temperature value is 9.86*C
Temperature value is 9.84*C
Temperature value is 9.80*C
Temperature value is 9.77*C
Temperature value is 9.76*C
Temperature value is 9.71*C
Temperature value is 9.69*C
Temperature value is 9.67*C
Temperature value is 9.66*C
Temperature value is 9.61*C
Temperature value is 9.59*C
Temperature value is 9.54*C
Temperature value is 9.53*C
Temperature value is 9.49*C
Temperature value is 9.47*C
Temperature value is 9.41*C
Temperature value is 9.37*C
Temperature value is 9.35*C
Temperature value is 9.34*C
Temperature value is 9.32*C
Temperature value is 9.30*C
Temperature value is 9.27*C
Temperature value is 9.25*C
Temperature value is 9.21*C
Temperature value is 9.17*C
Temperature value is 9.16*C
Temperature value is 9.14*C
Temperature value is 9.15*C
Temperature value is 9.12*C
Temperature value is 9.11*C
Temperature value is 9.08*C
Temperature value is 9.04*C
Temperature value is 9.02*C
Temperature value is 9.00*C
Temperature value is 8.98*C
Temperature value is 8.95*C
Temperature value is 8.93*C
Temperature value is 8.87*C
Temperature value is 8.83*C
Temperature value is 8.81*C
Temperature value is 8.79*C
Temperature value is 8.77*C
Temperature value is 8.75*C
[ 1344.454757] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1344.460112] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1344.466961] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1344.473376] Temperature sensor : i2c error
[ 1345.549594] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1345.556749] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1345.562686] Temperature sensor : i2c error
[ 1348.670442] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1348.675742] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1348.682524] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1348.689081] Temperature sensor : i2c error
[ 1349.788610] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1349.795796] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1349.803533] Temperature sensor : i2c error
[ 1352.918500] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1352.923799] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1352.930567] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1352.937016] Temperature sensor : i2c error
[ 1353.988475] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1353.995496] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1354.001467] Temperature sensor : i2c error
[ 1357.123371] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1357.128978] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1357.135867] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1357.142383] Temperature sensor : i2c error
[ 1358.200399] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1358.207492] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1358.213488] Temperature sensor : i2c error
[ 1361.358972] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1361.364326] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1361.373908] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1361.380508] Temperature sensor : i2c error
[ 1362.474286] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1362.481301] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1362.487281] Temperature sensor : i2c error
[ 1365.604013] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1365.609310] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1365.615949] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1365.622371] Temperature sensor : i2c error
[ 1366.672183] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1366.679235] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1366.685282] Temperature sensor : i2c error
[ 1369.814492] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1369.819836] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1369.829317] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1369.836054] Temperature sensor : i2c error
[ 1370.930558] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1370.937624] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1370.943853] Temperature sensor : i2c error
[ 1374.072127] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 1374.077431] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 1374.084244] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 1374.090696] Temperature sensor : i2c error
[ 1375.146358] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 1375.153368] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 1375.159382] Temperature sensor : i2c error
Temperature value is 8.01*C
Temperature value is 7.99*C
Temperature value is 7.96*C
Temperature value is 7.93*C
Temperature value is 7.92*C
Temperature value is 7.90*C
Temperature value is 7.89*C
Temperature value is 7.87*C
Temperature value is 7.85*C
Temperature value is 7.84*C
Temperature value is 7.83*C
Temperature value is 7.81*C
Temperature value is 7.78*C
Temperature value is 7.76*C
Temperature value is 7.74*C
Temperature value is 7.71*C
Temperature value is 7.65*C
Temperature value is 7.64*C
Temperature value is 7.63*C
Temperature value is 7.60*C
Temperature value is 7.59*C
Temperature value is 7.56*C
Temperature value is 7.57*C
Temperature value is 7.54*C
Temperature value is 7.50*C
Temperature value is 7.48*C
Temperature value is 7.45*C
Temperature value is 7.42*C
Temperature value is 7.40*C
Temperature value is 7.38*C
Temperature value is 7.37*C
Temperature value is 7.35*C
Temperature value is 7.33*C
Temperature value is 7.29*C
Temperature value is 7.27*C
Temperature value is 5.01*C
Temperature value is 5.03*C
Temperature value is 5.05*C
Temperature value is 5.07*C
Temperature value is 5.09*C
Temperature value is 5.11*C
Temperature value is 5.13*C
Temperature value is 5.16*C
Temperature value is 5.18*C
Temperature value is 5.21*C
Temperature value is 5.22*C
Temperature value is 5.24*C
Temperature value is 5.28*C
Temperature value is 5.30*C
Temperature value is 5.32*C
Temperature value is 5.35*C
Temperature value is 5.36*C
Temperature value is 5.38*C
Temperature value is 5.42*C
Temperature value is 5.43*C
Temperature value is 5.47*C
Temperature value is 5.48*C
Temperature value is 5.51*C
Temperature value is 5.54*C
Temperature value is 5.57*C
Temperature value is 5.61*C
Temperature value is 5.62*C
Temperature value is 5.65*C
Temperature value is 5.67*C
Temperature value is 5.68*C
Temperature value is 5.70*C
Temperature value is 5.72*C
Temperature value is 5.75*C
Temperature value is 5.77*C
Temperature value is 5.79*C
Temperature value is 5.81*C
Temperature value is 5.82*C
Temperature value is 5.85*C
Temperature value is 5.89*C
Temperature value is 5.90*C
Temperature value is 5.92*C
Temperature value is 5.94*C
Temperature value is 5.96*C
Temperature value is 5.98*C
Temperature value is 5.99*C
Temperature value is 6.02*C
Temperature value is 6.05*C
Temperature value is 6.06*C
Temperature value is 6.09*C
Temperature value is 6.11*C
Temperature value is 6.14*C
Temperature value is 6.16*C
Temperature value is 6.19*C
Temperature value is 6.21*C
Temperature value is 6.23*C
Temperature value is 6.26*C
Temperature value is 6.27*C
Temperature value is 6.28*C
Temperature value is 6.31*C
Temperature value is 6.33*C
Temperature value is 6.36*C
Temperature value is 6.38*C
Temperature value is 6.41*C
Temperature value is 6.42*C
Temperature value is 6.45*C
Temperature value is 6.48*C
Temperature value is 6.50*C
Temperature value is 6.51*C
Temperature value is 6.54*C
Temperature value is 6.56*C
Temperature value is 6.58*C
Temperature value is 6.60*C
Temperature value is 6.61*C
Temperature value is 6.64*C
Temperature value is 6.67*C
Temperature value is 6.69*C
Temperature value is 6.72*C
Temperature value is 6.73*C
Temperature value is 6.76*C
Temperature value is 6.79*C
Temperature value is 6.81*C
Temperature value is 6.83*C
Temperature value is 6.85*C
Temperature value is 6.86*C
Temperature value is 6.89*C
Temperature value is 6.90*C
Temperature value is 6.93*C
Temperature value is 6.95*C
Temperature value is 6.97*C
Temperature value is 6.98*C
Temperature value is 7.00*C
Temperature value is 7.01*C
Temperature value is 7.03*C
Temperature value is 7.07*C
Temperature value is 7.10*C
Temperature value is 7.12*C
Temperature value is 7.14*C
Temperature value is 7.15*C
Temperature value is 7.17*C
Temperature value is 7.19*C
Temperature value is 7.22*C
Temperature value is 7.25*C
Temperature value is 7.26*C
Temperature value is 7.28*C
Temperature value is 7.31*C
Temperature value is 7.32*C
Temperature value is 7.43*C
Temperature value is 7.52*C
Temperature value is 7.53*C
Temperature value is 7.55*C
Temperature value is 7.62*C
Temperature value is 7.67*C
Temperature value is 7.68*C
Temperature value is 7.70*C
Temperature value is 7.73*C
Temperature value is 7.75*C
Temperature value is 7.79*C
Temperature value is 7.88*C
Temperature value is 7.91*C
Temperature value is 7.94*C
Temperature value is 7.97*C
Temperature value is 7.98*C
Temperature value is 8.02*C
Temperature value is 8.05*C
[ 3042.246526] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3042.251895] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3042.258739] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3042.265301] Temperature sensor : i2c error
[ 3043.337897] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3043.345035] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3043.350950] Temperature sensor : i2c error
[ 3046.478015] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3046.483487] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3046.492010] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3046.498647] Temperature sensor : i2c error
[ 3047.554482] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3047.561494] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3047.567510] Temperature sensor : i2c error
[ 3050.674300] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3050.679602] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3050.686372] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3050.692842] Temperature sensor : i2c error
[ 3051.772455] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3051.779715] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3051.787680] Temperature sensor : i2c error
[ 3054.915288] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3054.920694] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3054.927540] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3054.934035] Temperature sensor : i2c error
[ 3056.026899] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3056.037026] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3056.043420] Temperature sensor : i2c error
[ 3059.171739] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3059.177128] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3059.183931] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3059.190347] Temperature sensor : i2c error
[ 3060.269166] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3060.276253] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3060.282272] Temperature sensor : i2c error
[ 3063.382899] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3063.388272] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3063.395167] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3063.401586] Temperature sensor : i2c error
[ 3064.467083] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3064.474269] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3064.480304] Temperature sensor : i2c error
[ 3067.586455] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3067.591761] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3067.598532] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3067.605006] Temperature sensor : i2c error
[ 3068.686284] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3068.693390] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3068.699420] Temperature sensor : i2c error
[ 3071.828755] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3071.834051] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3071.840741] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3071.847197] Temperature sensor : i2c error
[ 3072.906557] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3072.916800] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3072.922808] Temperature sensor : i2c error
[ 3076.038792] tegra-i2c c250000.i2c: I2C_INT_STATUS - 0x2
[ 3076.044116] tegra-i2c c250000.i2c: i2c transfer timed out addr: 0x40
[ 3076.050905] i2c_read_reg:read reg error:reg=e3,val=0 receive ret=146
[ 3076.057307] Temperature sensor : i2c error
[ 3077.118060] tegra-i2c c250000.i2c: arb lost in communicate to add 0x40
[ 3077.125181] i2c_read_reg:write reg error:reg=e3 sent ret = 245
[ 3077.131440] Temperature sensor : i2c error
Temperature value is 8.78*C
Temperature value is 8.80*C
Temperature value is 8.82*C
Temperature value is 8.86*C
Temperature value is 8.88*C
Temperature value is 8.91*C
Temperature value is 8.94*C
Temperature value is 8.97*C
Temperature value is 9.01*C
Temperature value is 9.03*C
Temperature value is 9.06*C
Temperature value is 9.10*C
Temperature value is 9.18*C
Temperature value is 9.19*C
Temperature value is 9.22*C
Temperature value is 9.24*C
Temperature value is 9.29*C
Temperature value is 9.31*C
Temperature value is 9.33*C
Temperature value is 9.36*C
Temperature value is 9.39*C
Temperature value is 9.42*C
Temperature value is 9.46*C
Temperature value is 9.48*C
Temperature value is 9.51*C
Temperature value is 9.55*C
Temperature value is 9.57*C
Temperature value is 9.62*C
Temperature value is 9.64*C
Temperature value is 9.72*C
Temperature value is 9.75*C
Temperature value is 9.79*C
Temperature value is 9.82*C
Temperature value is 9.89*C
Temperature value is 9.91*C
Temperature value is 9.93*C
Temperature value is 9.97*C
Temperature value is 10.01*C
Temperature value is 10.06*C
Temperature value is 10.08*C
Temperature value is 10.11*C
Temperature value is 10.13*C
Temperature value is 10.16*C
Temperature value is 10.22*C
Temperature value is 10.23*C
Temperature value is 10.25*C
Temperature value is 10.26*C
Temperature value is 10.29*C
Temperature value is 10.31*C
Temperature value is 10.36*C
Temperature value is 10.38*C
Temperature value is 10.43*C
Temperature value is 10.45*C
Temperature value is 10.48*C
Temperature value is 10.50*C
Temperature value is 10.54*C
Temperature value is 10.55*C
Temperature value is 10.65*C
Temperature value is 10.75*C
Temperature value is 10.79*C
Temperature value is 10.82*C
Temperature value is 10.84*C
Temperature value is 10.86*C
Temperature value is 10.87*C
Temperature value is 10.94*C
Temperature value is 10.95*C
Temperature value is 11.03*C
Temperature value is 11.05*C
Temperature value is 11.09*C
Temperature value is 11.10*C
Temperature value is 11.12*C
Temperature value is 11.14*C
Temperature value is 11.16*C
Temperature value is 11.18*C
Temperature value is 11.20*C
Temperature value is 11.23*C
Temperature value is 11.25*C
Temperature value is 11.28*C
Temperature value is 11.29*C
Temperature value is 11.32*C
Temperature value is 11.34*C
Temperature value is 11.37*C
Temperature value is 11.39*C
Temperature value is 11.41*C
Temperature value is 11.43*C
Temperature value is 11.45*C
Temperature value is 11.46*C
Temperature value is 11.48*C
Temperature value is 11.53*C
Temperature value is 11.55*C
Temperature value is 11.57*C
Temperature value is 11.60*C
Temperature value is 11.62*C
Temperature value is 11.66*C
Temperature value is 11.67*C
Temperature value is 11.70*C
Temperature value is 11.73*C
Temperature value is 11.75*C
Temperature value is 11.76*C
Temperature value is 11.78*C
Temperature value is 11.82*C
Temperature value is 11.83*C
Temperature value is 11.86*C
Temperature value is 11.88*C
Temperature value is 11.90*C
Temperature value is 11.91*C
Temperature value is 11.93*C
Temperature value is 11.96*C
Temperature value is 11.98*C
Temperature value is 12.01*C
PM_I2C test result.txt (205 KB)
