I’m using JetPack3.1 in my TX2
I want to change tx2 into sleep mode through the command line.
sudo pm-suspend does not work
but I use mouse to click the system menu suspend button, every thing is OK
Can someone help me?
thanks
here is the pm-suspend log
Initial commandline parameters:
Mon May 21 08:16:00 UTC 2018: Running hooks for suspend.
Running hook /usr/lib/pm-utils/sleep.d/000kernel-change suspend suspend:
/usr/lib/pm-utils/sleep.d/000kernel-change suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/000record-status suspend suspend:
/usr/lib/pm-utils/sleep.d/000record-status suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00logging suspend suspend:
Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017 aarch64 aarch64 aarch64 GNU/Linux
Module Size Used by
fuse 89008 2
bcmdhd 7625819 0
pci_tegra 74691 0
bluedroid_pm 13564 0
total used free shared buff/cache available
Mem: 8039124 358092 7259068 15304 421964 7590596
Swap: 0 0 0
/usr/lib/pm-utils/sleep.d/00logging suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00powersave suspend suspend:
/usr/lib/pm-utils/sleep.d/00powersave suspend suspend: success.
Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend:
/etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/40inputattach suspend suspend:
/usr/lib/pm-utils/sleep.d/40inputattach suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/50unload_alx suspend suspend:
/usr/lib/pm-utils/sleep.d/50unload_alx suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend:
Selected interface 'p2p-dev-wlan0'
OK
/usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/75modules suspend suspend:
/usr/lib/pm-utils/sleep.d/75modules suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/90clock suspend suspend:
/usr/lib/pm-utils/sleep.d/90clock suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend:
/usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95anacron suspend suspend:
/usr/lib/pm-utils/sleep.d/95anacron suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend:
/usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/95led suspend suspend:
/usr/lib/pm-utils/sleep.d/95led suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend:
/usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/99video suspend suspend:
/usr/lib/pm-utils/sleep.d/99video suspend suspend: success.
Mon May 21 08:16:00 UTC 2018: performing suspend
sh: echo: I/O error
Mon May 21 08:16:03 UTC 2018: Awake.
Mon May 21 08:16:03 UTC 2018: Running hooks for resume
Running hook /usr/lib/pm-utils/sleep.d/99video resume suspend:
/usr/lib/pm-utils/sleep.d/99video resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend:
/usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95led resume suspend:
/usr/lib/pm-utils/sleep.d/95led resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/95hdparm-apm resume suspend:
/usr/lib/pm-utils/sleep.d/95hdparm-apm resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95anacron resume suspend:
/usr/lib/pm-utils/sleep.d/95anacron resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/94cpufreq resume suspend:
/usr/lib/pm-utils/sleep.d/94cpufreq resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/90clock resume suspend:
/usr/lib/pm-utils/sleep.d/90clock resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/75modules resume suspend:
Reloaded unloaded modules.
/usr/lib/pm-utils/sleep.d/75modules resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend:
OK
/usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/50unload_alx resume suspend:
/usr/lib/pm-utils/sleep.d/50unload_alx resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/40inputattach resume suspend:
/usr/lib/pm-utils/sleep.d/40inputattach resume suspend: success.
Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend:
/etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00powersave resume suspend:
/usr/lib/pm-utils/sleep.d/00powersave resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00logging resume suspend:
/usr/lib/pm-utils/sleep.d/00logging resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/000record-status resume suspend:
/usr/lib/pm-utils/sleep.d/000record-status resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/000kernel-change resume suspend:
/usr/lib/pm-utils/sleep.d/000kernel-change resume suspend: success.
Mon May 21 08:16:03 UTC 2018: Finished.
