I get the following compiler messages
nvfortran -c date_module_implementation.f90
NVFORTRAN-S-0074-Illegal number or type of arguments to trim - keyword argument string (date_module_implementation.f90: 179)
NVFORTRAN-S-0146-Expression must be character type (date_module_implementation.f90: 179)
NVFORTRAN-S-0075-Subscript, substring, or argument illegal in this context for month (date_module_implementation.f90: 188)
NVFORTRAN-S-0146-Expression must be character type (date_module_implementation.f90: 188)
NVFORTRAN-S-0146-Expression must be character type (date_module_implementation.f90: 192)
NVFORTRAN-S-0038-Symbol, day, has not been explicitly declared (date_module_implementation.f90)
NVFORTRAN-S-0038-Symbol, month, has not been explicitly declared (date_module_implementation.f90)
0 inform, 0 warnings, 7 severes, 0 fatal for print_date
when trying to compile the following code
submodule (date_module_interface) &
contains
module function &
calendar_to_julian(this) &
result (ival)
implicit none
integer :: ival
class (date), intent (in) :: this
ival = this%day - 32075 + 1461*&
(this%year+ &
4800+(this%month-14)/12)/4 + &
367*(this%month-2-((this%month- &
14)/12)*12)/12 - 3*&
((this%year+4900+(this% &
month-14)/12)/100)/4
end function calendar_to_julian
type (date) module function &
date_constructor(dd, mm, &
yyyy)
implicit none
integer, intent (in) :: dd, mm, yyyy
date_constructor%day = dd
date_constructor%month = mm
date_constructor%year = yyyy
end function date_constructor
integer module function &
date_to_day_in_year(this)
implicit none
intrinsic modulo
date_to_day_in_year = 3055*&
(this%month+2)/ &
100 - (this%month+10)/13*2 - &
91 + &
(1-(modulo(this%year,4)+3)/4+&
(modulo(this% &
year,100)+99)/100-(modulo(this%year, &
400)+399)/400)*(this%month+10)/13 + &
this%day
end function date_to_day_in_year
date_to_weekday_number(this)
implicit none
intrinsic modulo
date_to_weekday_number = modulo((13*( &
this%month+10-&
(this%month+10)/13*12)-1)/5+ &
this%day+77+5*(this%year+(this%month- &
14)/12-(this%year+&
(this%month-14)/12)/100* &
100)/4+(this%year+(this%month- &
14)/12)/400-(this%year+(this%month- &
14)/12)/100*2, 7)
end function date_to_weekday_number
module function get_day(this)
implicit none
integer :: get_day
get_day = this%day
end function get_day
module function get_month(this)
implicit none
integer :: get_month
get_month = this%month
end function get_month
module function get_year(this)
implicit none
integer :: get_year
get_year = this%year
end function get_year
module function julian_to_date(julian)
implicit none
type (date) :: julian_to_date
integer, intent (in) :: julian
integer :: l, n
l = julian + 68569
n = 4*l/146097
l = l - (146097*n+3)/4
julian_to_date%year = (4000*(l+1)/1461001)
l = l - 1461*julian_to_date%year/4 + 31
julian_to_date%month = (80*l/2447)
julian_to_date%day = &
(l-2447*julian_to_date% &
month/80)
l = julian_to_date%month/11
julian_to_date%month = &
(julian_to_date%month &
+2-12*l)
julian_to_date%year = (100*(n-49)+ &
julian_to_date%year+1)
end function julian_to_date
module subroutine &
julian_to_date_and_week_and_day(jd, &
d, wd, ddd)
implicit none
integer, intent (in) :: jd
type (date), intent (out) :: d
integer, intent (out) :: wd, ddd
d = julian_to_date(jd)
wd = date_to_weekday_number(d)
ddd = date_to_day_in_year(d)
end subroutine &
module function ndays(date1, date2)
implicit none
integer :: ndays
class (date), intent (in) :: date1, date2
ndays = calendar_to_julian(date1) - &
calendar_to_julian(date2)
end function ndays
module function &
print_date(this, day_names, &
short_month_name, digits)
implicit none
logical, optional, intent (in) :: &
day_names, &
character (40) :: print_date
integer :: pos
logical :: want_day, &
want_short_month_name, &
want_digits
intrinsic len_trim, present, trim
want_day = .false.
want_short_month_name = .false.
want_digits = .false.
print_date = ' '
if (present(day_names)) then
want_day = day_names
end if
if (present(short_month_name)) then
want_short_month_name = short_month_name
end if
if (present(digits)) then
want_digits = digits
end if
if (want_digits) then
write (print_date(1:2), '(i2)') this%day
print_date(3:3) = '/'
write (print_date(4:5), '(i2)') &
this%month
print_date(6:6) = '/'
write (print_date(7:10), '(i4)') this%year
else
if (want_day) then
pos = date_to_weekday_number(this)
print_date = trim(day(pos)) // ' '
pos = len_trim(print_date) + 2
else
pos = 1
print_date = ' '
end if
write (print_date(pos:pos+1), '(i2)') &
this%day
if (want_short_month_name) then
print_date(pos+3:pos+5) = month(this% &
month)(1:3)
pos = pos + 7
else
print_date(pos+3:) = month(this%month)
end if
write (print_date(pos:pos+3), '(i4)') &
this%year
end if
return
end function print_date
module subroutine set_day(this, d)
implicit none
class (date), intent (inout) :: this
this%day = d
end subroutine set_day
module subroutine set_month(this, m)
implicit none
integer, intent (in) :: m
this%month = m
end subroutine set_month
module subroutine set_year(this, y)
implicit none
integer, intent (in) :: y
this%year = y
end subroutine set_year
module function year_and_day_to_date(year, &
day_in_year)
use day_and_month_name_module
implicit none
type (date) :: year_and_day_to_date
integer, intent (in) :: day_in_year, year
integer :: t
intrinsic modulo
year_and_day_to_date%year = year
t = 0
if (modulo(year,4)==0) then
t = 1
end if
if (modulo(year,400)/=0 .and. &
modulo(year,100)==0) then
t = 0
end if
year_and_day_to_date%day = day_in_year
if (day_in_year>59+t) then
year_and_day_to_date%day = &
year_and_day_to_date%day + 2 - t
end if
year_and_day_to_date%month = &
((year_and_day_to_date%day+91)*100)/3055
year_and_day_to_date%day = ( &
year_and_day_to_date%day+91) - &
(year_and_day_to_date%month*3055)/100
year_and_day_to_date%month - 2
if (year_and_day_to_date%month>=1 .and. &
year_and_day_to_date%month<=12) then
return
end if
write (unit=*, fmt='(a,i11,a)') &
'$$year_and_d&
&ay_to_date: day of the year input &
&=', day_in_year, ' is out of range.'
end function year_and_day_to_date
end submodule date_module_implementation
I assume that this is an incorrect message, as the code compiles and runs with the Nag, Intel, gfortran and Cray compilers.
