Hello, i wanted to share some experience troubleshooting usb issues with my custom jetson carrier board.
I designed custom carrier board for jetson nano, with dual independent usb hubs:
- USB5744 (USB3.0 hub connected to USB1 + USBSS)
- USB2514 (USB2.0 hub connected to USB2)
The issue was that:
On one of the jetson modules (B01) it sometimes worked perfectly, but sometimes during boot process those 2 hubs were not correctly enumerated (BOTH at the same time). So to be clear:
CASE 1 - everything is working both hubs and devices connected to them as well, stable under load
CASE 2 - none of them is enumerated during boot (error -71) -
On two others jetson modules (also B01) it would not boot, or everything works fine
CASE 1 - everything is working fine, both hubs and devices detected
CASE 2 - jetson not boots at all (error: Invalid Oscillator Freq)
My entire board is powered from pololu D24V90F5 step-down which is soldered onboard, and POWER_GOOD signal is used to drive jetson enable logic
Now look at the boot process logs (from UART2 debug port)
[0000.118] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.123] Processing in cold boot mode Bootloader 2
[0000.128] A02 Bootrom Patch rev = 1023
[0000.131] Power-up reason: pmc por
[0000.135] No Battery Present
[0000.137] pmic max77620 reset reason
[0000.141] pmic max77620 NVERC : 0x50
[0000.144] RamCode = 0
[0000.146] Platform has DDR4 type RAM
[0000.150] max77620 disabling SD1 Remote Sense
[0000.154] Setting DDR voltage to 1125mv
[0000.158] Serial Number of Pmic Max77663: 0x609f7
[0000.165] Entering ramdump check
[0000.168] Get RamDumpCarveOut = 0x0
[0000.172] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.177] Last reboot was clean, booting normally!
[0000.181] Sdram initialization is successful
[0000.185] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.192] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.197] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.203] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.209] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.215] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.221] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.226] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.243] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.249] Platform-DebugCarveout: 0
[0000.252] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.258] Non secure mode, and RB not enabled.
[0000.262] Read GPT from (4:0)
[0000.451] Csd NumOfBlocks=124735488
[0000.456] Set High speed to 1
[0000.460] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.470] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.476] Number of retries left 4
[0000.481] Using GPT Primary to query partitions
[0000.486] Loading Tboot-CPU binary
[0000.495] Verifying TBC in OdmNonSecureSBK mode
[0000.505] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.512] Bootloader downloaded successfully.
[0000.517] Downloaded Tboot-CPU binary to 0xa0000258
[0000.522] MAX77620_GPIO5 configured
[0000.525] CPU power rail is up
[0000.528] CPU clock enabled
[0000.532] Performing RAM repair
[0000.534] Updating A64 Warmreset Address to 0xa00002e9
[0000.540] Loading NvTbootBootloaderDTB
[0000.567] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.639] Bootloader DTB Load Address: 0x83000000
[0000.644] Loading NvTbootKernelDTB
[0000.668] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.740] Kernel DTB Load Address: 0x83100000
[0000.744] Loading cboot binary
[0000.773] Verifying EBT in OdmNonSecureSBK mode
[0000.815] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.822] Bootloader downloaded successfully.
[0000.826] Read PT from (2:0)
[0000.842] Using BFS PT to query partitions
[0000.846] PT: Partition NCT NOT found !
[0000.849] Warning: Find Partition via PT Failed
[0000.854] Next binary entry address: 0x92c00258
[0000.858] BoardId: 3448
[0000.863] Overriding pmu board id with proc board id
[0000.868] Display board id is not available
[0000.896] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.950] /bpmp deleted
[0000.952] SC7EntryFw header found loaded at 0xff700000
[0001.151] OVR2 PMIC
[0001.153] Bpmp FW successfully loaded
[0001.157] WB0 init successfully at 0xff780000
[0001.161] Set NvDecSticky Bits
[0001.165] GSC2 address ff53fffc value c0edbbcc
[0001.171] GSC MC Settings done
[0001.174] TOS Image length 53680
[0001.177] Monitor size 53680
[0001.180] OS size 0
[0001.187] Secure Os AES-CMAC Verification Success!
[0001.192] TOS image cipher info: plaintext
[0001.196] Loading and Validation of Secure OS Successful
[0001.211] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.216] NvTbootPackSdramParams: start.
[0001.221] NvTbootPackSdramParams: done.
[0001.225] Tegraboot started after 44812 us
[0001.229] Basic modules init took 848536 us
[0001.233] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.238] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.244] Storage Device Read Time = 108 ms, Read Size = 2226 KB
[0001.250] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.255] Next stage binary read took 24150 us
[0001.259] Carveout took -35834 us
[0001.263] CPU initialization took 373123 us
[0001.267] Total time taken by TegraBoot 1209975 us
[0001.271] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:18:12, Jun 25 2020
ERROR: Error initializing runtime service trusty_fast
[0001.394] RamCode = 0
[0001.398] LPDDR4 Training: Read DT: Number of tables = 2
[0001.403] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.416] EMC Training Successful
[0001.419] 408000 not found in DVFS table
[0001.426] RamCode = 0
[0001.429] DT Write: emc-table@204000 succeeded
[0001.435] DT Write: emc-table@1600000 succeeded
[0001.439] LPDDR4 Training: Write DT: Number of tables = 2
[0001.482]
[0001.484] Debug Init done
[0001.486] Marked DTB cacheable
[0001.489] Bootloader DTB loaded at 0x83000000
[0001.494] Marked DTB cacheable
[0001.497] Kernel DTB loaded at 0x83100000
[0001.501] DeviceTree Init done
[0001.514] Pinmux applied successfully
[0001.518] gicd_base: 0x50041000
[0001.521] gicc_base: 0x50042000
[0001.524] Interrupts Init done
[0001.528] Using base:0x60005090 & irq:208 for tick-timer
[0001.534] Using base:0x60005098 for delay-timer
[0001.538] platform_init_timer: DONE
[0001.542] Timer(tick) Init done
[0001.545] osc freq = 38400 khz
[0001.550]
[0001.551] Welcome to L4T Cboot
[0001.554]
[0001.555] Cboot Version: 00.00.2018.01-t210-3a7ad565
[0001.560] calling constructors
[0001.563] initializing heap
[0001.565] initializing threads
[0001.568] initializing timers
[0001.571] creating bootstrap completion thread
[0001.576] top of bootstrap2()
[0001.578] CPU: ARM Cortex A57
[0001.581] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.586] initializing platform
[0001.594] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.598] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.603] Macronix QSPI chip present
[0001.606] SPI device register
[0001.609] init boot device
[0001.612] allocating memory for boot device(SPI)
[0001.616] registering boot device
[0001.626] sdmmc node status = okay
[0001.629] sdcard instance = 0
[0001.632] sdcard gpio handle 0x56
[0001.635] sdcard gpio pin 0xc9
[0001.638] sdcard gpio flags 0x0
[0001.641] vmmc-supply 0x99
[0001.644] Instance: 0
[0001.646] Allocating memory for context
[0001.650] enabling clock
[0001.652] sd card init
[0001.654] Check card present and stable
[0001.658] Send command 0
[0001.683] Send command 3
[0001.687] Set RCA for the card
[0001.690] Query card specific data by command 9
[0001.696] Parse CSD data
[0001.699] Send command 7
[0001.709] Calling sd device register
[0001.712] Init sdcard
[0001.715] Allocating memory for boot device
[0001.719] Registering user device
[0001.732] Enable APE clock
[0001.735] Un-powergate APE partition
[0001.738] of_register: registering tegra_udc to of_hal
[0001.743] of_register: registering inv20628-driver to of_hal
[0001.749] of_register: registering ads1015-driver to of_hal
[0001.754] of_register: registering lp8557-bl-driver to of_hal
[0001.760] of_register: registering bq2419x_charger to of_hal
[0001.766] of_register: registering bq27441_fuel_gauge to of_hal
[0001.778] gpio framework initialized
[0001.781] of_register: registering tca9539_gpio to of_hal
[0001.786] of_register: registering tca9539_gpio to of_hal
[0001.792] of_register: registering i2c_bus_driver to of_hal
[0001.797] of_register: registering i2c_bus_driver to of_hal
[0001.803] of_register: registering i2c_bus_driver to of_hal
[0001.808] pmic framework initialized
[0001.812] of_register: registering max77620_pmic to of_hal
[0001.817] regulator framework initialized
[0001.821] of_register: registering tps65132_bl_driver to of_hal
[0001.827] initializing target
[0001.833] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.841] board ID = D78, board SKU = 0
[0001.845] Skipping Z3!
[0001.850] fixed regulator driver initialized
[0001.868] initializing OF layer
[0001.871] NCK carveout not present
[0001.874] Skipping dts_overrides
[0001.878] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.897] I2C Bus Init done
[0001.899] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.910] I2C Bus Init done
[0001.912] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.923] I2C Bus Init done
[0001.925] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.936] I2C Bus Init done
[0001.939] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.949] I2C Bus Init done
[0001.952] of_children_init: Ops found for compatible string maxim,max77620
[0001.962] max77620_init using irq 118
[0001.967] register 'maxim,max77620' pmic
[0001.972] gpio_driver_register: register 'max77620-gpio' driver
[0001.978] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.988] I2C Bus Init done
[0001.992] NCK carveout not present
[0002.003] Find /i2c@7000c000's alias i2c0
[0002.007] get eeprom at 1-a0, size 256, type 0
[0002.016] Find /i2c@7000c500's alias i2c2
[0002.020] get eeprom at 3-a0, size 256, type 0
[0002.024] get eeprom at 3-ae, size 256, type 0
[0002.028] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.034] I2C slave not started
[0002.037] I2C write failed
[0002.039] Writing offset failed
[0002.042] eeprom_init: EEPROM read failed
[0002.046] pm_ids_update: eeprom init failed
[0002.051] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.081] pm_ids_update: The pm board id is 3448-0000-400
[0002.087] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.095] pm_ids_update: pm id update successful
[0002.100] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.105] I2C slave not started
[0002.108] I2C write failed
[0002.111] Writing offset failed
[0002.114] eeprom_init: EEPROM read failed
[0002.118] pm_ids_update: eeprom init failed
[0002.148] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.154] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.162] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.168] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.177] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:63:01
[0002.183] Plugin Manager: Parse ODM data 0x00094000
[0002.194] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.209] Find /i2c@7000c000's alias i2c0
[0002.213] get eeprom at 1-a0, size 256, type 0
[0002.222] Find /i2c@7000c500's alias i2c2
[0002.226] get eeprom at 3-a0, size 256, type 0
[0002.231] get eeprom at 3-ae, size 256, type 0
[0002.235] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.240] I2C slave not started
[0002.243] I2C write failed
[0002.246] Writing offset failed
[0002.249] eeprom_init: EEPROM read failed
[0002.253] pm_ids_update: eeprom init failed
[0002.257] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.287] pm_ids_update: The pm board id is 3448-0000-400
[0002.294] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.301] pm_ids_update: pm id update successful
[0002.305] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.311] I2C slave not started
[0002.314] I2C write failed
[0002.316] Writing offset failed
[0002.319] eeprom_init: EEPROM read failed
[0002.323] pm_ids_update: eeprom init failed
[0002.354] Add serial number:1423619092284 as DT property
[0002.362] Applying platform configs
[0002.369] platform-init is not present. Skipping
[0002.373] calling apps_init()
[0002.393] Found 14 GPT partitions in "sd0"
[0002.397] Proceeding to Cold Boot
[0002.400] starting app android_boot_app
[0002.404] Device state: unlocked
[0002.407] display console init
[0002.416] could not find regulator
[0002.419] hdmi cable connected
[0002.455] DT entry for leds-pwm not found
[0004.430] I2C transfer timeout
[0004.433] I2C write failed
[0004.436] Writing offset failed
[0004.439] could not read edid
[0004.443] tmds-config node not found
[0004.447] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.462] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.470] could not find regulator
[0004.473] could not find regulator
[0004.476] could not find regulator
[0004.505] using default cmu settings
[0004.508] dc_hdmi_enable, starting HDMI initialisation
[0004.515] dc_hdmi_enable, HDMI initialisation complete
[0004.520] list and configure display window
[0004.524] display console init completed
[0004.532] subnode volume_up is not found !
[0004.536] subnode back is not found !
[0004.540] subnode volume_down is not found !
[0004.544] subnode menu is not found !
[0004.548] Gpio keyboard init success
[0004.591] found decompressor handler: lz4-legacy
[0004.606] decompressing blob (type 1)...
[0004.639] load_bmp_blob: panelresolution=480 type=0
[0004.690] decompressor handler not found
[0004.694] load_firmware_blob: Firmware blob loaded, entries=2
[0004.700] -------> se_aes_verify_sbk_clear: 747
[0004.704] se_aes_verify_sbk_clear: Error
[0004.708] bl_battery_charging: connected to external power supply
[0004.716] xusb is supported
[0004.722] error while finding nvidia,portmap
[0005.226] xusb blob version 0 size 124416
[0005.230] firmware size 124416
[0005.234] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0005.241] xhci0: 64 bytes context size, 32-bit DMA
[0005.281] usbus0: 5.0Gbps Super Speed USB v3.0
[0005.301] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0005.951] uhub0: 9 ports with 9 removable, self powered
[0015.281] get polling status timeout
[0015.285] failed to init xhci or no usb device attached
[0015.295] device_query_partition_size: failed to open partition sd0:MSC !
[0015.302] MSC Partition not found
[0015.308] device_query_partition_size: failed to open partition sd0:USP !
[0015.315] USP partition read failed!
[0015.319] blob_init: blob-partition USP header read failed
[0015.324] android_boot Unable to update recovery partition
[0015.330] kfs_getpartname: name = LNX
[0015.333] Loading kernel from LNX
[0015.431] load kernel from storage
[0015.443] decompressor handler not found
[0015.500] Successfully loaded kernel and ramdisk images
[0015.507] load_bmp_blob: panelresolution=480 type=0
[0015.580] display bmp image done
[0015.583] NCK carveout not present
[0015.587] Skipping dts_overrides
[0015.590] NCK carveout not present
[0015.601] Find /i2c@7000c000's alias i2c0
[0015.604] get eeprom at 1-a0, size 256, type 0
[0015.614] Find /i2c@7000c500's alias i2c2
[0015.618] get eeprom at 3-a0, size 256, type 0
[0015.622] get eeprom at 3-ae, size 256, type 0
[0015.626] pm_ids_update: Updating 1,a0, size 256, type 0
[0015.632] I2C slave not started
[0015.635] I2C write failed
[0015.637] Writing offset failed
[0015.640] eeprom_init: EEPROM read failed
[0015.644] pm_ids_update: eeprom init failed
[0015.648] pm_ids_update: Updating 3,a0, size 256, type 0
[0015.678] pm_ids_update: The pm board id is 3448-0000-400
[0015.685] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0015.693] pm_ids_update: pm id update successful
[0015.698] pm_ids_update: Updating 3,ae, size 256, type 0
[0015.703] I2C slave not started
[0015.706] I2C write failed
[0015.709] Writing offset failed
[0015.712] eeprom_init: EEPROM read failed
[0015.716] pm_ids_update: eeprom init failed
[0015.746] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0015.752] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0015.760] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0015.766] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0015.775] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:63:01
[0015.781] Plugin Manager: Parse ODM data 0x00094000
[0015.792] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0015.800] Add serial number:1423619092284 as DT property
[0015.809] "bpmp" doesn't exist, creating
[0015.815] Updated bpmp info to DTB
[0015.820] Updated initrd info to DTB
[0015.823] "proc-board" doesn't exist, creating
[0015.829] Updated board info to DTB
[0015.832] "pmu-board" doesn't exist, creating
[0015.838] Updated board info to DTB
[0015.841] "display-board" doesn't exist, creating
[0015.847] Updated board info to DTB
[0015.850] "reset" doesn't exist, creating
[0015.855] Updated reset info to DTB
[0015.858] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0015.897] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0015.903] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0015.916] Updated bootarg info to DTB
[0015.919] Adding uuid 00000001644612841400000016fc0340 to DT
[0015.925] Adding eks info 0 to DT
[0015.931] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0015.937] Updated memory info to DTB
[0015.946] set vdd_core voltage to 1125 mv
[0015.950] setting 'vdd-core' regulator to 1125000 micro volts
[0023.891] failed to get HID devices
[0023.911] Found secure-pmc; disable BPMP
U-Boot 2016.07-ge6da093be3 (Jun 25 2020 - 21:18:08 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
852 bytes read in 132 ms (5.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd.img
19993314 bytes read in 1140 ms (16.7 MiB/s)
Retrieving file: /boot/Image
34322440 bytes read in 1537 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317d857
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (jetson@jetson-desktop) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #3 SMP PREEMPT Wed Jan 27 11:41:26 CET 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb0000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 1.776962] csx307 7-003b: cs_imx307_board_setup: error during i2c read probe (-121)
[ 1.784793] csx307 7-003b: board setup failed
[ 1.789943] csx307 8-003b: cs_imx307_board_setup: error during i2c read probe (-121)
[ 1.797731] csx307 8-003b: board setup failed
[ 11.634026] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.640477] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 11.647178] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 11.652315] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.659012] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.664582] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.670412] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 11.675634] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 11.680971] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 11.688758] tegradc tegradc.1: dpd enable lookup fail:-19
[ 13.360813] cgroup: cgroup2: unknown option "nsdelegate"
[ 13.945998] usb 1-2: device not accepting address 2, error -71
[ 14.130287] usb 1-2: Device not responding to setup address.
[ 14.342234] usb 1-2: Device not responding to setup address.
[ 14.554001] usb 1-2: device not accepting address 3, error -71
[ 14.978642] random: crng init done
[ 14.982049] random: 7 urandom warning(s) missed due to ratelimiting
[ 15.688223] using random self ethernet address
[ 15.692701] using random host ethernet address
[ 16.482111] usb 1-2: device descriptor read/64, error -71
[ 16.650177] using random self ethernet address
[ 16.658052] using random host ethernet address
[ 16.774127] usb 1-2: device descriptor read/64, error -71
[ 17.250114] usb 1-2: device descriptor read/64, error -71
[ 17.443567] ------------[ cut here ]------------
[ 17.448195] WARNING: CPU: 3 PID: 2675 at /home/jetson/l4t-gcc/Linux_for_Tegra/source/public/kernel/kernel-4.9/kernel/jump_label.c:151 __static_key_slow_dec+0xa8/0xb0
[ 17.463088] ---[ end trace 0720df7e0406dd1c ]---
[ 17.542254] usb 1-2: device descriptor read/64, error -71
[ 17.654087] usb usb1-port2: unable to enumerate USB device
[ 17.922271] usb 1-3: Device not responding to setup address.
[ 18.134283] usb 1-3: Device not responding to setup address.
[ 18.345993] usb 1-3: device not accepting address 6, error -71
[ 18.530415] usb 1-3: Device not responding to setup address.
[ 18.742322] usb 1-3: Device not responding to setup address.
[ 18.954029] usb 1-3: device not accepting address 7, error -71
Ubuntu 18.04.4 LTS localhost ttyS0
localhost login: jetson
Password:
Last login: Fri Mar 26 13:11:32 UTC 2021 on ttyS0
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.9.140-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
383 packages can be updated.
266 updates are security updates.
[ 19.480532] edid invalid
[ 20.883926] usb 1-3: device descriptor read/64, error -71
[ 21.174296] usb 1-3: device descriptor read/64, error -71
[ 21.646214] usb 1-3: device descriptor read/64, error -71
[ 21.874712] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.874754] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 21.874795] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 21.874828] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.874862] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.874894] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.874928] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 21.874961] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 21.875046] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 21.935487] usb 1-3: device descriptor read/64, error -71
[ 22.042980] usb usb1-port3: unable to enumerate USB device
[ 32.114584] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 32.114620] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 32.114656] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 32.114685] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 32.114714] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 32.114744] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 32.114776] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 32.114806] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 32.114893] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
jetson@linux:~$ lsusb
Bus 002 Device 002: ID 0424:5744 Standard Microsystems Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jetson@linux:~$ lsusb -v
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.20
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x5744
bcdDevice 2.21
iManufacturer 2
iProduct 3
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 19
Transfer Type Interrupt
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 8
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 4.09
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 4.09
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
jetson@linux:~$ [ 42.354103] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 42.360606] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 42.367355] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 42.372537] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 42.379359] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 42.384964] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 42.390859] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 42.396106] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 42.401451] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
I noticed that jetson hangs for few seconds here:
[0015.950] setting ‘vdd-core’ regulator to 1125000 micro volts
Whereas when everything is working fine it goes smoothly:
[0009.899] set vdd_core voltage to 1125 mv
[0009.903] setting ‘vdd-core’ regulator to 1125000 micro volts
[0009.925] Found secure-pmc; disable BPMP
The other jetsons that fail to boot:
[0001.322] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:23:48, Oct 16 2020
[0001.444] RamCode = 0
[0001.449] LPDDR4 Training: Read DT: Number of tables = 2
[0001.454] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.467] EMC Training Successful
[0001.470] 408000 not found in DVFS table
[0001.476] RamCode = 0
[0001.480] DT Write: emc-table@204000 succeeded
[0001.485] DT Write: emc-table@1600000 succeeded
[0001.489] LPDDR4 Training: Write DT: Number of tables = 2
[0001.534]
[0001.535] Debug Init done
[0001.538] Marked DTB cacheable
[0001.541] Bootloader DTB loaded at 0x83000000
[0001.545] Marked DTB cacheable
[0001.548] Kernel DTB loaded at 0x83100000
[0001.552] DeviceTree Init done
[0001.565] Pinmux applied successfully
[0001.569] gicd_base: 0x50041000
[0001.573] gicc_base: 0x50042000
[0001.576] Interrupts Init done
[0001.580] Using base:0x60005090 & irq:208 for tick-timer
[0001.585] Using base:0x60005098 for delay-timer
[0001.590] platform_init_timer: DONE
[0001.593] Timer(tick) Init done
[0001.597] osc freq = 38400 khz
[0001.601]
[0001.602] Welcome to L4T Cboot
[0001.605]
[0001.606] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.611] calling constructors
[0001.614] initializing heap
[0001.617] initializing threads
[0001.620] initializing timers
[0001.622] creating bootstrap completion thread
[0001.627] top of bootstrap2()
[0001.630] CPU: ARM Cortex A57
[0001.633] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.637] initializing platform
[0001.645] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.649] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.654] Macronix QSPI chip present
[0001.657] SPI device register
[0001.660] init boot device
[0001.663] allocating memory for boot device(SPI)
[0001.667] registering boot device
[0001.677] sdmmc node status = okay
[0001.680] sdcard instance = 0
[0001.683] sdcard gpio handle 0x5b
[0001.686] sdcard gpio pin 0xc9
[0001.689] sdcard gpio flags 0x0
[0001.692] vmmc-supply 0x9e
[0001.695] Instance: 0
[0001.697] Allocating memory for context
[0001.701] enabling clock
[0001.703] sd card init
[0001.705] Check card present and stable
[0001.709] Send command 0
[0001.733] Send command 3
[0001.738] Set RCA for the card
[0001.741] Query card specific data by command 9
[0001.747] Parse CSD data
[0001.749] Send command 7
[0001.760] Calling sd device register
[0001.763] Init sdcard
[0001.765] Allocating memory for boot device
[0001.770] Registering user device
[0001.783] Enable APE clock
[0001.785] Un-powergate APE partition
[0001.789] of_register: registering tegra_udc to of_hal
[0001.794] of_register: registering inv20628-driver to of_hal
[0001.800] of_register: registering ads1015-driver to of_hal
[0001.805] of_register: registering lp8557-bl-driver to of_hal
[0001.811] of_register: registering bq2419x_charger to of_hal
[0001.817] of_register: registering bq27441_fuel_gauge to of_hal
[0001.828] gpio framework initialized
[0001.832] of_register: registering tca9539_gpio to of_hal
[0001.837] of_register: registering tca9539_gpio to of_hal
[0001.842] of_register: registering i2c_bus_driver to of_hal
[0001.848] of_register: registering i2c_bus_driver to of_hal
[0001.853] of_register: registering i2c_bus_driver to of_hal
[0001.859] pmic framework initialized
[0001.862] of_register: registering max77620_pmic to of_hal
[0001.868] regulator framework initialized
[0001.872] of_register: registering tps65132_bl_driver to of_hal
[0001.878] initializing target
[0001.884] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.892] board ID = D78, board SKU = 0
[0001.895] Skipping Z3!
[0001.900] fixed regulator driver initialized
[0001.918] initializing OF layer
[0001.921] NCK carveout not present
[0001.924] Skipping dts_overrides
[0001.928] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.945] I2C Bus Init done
[0001.948] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.958] I2C Bus Init done
[0001.961] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.971] I2C Bus Init done
[0001.974] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.984] I2C Bus Init done
[0001.987] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.997] I2C Bus Init done
[0002.000] of_children_init: Ops found for compatible string maxim,max77620
[0002.010] max77620_init using irq 118
[0002.015] register 'maxim,max77620' pmic
[0002.020] gpio_driver_register: register 'max77620-gpio' driver
[0002.026] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.036] I2C Bus Init done
[0002.040] NCK carveout not present
[0002.050] Find /i2c@7000c000's alias i2c0
[0002.054] get eeprom at 1-a0, size 256, type 0
[0002.062] Find /i2c@7000c500's alias i2c2
[0002.066] get eeprom at 3-a0, size 256, type 0
[0002.071] get eeprom at 3-ae, size 256, type 0
[0002.075] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.080] I2C slave not started
[0002.083] I2C write failed
[0002.086] Writing offset failed
[0002.089] eeprom_init: EEPROM read failed
[0002.093] pm_ids_update: eeprom init failed
[0002.097] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.127] pm_ids_update: The pm board id is 3448-0000-400
[0002.134] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.142] pm_ids_update: pm id update successful
[0002.147] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.152] I2C slave not started
[0002.155] I2C write failed
[0002.158] Writing offset failed
[0002.161] eeprom_init: EEPROM read failed
[0002.165] pm_ids_update: eeprom init failed
[0002.195] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.201] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.209] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.214] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.223] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:0d:a7
[0002.229] Plugin Manager: Parse ODM data 0x00094000
[0002.241] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.256] Find /i2c@7000c000's alias i2c0
[0002.260] get eeprom at 1-a0, size 256, type 0
[0002.269] Find /i2c@7000c500's alias i2c2
[0002.273] get eeprom at 3-a0, size 256, type 0
[0002.277] get eeprom at 3-ae, size 256, type 0
[0002.282] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.287] I2C slave not started
[0002.290] I2C write failed
[0002.293] Writing offset failed
[0002.296] eeprom_init: EEPROM read failed
[0002.300] pm_ids_update: eeprom init failed
[0002.304] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.334] pm_ids_update: The pm board id is 3448-0000-400
[0002.340] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.347] pm_ids_update: pm id update successful
[0002.352] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.357] I2C slave not started
[0002.360] I2C write failed
[0002.363] Writing offset failed
[0002.366] eeprom_init: EEPROM read failed
[0002.370] pm_ids_update: eeprom init failed
[0002.399] Add serial number:1423119072463 as DT property
[0000.120] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.126] Processing in cold boot mode Bootloader 2
[0000.130] A02 Bootrom Patch rev = 1023
[0000.134] Power-up reason: pmc por
[0000.137] No Battery Present
[0000.140] pmic max77620 reset reason
[0000.143] pmic max77620 NVERC : 0x50
[0000.146] RamCode = 0
[0000.149] Platform has DDR4 type RAM
[0000.152] max77620 disabling SD1 Remote Sense
[0000.156] Setting DDR voltage to 1125mv
[0000.160] Serial Number of Pmic Max77663: 0x1e1df9
[0000.168] Entering ramdump check
[0000.171] Get RamDumpCarveOut = 0x0
[0000.174] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.179] Last reboot was clean, booting normally!
[0000.184] Sdram initialization is successful
[0000.188] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.194] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.200] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.206] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.211] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.217] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.223] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.229] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.245] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.251] Platform-DebugCarveout: 0
[0000.254] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.260] Non secure mode, and RB not enabled.
[0000.264] Read GPT from (4:0)
[0000.453] Csd NumOfBlocks=124735488
[0000.458] Set High speed to 1
[0000.461] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.472] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.478] Number of retries left 4
[0000.487] Using GPT Primary to query partitions
[0000.492] Loading Tboot-CPU binary
[0000.517] Verifying TBC in OdmNonSecureSBK mode
[0000.527] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.534] Bootloader downloaded successfully.
[0000.538] Downloaded Tboot-CPU binary to 0xa0000258
[0000.543] MAX77620_GPIO5 configured
[0000.546] CPU power rail is up
[0000.549] Invalid Oscillator Freq
[0000.552]
Assert on NvTbootGetOscFreqKhz:104: 0
[0000.557]
Assert on NvTbootInitPllX:199: OscFreqKhz
My guess is that my very simplified power logic enables jetson before power had stabilized inside module and that’s why it hangs on ‘vdd-core’ setting.
My temporary solution that appears to be working:
I desoldered AND gate from my board, supplied power, and then manually enabe jetson by shorting POWER_EN wire to +5V. This ensures that power everywere on board is stable and then boot proces begins.
