[0000.200] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.205] Processing in cold boot mode Bootloader 2
[0000.210] A02 Bootrom Patch rev = 1023
[0000.213] Power-up reason: pmc por
[0000.217] No Battery Present
[0000.219] pmic max77620 reset reason
[0000.223] pmic max77620 NVERC : 0x40
[0000.226] RamCode = 0
[0000.228] Platform has DDR4 type RAM
[0000.232] max77620 disabling SD1 Remote Sense
[0000.236] Setting DDR voltage to 1125mv
[0000.240] Serial Number of Pmic Max77663: 0x291c64
[0000.247] Entering ramdump check
[0000.250] Get RamDumpCarveOut = 0x0
[0000.254] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.259] Last reboot was clean, booting normally!
[0000.263] Sdram initialization is successful
[0000.267] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.274] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.279] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.285] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.291] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.297] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.303] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.309] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.325] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.331] Platform-DebugCarveout: 0
[0000.334] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.340] Non secure mode, and RB not enabled.
[0000.344] *** Booting BFS0.
[0000.347] Initialize FailControl
[0000.350] Read PT from (0:3)
[0000.365] Csd NumOfBlocks=0
[0000.404] PT crc32 and magic check passed.
[0000.408] Using BFS PT to query partitions
[0000.412] PT: Partition LNX NOT found !
[0000.416] *** Booting KFS0.
[0000.418] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.424] BoardID = 3448, SKU = 0x2
[0000.428] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.433] Read GPT from (0:3)
[0000.441] Using GPT Primary to query partitions
[0000.446] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.453] Loading Tboot-CPU binary
[0000.458] Verifying TBC in OdmNonSecureSBK mode
[0000.468] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.475] Bootloader downloaded successfully.
[0000.479] Downloaded Tboot-CPU binary to 0xa0000258
[0000.485] MAX77620_GPIO5 configured
[0000.488] CPU power rail is up
[0000.491] CPU clock enabled
[0000.494] Performing RAM repair
[0000.497] Updating A64 Warmreset Address to 0xa00002e9
[0000.502] BoardID = 3448, SKU = 0x2
[0000.506] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.512] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.518] Loading NvTbootBootloaderDTB
[0000.535] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.606] Bootloader DTB Load Address: 0x83000000
[0000.611] BoardID = 3448, SKU = 0x2
[0000.614] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.620] Loading NvTbootKernelDTB
[0000.637] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.708] Kernel DTB Load Address: 0x83100000
[0000.712] BoardID = 3448, SKU = 0x2
[0000.715] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.721] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.729] Loading cboot binary
[0000.739] Verifying EBT in OdmNonSecureSBK mode
[0000.781] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.788] Bootloader downloaded successfully.
[0000.792] BoardID = 3448, SKU = 0x2
[0000.795] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.801] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.808] PT: Partition NCT NOT found !
[0000.811] Warning: Find Partition via PT Failed
[0000.816] Next binary entry address: 0x92c00258
[0000.820] BoardId: 3448
[0000.825] Overriding pmu board id with proc board id
[0000.829] Display board id is not available
[0000.834] BoardID = 3448, SKU = 0x2
[0000.837] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.843] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.856] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.912] /bpmp deleted
[0000.915] SC7EntryFw header found loaded at 0xff700000
[0001.103] OVR2 PMIC
[0001.105] Bpmp FW successfully loaded
[0001.108] BoardID = 3448, SKU = 0x2
[0001.111] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.117] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.124] WB0 init successfully at 0xff780000
[0001.129] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.134] Set NvDecSticky Bits
[0001.137] GSC2 address ff53fffc value c0edbbcc
[0001.144] GSC MC Settings done
[0001.146] BoardID = 3448, SKU = 0x2
[0001.150] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.156] TOS Image length 53680
[0001.159] Monitor size 53680
[0001.162] OS size 0
[0001.168] Secure Os AES-CMAC Verification Success!
[0001.172] TOS image cipher info: plaintext
[0001.176] Loading and Validation of Secure OS Successful
[0001.192] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.197] NvTbootPackSdramParams: start.
[0001.202] NvTbootPackSdramParams: done.
[0001.206] Tegraboot started after 128725 us
[0001.210] Basic modules init took 741286 us
[0001.214] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.219] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.225] Next stage binary read took 7376 us
[0001.229] Carveout took -34771 us
[0001.232] CPU initialization took 392217 us
[0001.236] Total time taken by TegraBoot 1106108 us
[0001.241] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 14:22:20, Apr 20 2022
ERROR: Error initializing runtime service trusty_fast
[0001.363] RamCode = 0
[0001.367] LPDDR4 Training: Read DT: Number of tables = 2
[0001.372] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.385] EMC Training Successful
[0001.388] 408000 not found in DVFS table
[0001.395] RamCode = 0
[0001.398] DT Write: emc-table@204000 succeeded
[0001.403] DT Write: emc-table@1600000 succeeded
[0001.408] LPDDR4 Training: Write DT: Number of tables = 2
[0001.450]
[0001.451] Debug Init done
[0001.454] Marked DTB cacheable
[0001.457] Bootloader DTB loaded at 0x83000000
[0001.462] Marked DTB cacheable
[0001.465] Kernel DTB loaded at 0x83100000
[0001.469] DeviceTree Init done
[0001.482] Pinmux applied successfully
[0001.486] gicd_base: 0x50041000
[0001.489] gicc_base: 0x50042000
[0001.492] Interrupts Init done
[0001.497] Using base:0x60005090 & irq:208 for tick-timer
[0001.502] Using base:0x60005098 for delay-timer
[0001.506] platform_init_timer: DONE
[0001.510] Timer(tick) Init done
[0001.513] osc freq = 38400 khz
[0001.517]
[0001.518] Welcome to L4T Cboot
[0001.521]
[0001.523] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.527] calling constructors
[0001.530] initializing heap
[0001.533] initializing threads
[0001.536] initializing timers
[0001.539] creating bootstrap completion thread
[0001.543] top of bootstrap2()
[0001.546] CPU: ARM Cortex A57
[0001.549] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.554] initializing platform
[0001.607] Config for emmc ddr50 mode completed
[0001.612] sdmmc bdev is already initialized
[0001.616] Enable APE clock
[0001.618] Un-powergate APE partition
[0001.622] of_register: registering tegra_udc to of_hal
[0001.627] of_register: registering inv20628-driver to of_hal
[0001.633] of_register: registering ads1015-driver to of_hal
[0001.638] of_register: registering lp8557-bl-driver to of_hal
[0001.644] of_register: registering bq2419x_charger to of_hal
[0001.650] of_register: registering bq27441_fuel_gauge to of_hal
[0001.661] gpio framework initialized
[0001.665] of_register: registering tca9539_gpio to of_hal
[0001.670] of_register: registering tca9539_gpio to of_hal
[0001.675] of_register: registering i2c_bus_driver to of_hal
[0001.681] of_register: registering i2c_bus_driver to of_hal
[0001.686] of_register: registering i2c_bus_driver to of_hal
[0001.692] pmic framework initialized
[0001.695] of_register: registering max77620_pmic to of_hal
[0001.701] regulator framework initialized
[0001.705] of_register: registering tps65132_bl_driver to of_hal
[0001.711] initializing target
[0001.717] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.725] board ID = D78, board SKU = 2
[0001.731] fixed regulator driver initialized
[0001.749] initializing OF layer
[0001.752] NCK carveout not present
[0001.755] Skipping dts_overrides
[0001.759] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.776] I2C Bus Init done
[0001.778] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.789] I2C Bus Init done
[0001.791] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.802] I2C Bus Init done
[0001.804] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.815] I2C Bus Init done
[0001.817] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.828] I2C Bus Init done
[0001.830] of_children_init: Ops found for compatible string maxim,max77620
[0001.841] max77620_init using irq 118
[0001.845] register 'maxim,max77620' pmic
[0001.850] gpio_driver_register: register 'max77620-gpio' driver
[0001.856] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.866] I2C Bus Init done
[0001.870] NCK carveout not present
[0001.879] Find /i2c@7000c000's alias i2c0
[0001.883] get eeprom at 1-a0, size 256, type 0
[0001.892] Find /i2c@7000c500's alias i2c2
[0001.896] get eeprom at 3-a0, size 256, type 0
[0001.900] get eeprom at 3-ae, size 256, type 0
[0001.905] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.910] I2C slave not started
[0001.913] I2C write failed
[0001.916] Writing offset failed
[0001.919] eeprom_init: EEPROM read failed
[0001.923] pm_ids_update: eeprom init failed
[0001.927] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.957] pm_ids_update: The pm board id is 3448-0002-401
[0001.964] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0001.972] pm_ids_update: pm id update successful
[0001.977] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.007] eeprom_init: EEPROM incompatible version found
[0002.012] pm_ids_update: eeprom init failed
[0002.042] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.048] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.056] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.061] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.070] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:45:77
[0002.076] Plugin Manager: Parse ODM data 0x000a4000
[0002.088] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.103] Find /i2c@7000c000's alias i2c0
[0002.107] get eeprom at 1-a0, size 256, type 0
[0002.116] Find /i2c@7000c500's alias i2c2
[0002.119] get eeprom at 3-a0, size 256, type 0
[0002.124] get eeprom at 3-ae, size 256, type 0
[0002.128] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.133] I2C slave not started
[0002.136] I2C write failed
[0002.139] Writing offset failed
[0002.142] eeprom_init: EEPROM read failed
[0002.146] pm_ids_update: eeprom init failed
[0002.150] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.180] pm_ids_update: The pm board id is 3448-0002-401
[0002.187] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.193] pm_ids_update: pm id update successful
[0002.198] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.228] eeprom_init: EEPROM incompatible version found
[0002.233] pm_ids_update: eeprom init failed
[0002.263] Add serial number:1425121062156 as DT property
[0002.271] Applying platform configs
[0002.277] platform-init is not present. Skipping
[0002.282] calling apps_init()
[0002.303] Found 17 GPT partitions in "sdmmc3_user"
[0002.308] Proceeding to Cold Boot
[0002.311] starting app android_boot_app
[0002.315] Device state: unlocked
[0002.318] display console init
[0002.326] could not find regulator
[0002.350] hdmi cable not connected
[0002.353] is_hdmi_needed: HDMI not connected, returning false
[00[0002.362] DT entry for leds-pwm not found
02.359] hdmi is not connected
[0002.369] sor0 is not supported
[0002.372] display_console_init: no valid display out_type
[0002.380] subnode volume_up is not found !
[0002.384] subnode back is not found !
[0002.387] subnode volume_down is not found !
[0002.391] subnode menu is not found !
[0002.395] Gpio keyboard init success
[0002.442] found decompressor handler: lz4-legacy
[0002.457] decompressing blob (type 1)...
[0002.523] display_resolution: No display init
[0002.527] Failed to retrieve display resolution
[0002.532] Could not load/initialize BMP blob...ignoring
[0002.537] -------> se_aes_verify_sbk_clear: 747
[0002.541] se_aes_verify_sbk_clear: Error
[0002.545] SE operation failed
[0002.548] bl_battery_charging: connected to external power supply
[0002.557] display_console_ioctl: No display init
[0002.562] switch_backlight failed
[0002.571] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.579] MSC Partition not found
[0002.588] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.596] USP partition read failed!
[0002.599] blob_init: blob-partition USP header read failed
[0002.605] android_boot Unable to update recovery partition
[0002.610] kfs_getpartname: name = LNX
[0002.614] Loading kernel from LNX
[0002.712] load kernel from storage
[0002.721] decompressor handler not found
[0002.755] Successfully loaded kernel and ramdisk images
[0002.760] board ID = D78, board SKU = 2
[0002.765] display_resolution: No display init
[0002.769] Failed to retrieve display resolution
[0002.774] bmp blob is not loaded and initialized
[0002.778] Failed to display boot-logo
[0002.782] NCK carveout not present
[0002.785] Skipping dts_overrides
[0002.788] NCK carveout not present
[0002.798] Find /i2c@7000c000's alias i2c0
[0002.802] get eeprom at 1-a0, size 256, type 0
[0002.810] Find /i2c@7000c500's alias i2c2
[0002.814] get eeprom at 3-a0, size 256, type 0
[0002.819] get eeprom at 3-ae, size 256, type 0
[0002.823] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.828] I2C slave not started
[0002.831] I2C write failed
[0002.834] Writing offset failed
[0002.837] eeprom_init: EEPROM read failed
[0002.841] pm_ids_update: eeprom init failed
[0002.845] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.875] pm_ids_update: The pm board id is 3448-0002-401
[0002.882] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.890] pm_ids_update: pm id update successful
[0002.895] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.925] eeprom_init: EEPROM incompatible version found
[0002.930] pm_ids_update: eeprom init failed
[0002.960] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.966] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.974] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.980] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.988] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:45:77
[0002.994] Plugin Manager: Parse ODM data 0x000a4000
[0003.007] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.015] Add serial number:1425121062156 as DT property
[0003.024] "bpmp" doesn't exist, creating
[0003.029] Updated bpmp info to DTB
[0003.034] Updated initrd info to DTB
[0003.038] "proc-board" doesn't exist, creating
[0003.044] Updated board info to DTB
[0003.047] "pmu-board" doesn't exist, creating
[0003.053] Updated board info to DTB
[0003.056] "display-board" doesn't exist, creating
[0003.062] Updated board info to DTB
[0003.066] "reset" doesn't exist, creating
[0003.070] Updated reset info to DTB
[0003.074] display_console_ioctl: No display init
[0003.078] display_console_ioctl: No display init
[0003.083] display_console_ioctl: No display init
[0003.087] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.122] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.127] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.144] Updated bootarg info to DTB
[0003.148] Adding uuid 000000016431b6c60000000004020340 to DT
[0003.154] Adding eks info 0 to DT
[0003.159] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.165] Updated memory info to DTB
[0003.173] set vdd_core voltage to 1125 mv
[0003.177] setting 'vdd-core' regulator to 1125000 micro volts
[0003.182] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Apr 20 2022 - 14:22:25 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1154 bytes read in 23 ms (48.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160179 bytes read in 174 ms (39.2 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 781 ms (42.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ce8d
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Apr 20 14:25:12 PDT 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 1.147454] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.251422] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.259293] imx219 7-0010: board setup failed
[ 1.287854] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.287969] imx219 8-0010: board setup failed
[ 1.638131] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.131136] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.138103] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.815730] using random self ethernet address
[ 2.820666] using random host ethernet address
[ 3.196936] random: crng init done
[ 3.200369] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.412121] using random self ethernet address
[ 3.424241] using random host ethernet address
[ 4.961394] Bridge firewalling registered
Ubuntu 18.04.6 LTS jetsonnano-desktop ttyS0
jetsonnano-desktop login:
