I initialize two actors and set their center of mass like that:
actor1 = thePhysics->createRigidDynamic(
physx::PxTransform(0.0,3.0,0.0,physx::PxQuat(physx::PxIdentity)));
actor1->setMass(25.0);
actor1->setCMassLocalPose(physx::PxTransform(physx::PxVec3(0.295, 0.0, 0.0)));
actor2 = thePhysics->createRigidDynamic(
actor2->setMass(14.0);
actor2->setCMassLocalPose(physx::PxTransform(physx::PxVec3(0.424, 0.0, 0.0)));
Than I create a prismatic joint between them:
physx::PxPrismaticJointCreate(*thePhysics, actor1, physx::PxTransform(0.0, 0.0, 0.0, physx::PxQuat(physx::PxIdentity)), actor2, physx::PxTransform(0.0, 0.0, 0.0, physx::PxQuat(physx::PxIdentity)));
If I start the simulation the joint position has in the first frame a value of 0.129 but the joint coordinate frames of both actors are exactly on the same position. If I don’t set the center of mass the joint position is 0.0 like I expect it.
Is there something that I do wrong? How I get the right value for the joint position?
