Dear all, nice to meet you. How’s it going ?
When I did install the linux OS in my personal computer, my GPU GTX 1060 stoped be recognized by the computer hardware. Before I used Windows 10.
I tried to install the driver using root, but the following error appeared:
ERROR: An NVIDIA kernel module ‘nvidia-drm’ appears to already be loaded in
your kernel. This may be because it is in use (for example, by an X
server, a CUDA program, or the NVIDIA Persistence Daemon), but this
may also happen if your kernel was configured without support for
module unloading. Please be sure to exit any programs that may be
using the GPU(s) before attempting to upgrade your driver. If no
GPU-based programs are running, you know that your kernel supports
module unloading, and you still receive this message, then an error
may have occured that has corrupted an NVIDIA kernel module’s usage
count, for which the simplest remedy is to reboot your computer.
There is no software using my GPU and I have already restarted the computer.
Can you help me ?
Thanks !
