Trying to build the TensorRT OSS using the build container =
Example: Ubuntu 20.04 on x86-64 with cuda-11.6.2 (default)
leads to a problem with NGC
git clone -b master https://github.com/nvidia/TensorRT TensorRT
cd TensorRT
git submodule update --init --recursive
sudo ./docker/build.sh --file docker/ubuntu-20.04.Dockerfile --tag tensorrt-ubuntu20.04-cuda11.6
results in this problem:
inflating: ngc-cli/boto3/data/cloudformation/2010-05-15/resources-1.json
creating: ngc-cli/boto3/data/dynamodb/
creating: ngc-cli/boto3/data/dynamodb/2012-08-10/
inflating: ngc-cli/boto3/data/dynamodb/2012-08-10/resources-1.json
creating: ngc-cli/boto3/data/sqs/
creating: ngc-cli/boto3/data/sqs/2012-11-05/
inflating: ngc-cli/boto3/data/sqs/2012-11-05/resources-1.json
creating: ngc-cli/boto3/data/s3/
creating: ngc-cli/boto3/data/s3/2006-03-01/
inflating: ngc-cli/boto3/data/s3/2006-03-01/resources-1.json
inflating: ngc-cli/libssl.so.10
creating: ngc-cli/frozenlist/
inflating: ngc-cli/frozenlist/_frozenlist.cpython-39-x86_64-linux-gnu.so
extracting: ngc-cli.md5
chmod: cannot access 'ngc': No such file or directory
The command '/bin/bash -c cd /usr/local/bin && wget https://ngc.nvidia.com/downloads/ngccli_cat_linux.zip && unzip ngccli_cat_linux.zip && chmod u+x ngc && rm ngccli_cat_linux.zip ngc.md5 && echo "no-apikey\nascii\n" | ngc config set' returned a non-zero code: 1
Environment
Dell Server with an A2 GPU.
TensorRT Version:
8.2.1.5
Nvidia Driver Version: 510.47.03
CUDA Version: 11.6
Operating System + Version: Ubuntu 20.04
Steps To Reproduce
From https://github.com/NVIDIA/TensorRT/blob/main/README.md
Generate the TensorRT-OSS build container.
The TensorRT-OSS build container can be generated using the supplied Dockerfiles and build script. The build container is configured for building TensorRT OSS out-of-the-box.
cd TensorRT
