I use Gstreamer play an IPC camera.
Command is
gst-launch-1.0 -v rtspsrc location=rtsp://admin:admin123@192.168.1.43/avstream/channel=1/stream=0.sdp ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink
But it has 4~5 seconds delay. And the NVDEC is worked at 128M.
When I use ffplay without NVDEC, it has 1~2 seconds delay.
ffplay rtsp://admin:admin123@192.168.1.43/avstream/channel=1/stream=0.sdp
Why?
Please try to set the property in rtspsrc:
latency : Amount of ms to buffer
flags: readable, writable
Unsigned Integer. Range: 0 - 4294967295 Default: 2000
and the property in nvv4l2decoder:
enable-max-performance: Set to enable max performance
Boolean. Default: false
Thanks DaneLLL,
After adding these two property, the delay decreased and NVDEC worked at 857M.
But there is still a delay of 2 seconds, which is similar to the delay without using NVDEC.
Is there any other way to lower the delay?
The delay may be from the source or network. Please try UDP and see how much latency it is for comparison.
I tested using both FFmpeg (without nvdec) and gstreamer (with nvdec) using Python code, and the delay was reduced to around 400ms. So, without considering CPU usage, the efficiency of CPU software decoding and hardware decoding is similar. Can we understand it this way?
Please enable the property and try:
disable-dpb : Set to disable DPB buffer for low latency
By default decoder will output frames in display order and decoded frame are queued. Please disable it and see if there is further improvement.
After enable the property, the delay has been reduced to 200ms. Thank you very much!
