For information, is your host PC in Ubuntu 18.04 or 20.04? Would like to know which Ubuntu version you are using.
The source sync list on my side is this one.
62 k:kernel/kernel-5.10:nv-tegra.nvidia.com/linux-5.10.git:
63 k:kernel/nvgpu:nv-tegra.nvidia.com/linux-nvgpu.git:
64 k:kernel/nvidia:nv-tegra.nvidia.com/linux-nvidia.git:
65 k:kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm:nv-tegra.nvidia.com/kernel/nvethernetrm.git:
66 k:hardware/nvidia/platform/tegra/common:nv-tegra.nvidia.com/device/hardware/nvidia/platform/tegra/common.git:
67 k:hardware/nvidia/soc/t19x:nv-tegra.nvidia.com/device/hardware/nvidia/soc/t19x.git:
68 k:hardware/nvidia/platform/t19x/common:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/common.git:
69 k:hardware/nvidia/platform/t19x/galen/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/stardust-dts.git:
70 k:hardware/nvidia/platform/t19x/jakku/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/jakku-dts.git:
71 k:hardware/nvidia/platform/t19x/mccoy/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/mccoy-dts.git:
72 k:hardware/nvidia/platform/t19x/galen-industrial/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t19x/galen-industrial-dts.git:
73 k:hardware/nvidia/platform/t23x/common/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t23x/common-dts.git:
74 k:hardware/nvidia/platform/t23x/p3768/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t23x/p3768-dts.git:
75 k:hardware/nvidia/platform/t23x/concord/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t23x/concord-dts.git:
76 k:hardware/nvidia/platform/t23x/prometheus/kernel-dts:nv-tegra.nvidia.com/device/hardware/nvidia/platform/t23x/prometheus-dts:
77 k:hardware/nvidia/soc/t23x:nv-tegra.nvidia.com/device/hardware/nvidia/soc/t23x.git:
78 k:hardware/nvidia/soc/tegra:nv-tegra.nvidia.com/device/hardware/nvidia/soc/tegra.git:
79 k:tegra/kernel-src/nv-kernel-display-driver:nv-tegra.nvidia.com/tegra/kernel-src/nv-kernel-display-driver.git:
80 o:3rdparty/dtc:nv-tegra.nvidia.com/3rdparty/dtc.git:
81 o:3rdparty/libnl/3.5.0:nv-tegra.nvidia.com/3rdparty/libnl/3.5.0.git:
82 o:tegra/argus-cam-libav/argus_cam_libavencoder:nv-tegra.nvidia.com/tegra/argus-cam-libav/argus_cam_libavencoder.git:
83 o:tegra/cuda-src/nvsample_cudaprocess:nv-tegra.nvidia.com/tegra/cuda-src/nvsample_cudaprocess.git:
84 o:tegra/gfx-src/nv-xconfig:nv-tegra.nvidia.com/tegra/gfx-src/nv-xconfig.git:
85 o:tegra/gst-src/gst-egl:nv-tegra.nvidia.com/tegra/gst-src/gst-egl.git:
86 o:tegra/gst-src/gst-jpeg:nv-tegra.nvidia.com/tegra/gst-src/gst-jpeg.git:
87 o:tegra/gst-src/gst-nvarguscamera:nv-tegra.nvidia.com/tegra/gst-src/gst-nvarguscamera.git:
88 o:tegra/gst-src/gst-nvcompositor:nv-tegra.nvidia.com/tegra/gst-src/gst-nvcompositor.git:
89 o:tegra/gst-src/gst-nvtee:nv-tegra.nvidia.com/tegra/gst-src/gst-nvtee.git:
90 o:tegra/gst-src/gst-nvv4l2camera:nv-tegra.nvidia.com/tegra/gst-src/gst-nvv4l2camera.git:
91 o:tegra/gst-src/gst-nvvidconv:nv-tegra.nvidia.com/tegra/gst-src/gst-nvvidconv.git:
92 o:tegra/gst-src/gst-nvvideo4linux2:nv-tegra.nvidia.com/tegra/gst-src/gst-nvvideo4linux2.git:
93 o:tegra/gst-src/nvgstapps:nv-tegra.nvidia.com/tegra/gst-src/nvgstapps.git:
94 o:tegra/gst-src/libgstnvcustomhelper:nv-tegra.nvidia.com/tegra/gst-src/libgstnvcustomhelper.git:
95 o:tegra/gst-src/libgstnvdrmvideosink:nv-tegra.nvidia.com/tegra/gst-src/libgstnvdrmvideosink.git:
96 o:tegra/gst-src/libgstnvvideosinks:nv-tegra.nvidia.com/tegra/gst-src/libgstnvvideosinks.git:
97 o:tegra/v4l2-src/libv4l2_nvargus:nv-tegra.nvidia.com/tegra/v4l2-src/libv4l2_nvargus.git:
98 o:tegra/nv-sci-src/nvsci_headers:nv-tegra.nvidia.com/tegra/nv-sci-src/nvsci_headers.git:
99 o:tegra/optee-src/atf:nv-tegra.nvidia.com/tegra/optee-src/atf.git:
100 o:tegra/optee-src/nv-optee:nv-tegra.nvidia.com/tegra/optee-src/nv-optee.git:
101 o:tegra/v4l2-src/v4l2_libs:nv-tegra.nvidia.com/tegra/v4l2-src/v4l2_libs.git:
You don’t really need a “clean system” here. This thing is just downloading some source codes. It has nothing to do with a “system”.
You just need to clean directory to download code.
Also, I want to repeat that please really tell us what is your build step and also error logs you saw on your side.
It seems you are assuming we know every known issue here. But we don’t.
For your Kconfig issue, I also wonder if you look into the wrong path again because we do have “drivers/platform/tegra” in nvidia repo too but not k5.10.
To me, it looks like the issue begins with your source sync that gives you timeout error. So maybe you should just focus on fixing that first. Whether it is network problem or something else.
There was an issue in our server and it shall be fixed now:
Unable to connect to nv-tegra.nvidia.com
Please try again and see if you can download the code successfully.
