Thank you, “recently” tells me enough about this issue given the age of the this Jetpack release.
As I alluded to in my initial message, I can get things to clone correctly. It requires a few modifications to the source_sync.sh script. First, in the array in the script, remove .git from the lines and add the missing /r/: k:kernel/kernel-5.10:nv-tegra.nvidia.com/linux-5.10.git becomes k:kernel/kernel-5.10:nv-tegra.nvidia.com/r/linux-5.10.
Then change the generated URL scheme from git:// to https://:
After that, the tag will download correctly; at least no errors will be reported. but then I am left in the position I wrote about above where files/paths are being used in the build that do not exist in the downloaded files or anywhere in the tagged repo.
Downloading default kernel/kernel-5.10 source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/kernel-5.10’…
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection timed out
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection timed out
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/kernel-5.10 source sync failed!
Downloading default kernel/nvgpu source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvgpu’…
nv-tegra.nvidia.com[0: 35.82.181.43]: errno=Connection timed out
nv-tegra.nvidia.com[1: 34.216.216.36]: errno=Connection timed out
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvgpu source sync failed!
Directory for kernel/nvidia, /home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvidia, already exists!
fatal: not a git repository (or any of the parent directories): .git
But the directory is not a git repository – clean it up first
Downloading default kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm source sync failed!
Downloading default hardware/nvidia/platform/tegra/common source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common source sync failed!
Downloading default hardware/nvidia/soc/t19x source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x source sync failed!
Downloading default hardware/nvidia/platform/t19x/common source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common source sync failed!
Downloading default hardware/nvidia/platform/t19x/galen/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t19x/jakku/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t19x/mccoy/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/mccoy/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/mccoy/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t19x/galen-industrial/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen-industrial/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t23x/common/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/common/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/common/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t23x/p3768/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/p3768/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/p3768/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t23x/concord/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/concord/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/concord/kernel-dts source sync failed!
Downloading default hardware/nvidia/platform/t23x/prometheus/kernel-dts source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/prometheus/kernel-dts’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/platform/t23x/prometheus/kernel-dts source sync failed!
Downloading default hardware/nvidia/soc/t23x source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/t23x’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/t23x source sync failed!
Downloading default hardware/nvidia/soc/tegra source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra source sync failed!
Downloading default tegra/kernel-src/nv-kernel-display-driver source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/kernel-src/nv-kernel-display-driver’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/kernel-src/nv-kernel-display-driver source sync failed!
Downloading default 3rdparty/dtc source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/3rdparty/dtc’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/3rdparty/dtc source sync failed!
Downloading default 3rdparty/libnl/3.5.0 source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/3rdparty/libnl/3.5.0’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/3rdparty/libnl/3.5.0 source sync failed!
Downloading default tegra/argus-cam-libav/argus_cam_libavencoder source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/argus-cam-libav/argus_cam_libavencoder’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/argus-cam-libav/argus_cam_libavencoder source sync failed!
Downloading default tegra/cuda-src/nvsample_cudaprocess source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/cuda-src/nvsample_cudaprocess’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/cuda-src/nvsample_cudaprocess source sync failed!
Downloading default tegra/gfx-src/nv-xconfig source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gfx-src/nv-xconfig’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gfx-src/nv-xconfig source sync failed!
Downloading default tegra/gst-src/gst-egl source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-egl’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-egl source sync failed!
Downloading default tegra/gst-src/gst-jpeg source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-jpeg’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-jpeg source sync failed!
Downloading default tegra/gst-src/gst-nvarguscamera source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvarguscamera’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvarguscamera source sync failed!
Downloading default tegra/gst-src/gst-nvcompositor source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvcompositor’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvcompositor source sync failed!
Downloading default tegra/gst-src/gst-nvtee source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvtee’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvtee source sync failed!
Downloading default tegra/gst-src/gst-nvv4l2camera source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvv4l2camera’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvv4l2camera source sync failed!
Downloading default tegra/gst-src/gst-nvvidconv source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvvidconv’…
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=No route to host
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=No route to host
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvvidconv source sync failed!
Downloading default tegra/gst-src/gst-nvvideo4linux2 source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvvideo4linux2’…
fatal: Unable to look up nv-tegra.nvidia.com (port 9418) (Name or service not known)
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/gst-nvvideo4linux2 source sync failed!
Downloading default tegra/gst-src/nvgstapps source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/nvgstapps’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/nvgstapps source sync failed!
Downloading default tegra/gst-src/libgstnvcustomhelper source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvcustomhelper’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvcustomhelper source sync failed!
Downloading default tegra/gst-src/libgstnvdrmvideosink source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvdrmvideosink’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvdrmvideosink source sync failed!
Downloading default tegra/gst-src/libgstnvvideosinks source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvvideosinks’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/gst-src/libgstnvvideosinks source sync failed!
Downloading default tegra/v4l2-src/libv4l2_nvargus source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/v4l2-src/libv4l2_nvargus’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/v4l2-src/libv4l2_nvargus source sync failed!
Downloading default tegra/nv-sci-src/nvsci_headers source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/nv-sci-src/nvsci_headers’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/nv-sci-src/nvsci_headers source sync failed!
Downloading default tegra/optee-src/atf source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/optee-src/atf’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/optee-src/atf source sync failed!
Downloading default tegra/optee-src/nv-optee source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/optee-src/nv-optee’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/optee-src/nv-optee source sync failed!
Downloading default tegra/v4l2-src/v4l2_libs source…
Cloning into ‘/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/v4l2-src/v4l2_libs’…
/home/vadmin/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/tegra/v4l2-src/v4l2_libs source sync failed!
Edit: I just noticed that my VM lost connectivity toward the end of execution but rest assured that the outcome is the same as the previous clone attempts.
