Unable to connect to nv-tegra.nvidia.com 2025-05-6
Continuing the discussion from Unable to connect to nv-tegra.nvidia.com 2025-04-18:
Having the same issues now 05/26/2025.
Downloading default hardware/nvidia/t23x/nv-public source...
Cloning into '[...]'.
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection refused
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection refused
I’m using this command.
./source_sync.sh -k -t jetson_36.4.3
It works internally?
  1. Extracted the BSP, ROOTFS, PUBLIC SOURCES, then sync.
I’ve discovered what I needed to extract to make my kernel customization iwo the sync, just reporting the issue.
Sorry to bring this trouble, I have forwarded it to internal team to fix it, please wait for my update. Thanks
@tarcisio.jaolive can you share source_sync.sh to me? and can you go to your local repo then run “git remote -v”?
Hi @lelei
As I said before, I worked around it and discovered what I needed to do manually to make it work from the compressed files on the site, i’m just helping you debug.
Thanks for asking tho, follows the answers:
Nothing outputs from git remote -v because I never connected to the remote git in the first place, it gets refused as if i don’t have access or the repository isn’t there anymore.
The code and output for source_sync.sh:
#!/bin/bash
# SPDX-FileCopyrightText: Copyright (c) 2012-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: BSD-3-Clause
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its
# contributors may be used to endorse or promote products derived from
# this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
# SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
# CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
# OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# This script sync's NVIDIA's version of
# 1. the kernel source
# from nv-tegra, NVIDIA's public git repository.
# The script also provides opportunities to the sync to a specific tag
# so that the binaries shipped with a release can be replicated.
# Usage:
# By default it will download all the listed sources
# ./source_sync.sh
# Use the -t <TAG> option to provide the TAG to be used to sync all the sources.
# Use the -k <TAG> option to download only the kernel and device tree repos and optionally sync to TAG
# For detailed usage information run with -h option.
# verify that git is installed
if  ! which git > /dev/null  ; then
  echo "ERROR: git is not installed. If your linux distro is 10.04 or later,"
  echo "git can be installed by 'sudo apt-get install git-core'."
  exit 1
fi
# source dir
LDK_DIR=$(cd $(dirname $0) && pwd)
# script name
SCRIPT_NAME=$(basename $0)
# info about sources.
# NOTE: *Add only kernel repos here. Add new repos separately below. Keep related repos together*
# NOTE: nvethrnetrm.git should be listed after "linux-nv-oot.git" due to nesting of sync path
SOURCE_INFO="
k:kernel/kernel-jammy-src:nv-tegra.nvidia.com/3rdparty/canonical/linux-jammy.git:
k:nvgpu:nv-tegra.nvidia.com/linux-nvgpu.git:
k:nvidia-oot:nv-tegra.nvidia.com/linux-nv-oot.git:
k:hwpm:nv-tegra.nvidia.com/linux-hwpm.git:
k:nvethernetrm:nv-tegra.nvidia.com/kernel/nvethernetrm.git:
k:kernel-devicetree:nv-tegra.nvidia.com/linux/kernel-devicetree.git:
k:hardware/nvidia/t23x/nv-public:nv-tegra.nvidia.com/device/hardware/nvidia/t23x-public-dts.git:
k:hardware/nvidia/tegra/nv-public:nv-tegra.nvidia.com/device/hardware/nvidia/tegra-public-dts.git:
k:nvdisplay:nv-tegra.nvidia.com/tegra/kernel-src/nv-kernel-display-driver.git:
k:dtc-src/1.4.5:nv-tegra.nvidia.com/3rdparty/dtc-src/1.4.5.git:
o:tegra/argus-cam-libav/argus_cam_libavencoder:nv-tegra.nvidia.com/tegra/argus-cam-libav/argus_cam_libavencoder.git:
o:tegra/cuda-src/nvsample_cudaprocess:nv-tegra.nvidia.com/tegra/cuda-src/nvsample_cudaprocess.git:
o:tegra/gfx-src/nv-xconfig:nv-tegra.nvidia.com/tegra/gfx-src/nv-xconfig.git:
o:tegra/gst-src/gst-egl:nv-tegra.nvidia.com/tegra/gst-src/gst-egl.git:
o:tegra/gst-src/gst-jpeg:nv-tegra.nvidia.com/tegra/gst-src/gst-jpeg.git:
o:tegra/gst-src/gst-nvarguscamera:nv-tegra.nvidia.com/tegra/gst-src/gst-nvarguscamera.git:
o:tegra/gst-src/gst-nvcompositor:nv-tegra.nvidia.com/tegra/gst-src/gst-nvcompositor.git:
o:tegra/gst-src/gst-nvtee:nv-tegra.nvidia.com/tegra/gst-src/gst-nvtee.git:
o:tegra/gst-src/gst-nvv4l2camera:nv-tegra.nvidia.com/tegra/gst-src/gst-nvv4l2camera.git:
o:tegra/gst-src/gst-nvvidconv:nv-tegra.nvidia.com/tegra/gst-src/gst-nvvidconv.git:
o:tegra/gst-src/gst-nvvideo4linux2:nv-tegra.nvidia.com/tegra/gst-src/gst-nvvideo4linux2.git:
o:tegra/gst-src/nvgstapps:nv-tegra.nvidia.com/tegra/gst-src/nvgstapps.git:
o:tegra/gst-src/libgstnvcustomhelper:nv-tegra.nvidia.com/tegra/gst-src/libgstnvcustomhelper.git:
o:tegra/gst-src/libgstnvdrmvideosink:nv-tegra.nvidia.com/tegra/gst-src/libgstnvdrmvideosink.git:
o:tegra/gst-src/libgstnvvideosinks:nv-tegra.nvidia.com/tegra/gst-src/libgstnvvideosinks.git:
o:tegra/gst-src/opencv_gst_samples:nv-tegra.nvidia.com/tegra/gst-src/opencv_gst_samples.git:
o:tegra/v4l2-src/libv4l2_nvargus:nv-tegra.nvidia.com/tegra/v4l2-src/libv4l2_nvargus.git:
o:tegra/nv-sci-src/nvsci_headers:nv-tegra.nvidia.com/tegra/nv-sci-src/nvsci_headers.git:
o:tegra/nv-sci-src/nvsci_samples:nv-tegra.nvidia.com/tegra/nv-sci-src/nvsci_samples.git:
o:tegra/openwfd-src/openwfd_headers:nv-tegra.nvidia.com/tegra/openwfd-src/openwfd_headers.git:
o:tegra/optee-src/atf:nv-tegra.nvidia.com/tegra/optee-src/atf.git:
o:tegra/optee-src/nv-optee:nv-tegra.nvidia.com/tegra/optee-src/nv-optee.git:
o:tegra/spe-src/spe-freertos-bsp:nv-tegra.nvidia.com/tegra/spe-src/spe-freertos-bsp.git:
o:tegra/v4l2-src/v4l2_libs:nv-tegra.nvidia.com/tegra/v4l2-src/v4l2_libs.git:
# exit on error on sync
EOE=0
# after processing SOURCE_INFO
NSOURCES=0
declare -a SOURCE_INFO_PROCESSED
# download all?
DALL=1
function Usages {
	local ScriptName=$1
	local LINE
	local OP
	local DESC
	local PROCESSED=()
	local i
	echo "Use: $1 [options]"
	echo "Available general options are,"
	echo "     -h     :     help"
	echo "     -e     : exit on sync error"
	echo "     -d [DIR] : root of source is DIR"
	echo "     -t [TAG] : Git tag that will be used to sync all the sources"
	echo ""
	echo "By default, all sources are downloaded."
	echo "Only specified sources are downloaded, if one or more of the following options are mentioned."
	echo ""
	echo "$SOURCE_INFO" | while read LINE; do
		if [ ! -z "$LINE" ]; then
			OP=$(echo "$LINE" | cut -f 1 -d ':')
			DESC=$(echo "$LINE" | cut -f 2 -d ':')
			if [[ ! " ${PROCESSED[@]} " =~ " ${OP} " ]]; then
				echo "     -${OP} [TAG]: Download $DESC source and optionally sync to TAG"
				PROCESSED+=("${OP}")
			else
				echo "           and download $DESC source and sync to the same TAG"
			fi
		fi
	done
	echo ""
function ProcessSwitch {
	local SWITCH="$1"
	local TAG="$2"
	local i
	local found=0
	for ((i=0; i < NSOURCES; i++)); do
		local OP=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 1 -d ':')
		if [ "-${OP}" == "$SWITCH" ]; then
			SOURCE_INFO_PROCESSED[i]="${SOURCE_INFO_PROCESSED[i]}${TAG}:y"
			DALL=0
			found=1
		fi
	done
	if [ "$found" == 1 ]; then
		return 0
	fi
	echo "Terminating... wrong switch: ${SWITCH}" >&2
	Usages "$SCRIPT_NAME"
	exit 1
function UpdateTags {
	local SWITCH="$1"
	local TAG="$2"
	local i
		if [ "${OP}" == "$SWITCH" ]; then
			SOURCE_INFO_PROCESSED[i]=$(echo "${SOURCE_INFO_PROCESSED[i]}" \
				| awk -F: -v OFS=: -v var="${TAG}" '{$4=var; print}')
		fi
	done
function DownloadAndSync {
	local WHAT_SOURCE="$1"
	local LDK_SOURCE_DIR="$2"
	local REPO_URL="$3"
	local TAG="$4"
	local OPT="$5"
	local RET=0
	if [ -d "${LDK_SOURCE_DIR}" ]; then
		echo "Directory for $WHAT, ${LDK_SOURCE_DIR}, already exists!"
		pushd "${LDK_SOURCE_DIR}" > /dev/null
		git status 2>&1 >/dev/null
		if [ $? -ne 0 ]; then
			echo "But the directory is not a git repository -- clean it up first"
			echo ""
			echo ""
			popd > /dev/null
			return 1
		fi
		git fetch --all 2>&1 >/dev/null
		popd > /dev/null
	else
		echo "Downloading default $WHAT source..."
		git clone "$REPO_URL" -n ${LDK_SOURCE_DIR} 2>&1 >/dev/null
			echo "$2 source sync failed!"
			echo ""
			echo ""
			return 1
		fi
		echo "The default $WHAT source is downloaded in: ${LDK_SOURCE_DIR}"
	fi
	if [ -z "$TAG" ]; then
		echo "Please enter a tag to sync $2 source to"
		echo -n "(enter nothing to skip): "
		read TAG
		TAG=$(echo $TAG)
		UpdateTags $OPT $TAG
	fi
	if [ ! -z "$TAG" ]; then
		pushd ${LDK_SOURCE_DIR} > /dev/null
		git tag -l 2>/dev/null | grep -q -P "^$TAG\$"
		if [ $? -eq 0 ]; then
			echo "Syncing up with tag $TAG..."
			git checkout -b mybranch_$(date +%Y-%m-%d-%s) $TAG
			echo "$2 source sync'ed to tag $TAG successfully!"
		else
			echo "Couldn't find tag $TAG"
			echo "$2 source sync to tag $TAG failed!"
			RET=1
		fi
		popd > /dev/null
	fi
	echo ""
	echo ""
	return "$RET"
# prepare processing ....
GETOPT=":ehd:t:"
OIFS="$IFS"
IFS=$(echo -en "\n\b")
SOURCE_INFO_PROCESSED=($(echo "$SOURCE_INFO"))
IFS="$OIFS"
NSOURCES=${#SOURCE_INFO_PROCESSED[*]}
	GETOPT="${GETOPT}${OP}:"
done
# parse the command line first
while getopts "$GETOPT" opt; do
	case $opt in
		d)
			case $OPTARG in
				-[A-Za-z]*)
					exit 1
					LDK_DIR="$OPTARG"
			esac
		e)
			EOE=1
		h)
			exit 1
		t)
			TAG="$OPTARG"
			PROCESSED=()
					UpdateTags $OP $TAG
				fi
			done
		[A-Za-z])
			case $OPTARG in
				-[A-Za-z]*)
					eval arg=\$$((OPTIND-1))
					case $arg in
						-[A-Za-Z]-*)
							exit 1
							ProcessSwitch "-$opt" ""
							OPTIND=$((OPTIND-1))
					esac
					ProcessSwitch "-$opt" "$OPTARG"
			esac
			case $OPTARG in
				#required arguments
				d)
					exit 1
				#optional arguments
				[A-Za-z])
					ProcessSwitch "-$OPTARG" ""
			esac
			echo "Terminating... wrong switch: $@" >&2
			exit 1
	esac
done
shift $((OPTIND-1))
GRET=0
	OPT=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 1 -d ':')
	WHAT=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 2 -d ':')
	REPO=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 3 -d ':')
	TAG=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 4 -d ':')
	DNLOAD=$(echo "${SOURCE_INFO_PROCESSED[i]}" | cut -f 5 -d ':')
	if [ $DALL -eq 1 -o "x${DNLOAD}" == "xy" ]; then
		DownloadAndSync "$WHAT" "${LDK_DIR}/${WHAT}" "git://${REPO}" "${TAG}" "${OPT}"
		tRET=$?
		let GRET=GRET+tRET
		if [ $tRET -ne 0 -a $EOE -eq 1 ]; then
			exit $tRET
		fi
	fi
done
ln -sf ../../../../../../nvethernetrm nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm
exit $GRET
Running source_sync.sh with jetson_36.4.3...
Downloading default kernel/kernel-jammy-src source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/kernel/kernel-jammy-src'...
nv-tegra.nvidia.com[0: 35.82.181.43]: errno=Connection refused
nv-tegra.nvidia.com[1: 34.216.216.36]: errno=Connection refused
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/kernel/kernel-jammy-src source sync failed!
Downloading default nvgpu source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvgpu'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvgpu source sync failed!
Downloading default nvidia-oot source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvidia-oot'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvidia-oot source sync failed!
Downloading default hwpm source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hwpm'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hwpm source sync failed!
Downloading default nvethernetrm source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvethernetrm'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvethernetrm source sync failed!
Downloading default kernel-devicetree source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/kernel-devicetree'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/kernel-devicetree source sync failed!
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public source sync failed!
Downloading default hardware/nvidia/tegra/nv-public source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hardware/nvidia/tegra/nv-public'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/hardware/nvidia/tegra/nv-public source sync failed!
Downloading default nvdisplay source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvdisplay'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/nvdisplay source sync failed!
Downloading default dtc-src/1.4.5 source...
Cloning into '$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/dtc-src/1.4.5'...
$WORKING_DIR/DEBUG_SYNC/DEBUG_SOURCE/Linux_for_Tegra/source/dtc-src/1.4.5 source sync failed!
ln: failed to create symbolic link 'nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm': No such file or directory
ERROR: Failed to sync sources
$~$WORKING_DIR/DEBUG_SYNC$ git remote -v
The server issue should be fixed, please help to get it a try. Thanks
It is fixed, thanks.
