Failed to fetch source through source_sync
Unable to pull the source code of tag jeton_38.4 from Git.
root@wpces:/home/wpces/Downloads/Linux_for_Tegra/source# ping gitlab.com
PING gitlab.com (xx.xx.xx.xx) 56(84) bytes of data.
64 bytes from xx.xx.xx.xx: icmp_seq=1 ttl=128 time=177 ms
64 bytes from xx.xx.xx.xx: icmp_seq=2 ttl=128 time=165 ms
64 bytes from xx.xx.xx.xx: icmp_seq=3 ttl=128 time=176 ms
^C
--- gitlab.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 164.968/172.537/176.606/5.357 ms
root@wpces:/home/wpces/Downloads/Linux_for_Tegra/source# ./source_sync.sh -k -t jetson_38.4
Detecting available git server...
Testing server: gitlab.com/nvidia/nv-tegra...
Testing server: nv-tegra.nvidia.com...
Using git server: nv-tegra.nvidia.com
Using user provided tag jetson_38.4 for source sync
Tag is set to jetson_38.4
Fetching tag jetson_38.4 for dtc-src/1.4.5 ...
Checking out tag jetson_38.4 for dtc-src/1.4.5 ...
Failed to checkout tag jetson_38.4 for dtc-src/1.4.5
Fetching tag jetson_38.4 for hardware/nvidia/t23x/nv-public ...
Checking out tag jetson_38.4 for hardware/nvidia/t23x/nv-public ...
Failed to checkout tag jetson_38.4 for hardware/nvidia/t23x/nv-public
Fetching tag jetson_38.4 for hardware/nvidia/t264/nv-public ...
Do I have to manually download and unzip it from the official website?I don’t want to do that.
That’s still under preparation, please wait for our announcement to try, Thanks
Okay, looking forward to it. Thank you for the answer!
Here’s what I did a bit earlier tonight.
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/release/Jetson_Linux_R38.4.0_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/release/Tegra_Linux_Sample-Root-Filesystem_R38.4.0_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/source/public_sources.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/release/ota_tools_R38.4.0_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/release/host_overlay_fskp_tools_R38.4.0_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r38_Release_v4.0/source/ubuntu_noble-l4t_aarch64_src.tbz2
tar -xpf Jetson_Linux_R38.4.0_aarch64.tbz2
cd Linux_for_Tegra/rootfs/
sudo tar -xpf ../../Tegra_Linux_Sample-Root-Filesystem_R38.4.0_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh --openrm
tar -xpf ./public_sources.tbz2
cd Linux_for_Tegra/source
Then extract all the tarballs in the source folder
for f in *; do
  case "$f" in
    *.tbz2|*.tar.bz2) tar -xjf "$f" ;;
    *.tar.gz|*.tgz)    tar -xzf "$f" ;;
    *.tar.xz)          tar -xJf "$f" ;;
    *.tar)             tar -xf "$f" ;;
  esac
done
You’re really doing an excellent job! Has there been any improvement in the 100G network with this version? By switching to threaded mode, I was only able to reach over 40G with TCP in the previous version (r38.2.1), and UDP was only a few Mbps.
hi,kayccc
But I want to know where to make the announcement for it to be valid. I could already see it on the official website yesterday.
JetPack SDK Downloads and Notes | NVIDIA Developer
We have posted the JP7.1 announcement at this morning - NVIDIA Jetson T4000 and NVIDIA JetPack 7.1 now available: Accelerate AI Inference for Edge and Robotics - Jetson & Embedded Systems / Jetson Thor - NVIDIA Developer Forums
Please get it a try now. Thanks
hi,kayccc
It can now be automatically pulled except for the kernel.It got blocked.
Successfully synced hardware/nvidia/t23x/nv-public to /home/wpces/Downloads/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public with  tag jetson_38.4
Checking out tag jetson_38.4 for hardware/nvidia/t264/nv-public ...
Successfully synced hardware/nvidia/t264/nv-public to /home/wpces/Downloads/Linux_for_Tegra/source/hardware/nvidia/t264/nv-public with  tag jetson_38.4
Fetching tag jetson_38.4 for hardware/nvidia/tegra/nv-public ...
Checking out tag jetson_38.4 for hardware/nvidia/tegra/nv-public ...
Successfully synced hardware/nvidia/tegra/nv-public to /home/wpces/Downloads/Linux_for_Tegra/source/hardware/nvidia/tegra/nv-public with  tag jetson_38.4
Fetching tag jetson_38.4 for hwpm ...
Checking out tag jetson_38.4 for hwpm ...
Successfully synced hwpm to /home/wpces/Downloads/Linux_for_Tegra/source/hwpm with  tag jetson_38.4
Fetching tag jetson_38.4 for kernel-devicetree ...
Checking out tag jetson_38.4 for kernel-devicetree ...
Successfully synced kernel-devicetree to /home/wpces/Downloads/Linux_for_Tegra/source/kernel-devicetree with  tag jetson_38.4
Cloning kernel/kernel-noble repository ...
Is this still an issue now?
Could you confirm whether syncing sources is slower but still works without issues, right?
This is because of nv-tegra git server. If you are seeing issues because of slowness of nv-tegra, you could use the new git server to sync - nv-tegra · GitLab
Sorry, all the code except for the kernel can be synced. I’ve given up on manually extracting the tar package.
I just tried again, but I can’t pull the kernel down. It’s not slow, it just doesn’t move at all. There’s only a control folder and a .git folder. Other device tree sources that are smaller can be pulled down
root@wpces:/home/wpces/Downloads/Linux_for_Tegra/source/kernel/kernel-noble# ll
total 12
drwxr-xr-x 3 root root 4096 Jan 19 10:01 ./
drwxrwxrwx 3 root root 4096 Jan 19 10:01 ../
drwxr-xr-x 7 root root 4096 Jan 19 10:01 .git/
Please try attached source_sync.sh and see if you can successfully download kernel source code.
source_sync.zip (4.9 KB)
Hi wpceswpces,
Last week I looked at the 7.1 source_sync.sh and it’s been updated and now defaults to the most recent Jetpack. I just ran following to pull sources. I think gitlab requires a person to logged into it; but I don’t know how that would work as I doubt gitlab.com is checking my web browsers cookies from within source_sync.sh. So nv-tegra wins below.
cd ~/nvidia/nvidia_sdk/JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/source
./source_sync.sh -k -o
No user provided tag.. getting latest tag from reference repository
Using latest tag jetson_38.4 for source sync
I once cd into a git pull from nv-tegra and it was empty. so to be safe I ran I think then it was jetson_36.4.3 and all the source appeared.
git checkout jetson_38.4
Alright, whitesscott,but this part of the code in the Git repository should be public, so I feel like logging into an account shouldn’t be necessary.
Hi,DaneLLL
Alright, thank you! I’ll try the new script you provided later.
Can the new script work well?
Hi,kayccc
Sorry, I tried the new script, but it directly exits without cloning the code from the repository.
new:
root@tj-software:~/wpces/source# ./source_sync.sh -k -t jetson_38.4
Testing server: https://gitlab.com/nvidia/nv-tegra...
Using git server: https://gitlab.com/nvidia/nv-tegra
old:
root@tj-software:~/wpces/old# ./source_sync.sh -k -t jetson_38.4
Cloning dtc-src/1.4.5 repository ...
Successfully synced dtc-src/1.4.5 to /root/wpces/old/dtc-src/1.4.5 with  tag jetson_38.4
Cloning hardware/nvidia/t23x/nv-public repository ...
Successfully synced hardware/nvidia/t23x/nv-public to /root/wpces/old/hardware/nvidia/t23x/nv-public with  tag jetson_38.4
Cloning hardware/nvidia/t264/nv-public repository ...
Successfully synced hardware/nvidia/t264/nv-public to /root/wpces/old/hardware/nvidia/t264/nv-public with  tag jetson_38.4
Cloning hardware/nvidia/tegra/nv-public repository ...
Successfully synced hardware/nvidia/tegra/nv-public to /root/wpces/old/hardware/nvidia/tegra/nv-public with  tag jetson_38.4
Cloning hwpm repository ...
Successfully synced hwpm to /root/wpces/old/hwpm with  tag jetson_38.4
Cloning kernel-devicetree repository ...
Successfully synced kernel-devicetree to /root/wpces/old/kernel-devicetree with  tag jetson_38.4
^C
root@tj-software:~/wpces/old# ls
Please try without “-k”:
$ ./source_sync.sh -t jetson_38.4
I think a router in front of, or the server itself is down.
The connection has timed out
The server at nv-tegra.nvidia.com is taking too long to respond.```
traceroute to nv-tegra.nvidia.com (35.82.181.43), 30 hops max, 60 byte packets
 1  Archer_BE550 (192.168.1.1)  0.415 ms  0.417 ms  0.397 ms
 2  10.112.239.146 (10.112.239.146)  20.008 ms 10.112.239.147 (10.112.239.147)  19.950 ms  19.933 ms
 3  po-56-rur202.pittsburg.ca.sfba.comcast.net (68.85.103.213)  19.881 ms po-56-rur201.pittsburg.ca.sfba.comcast.net (68.85.103.197)  19.822 ms po-56-rur202.pittsburg.ca.sfba.comcast.net (68.85.103.213)  19.848 ms
 4  po-200-xar01.pittsburg.ca.sfba.comcast.net (68.86.143.1)  19.790 ms  20.284 ms po-200-xar02.pittsburg.ca.sfba.comcast.net (68.87.192.69)  19.838 ms
 5  po-2-xar02.pittsburg.ca.sfba.comcast.net (162.151.86.14)  19.807 ms  19.792 ms  19.775 ms
 6  be-398-ar01.hayward.ca.sfba.comcast.net (162.151.87.225)  22.060 ms  20.164 ms  20.135 ms
 7  be-398-ar01.hayward.ca.sfba.comcast.net (162.151.87.225)  20.144 ms  12.319 ms  12.325 ms
 8  * * *
 9  * * *
10  * * *
Hi,DaneLLL
I tried the parameter without -k and found that, just like in the old script in version 7.1, the device tree can be pulled down, but the kernel source cannot. After waiting for 5 to 6 minutes, the kernel source directory is still empty except for the .git file.
root@tj-software:~/wpces/source# ./source_sync.sh -t jetson_38.4
Successfully synced dtc-src/1.4.5 to /root/wpces/source/dtc-src/1.4.5 with  tag jetson_38.4
Successfully synced hardware/nvidia/t23x/nv-public to /root/wpces/source/hardware/nvidia/t23x/nv-public with  tag jetson_38.4
Successfully synced hardware/nvidia/t264/nv-public to /root/wpces/source/hardware/nvidia/t264/nv-public with  tag jetson_38.4
Successfully synced hardware/nvidia/tegra/nv-public to /root/wpces/source/hardware/nvidia/tegra/nv-public with  tag jetson_38.4
Successfully synced hwpm to /root/wpces/source/hwpm with  tag jetson_38.4
Successfully synced kernel-devicetree to /root/wpces/source/kernel-devicetree with  tag jetson_38.4
root@tj-software:~/wpces/source/kernel/kernel-noble# ll
总计 12
drwxr-xr-x 3 root root 4096  1月 21 09:49 ./
drwxr-xr-x 3 root root 4096  1月 21 09:49 ../
drwxr-xr-x 7 root root 4096  1月 21 09:49 .git/
总计 12
