I’m trying to compile with portald 7.1-6 in an intel 64bit machine (xeon) with 16GB of RAM and I get the following error:
pgf77 -V -v -mcmodel=medium -Mlarge_arrays -i8 -r8 -tp p7-64 -o iso2 isomag2.f -L/usr/local/portland/linux86-64/7.1-6/lib -llapack -lblas -lpgftnrtl -lpgc
pgf77 7.1-6 64-bit target on x86-64 Linux -tp p7-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2007, STMicroelectronics, Inc. All Rights Reserved.
isomag2.f:
/usr/local/portland/linux86-64/7.1-6/bin/pgftn isomag2.f -opt 1 -version -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 70 0x8000 -x 122 1 -quad -x 59 4 -x 59 4 -tp p7-64 -x 51 0x20 -x 124 0x1401 -astype 0 -stdinc /usr/local/portland/linux86-64/7.1-6/include:/usr/local/include:/usr/lib/gcc/x86_64-linux-gnu/4.1.2/include:/usr/lib/gcc/x86_64-linux-gnu/4.1.2/include:/usr/include -def unix -def __unix -def __unix__ -def linux -def __linux -def __linux__ -def __NO_MATH_INLINES -def __x86_64__ -def __LONG_MAX__=9223372036854775807L -def '__SIZE_TYPE__=unsigned long int' -def '__PTRDIFF_TYPE__=long int' -def __THROW= -def __extension__= -def __amd64__ -def __SSE__ -def __MMX__ -def __SSE2__ -def __SSE3__ -cmdline '+pgf77 isomag2.f -V -v -mcmodel=medium -Mlarge_arrays -i8 -r8 -tp p7-64 -o iso2 -L/usr/local/portland/linux86-64/7.1-6/lib -llapack -lblas -lpgftnrtl -lpgc' -x 124 0x10 -x 124 1 -x 135 1 -x 68 0x1 -x 68 0x1 -x 124 0x28 -asm /tmp/pgf77BMwfrGGQgx5d.s
NOTE: your trial license will expire in 6 days, 11.5 hours.
PGFTN/x86-64 Linux 7.1-6
0 inform, 0 warnings, 0 severes, 0 fatal for isomag2
PGFTN-I-0035-Predefined intrinsic imag loses intrinsic property (./pariso21: 11)
1 inform, 0 warnings, 0 severes, 0 fatal for ene
1 inform, 0 warnings, 0 severes, 0 fatal for iso
1 inform, 0 warnings, 0 severes, 0 fatal for sus
1 inform, 0 warnings, 0 severes, 0 fatal for mag
1 inform, 0 warnings, 0 severes, 0 fatal for war
0 inform, 0 warnings, 0 severes, 0 fatal for fak
0 inform, 0 warnings, 0 severes, 0 fatal for lab
0 inform, 0 warnings, 0 severes, 0 fatal for cle
0 inform, 0 warnings, 0 severes, 0 fatal for c6j
0 inform, 0 warnings, 0 severes, 0 fatal for c9000
0 inform, 0 warnings, 0 severes, 0 fatal for c9011
0 inform, 0 warnings, 0 severes, 0 fatal for c9101
0 inform, 0 warnings, 0 severes, 0 fatal for c9110
0 inform, 0 warnings, 0 severes, 0 fatal for c9022
0 inform, 0 warnings, 0 severes, 0 fatal for c9202
0 inform, 0 warnings, 0 severes, 0 fatal for c9220
PGFTN/x86-64 Linux 7.1-6: compilation completed with informational messages
/usr/bin/as /tmp/pgf77BMwfrGGQgx5d.s -o isomag2.o
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o /usr/local/portland/linux86-64/7.1-6/libso/trace_init.o /usr/lib/gcc/x86_64-linux-gnu/4.1.2/crtbegin.o /usr/local/portland/linux86-64/7.1-6/libso/pgfmain.o -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 /usr/local/portland/linux86-64/7.1-6/lib/pgi.ld -L/usr/local/portland/linux86-64/7.1-6/lib -L/usr/local/portland/linux86-64/7.1-6/libso -L/usr/local/portland/linux86-64/7.1-6/lib -L/usr/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2 isomag2.o -llapack -lblas -lpgftnrtl -lpgc -rpath /usr/local/portland/linux86-64/7.1-6/libso -rpath /usr/local/portland/linux86-64/7.1-6/lib -o iso2 -lpgftnrtl -lnspgc -lpgc -lrt -lpthread -lm -lgcc -lc -lgcc /usr/lib/gcc/x86_64-linux-gnu/4.1.2/crtend.o /usr/lib64/crtn.o
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(fmtwrite.o): In function `fw_write':
fmtwrite.c:(.text+0x6db): relocation truncated to fit: R_X86_64_PC32 against symbol `envar_fortranopt' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(fmtconv.o): In function `conv_int8':
fmtconv.c:(.text+0x790): relocation truncated to fit: R_X86_64_PC32 against symbol `__ftn_32in64_' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(fmtwrite.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o): In function `fio_init':
error.c:(.text+0x957): relocation truncated to fit: R_X86_64_PC32 against symbol `envar_fortranopt' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o): In function `__fio_check_format':
error.c:(.text+0x967): relocation truncated to fit: R_X86_64_PC32 against symbol `envar_fortranopt' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o): In function `__fio_eor_crlf':
error.c:(.text+0x9a7): relocation truncated to fit: R_X86_64_PC32 against symbol `envar_fortranopt' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(open.o): In function `__fio_open':
open.c:(.text+0x874): relocation truncated to fit: R_X86_64_PC32 against symbol `envar_fortranopt' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a(error.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o): In function `__pgio_get_argv':
pgargs.c:(.text+0x7): relocation truncated to fit: R_X86_64_PC32 against symbol `__argv_save' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o): In function `__pgio_set_argv':
pgargs.c:(.text+0x1c): relocation truncated to fit: R_X86_64_PC32 against symbol `__argv_save' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o): In function `__pgio_get_argc':
pgargs.c:(.text+0x28): relocation truncated to fit: R_X86_64_PC32 against symbol `__argc_save' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o)
/usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o): In function `__pgio_set_argc':
pgargs.c:(.text+0x3a): relocation truncated to fit: R_X86_64_PC32 against symbol `__argc_save' defined in COMMON section in /usr/local/portland/linux86-64/7.1-6/lib/libpgc.a(pgargs.o)
pgf77-Fatal-linker completed with exit code 1
Unlinking /tmp/pgf77BMwfrGGQgx5d.s
NOTE: I use the -mcmodel=medium -Mlarge_arrays -i8 -r8 -tp p7-64 flags
Could you say me what happens?
Thanks in advance,
sorry I forgot to say that when I try to look for any of this symbols it seems that portland hasn’t got any definition for these.
nm -A /usr/local/portland/linux86-64/7.1-6/lib/*.a | grep envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgf90.a:error.o:0000000000000008 C envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgf90.a:fmtwrite.o: U envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgf90.a:open.o: U envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a:fmtwrite.o: U envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a:error.o:0000000000000008 C envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpgftnrtl.a:open.o: U envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpghpf.a:error.o:0000000000000008 C envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpghpf.a:fmtwrite.o: U envar_fortranopt
/usr/local/portland/linux86-64/7.1-6/lib/libpghpf.a:open.o: U envar_fortranopt
best regards
jingles
