I have tried to install Nvidia driver for my TUF Dash F15 laptop with RTX 3080 mobile gpu according to my previous thread.
I was instructed to start a new thread after it seems the issue is a compatibility between the intel iGPU and the nvidia RTX.
I just installed Ubuntu 21 by erasing the disk to install and sudo apt update and sudo apt upgrade and reboot. I then go the the ‘Additional Drivers’ tab in the ‘Software Update’ launcher and select "Using NVIDIA driver metapackage from nvidia-driver-460 (proprietary)’ and reboot. Upon booting, my laptop won’t load past the default ASUS screen and I cannot get to grub or any terminal using hot-keys. My only option at this point is to re-install Ubuntu.
Since I can’t get to a terminal, I don’t know how to get the nvidia-bug-report.log.gz or /var/log/nvidia-installer.log!
I’ve re-installed Ubuntu 21 and now I have not tried to install the driver. Below is the relevant information I could gather.
sudo lshw -c video
*-display
VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 01
width: 64 bits
clock: 33Hz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:600-5ff iomemory:400-3ff irq:186 memory:6034000000-6034ffffff ioport:5000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40fffffff
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33mHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resouces: iomemory:600-5ff iomemory:600-5ff irq:16 memory:85000000-85ffffff memory:6020000000-602fffffff memory:6031fffff ioport:4000(size=128) memory:86000000-8607ffff
