Problems with the newly purchased TX2 module
Is this issue reproducible on rel-32.7.3 devkit? We won’t upgrade rel-28 anymore. So this better getting reproduced on rel-32.
Also, could you try to use full flash command by flash.sh instead of using dd?
It’s will be a huge workload to reproduce on rel-32 version, so it’s not my best choice.
I will try to make rel-28.3.1 work on the new tx2 module.
I found there are differences in the bpmp section between rel-28.3.1 and rel-28.5. after fixed the previous error operation, uart7 and screen display are both working fine in rel-28.5.
I tried to write the bpmp-fw and bpmp-fw-dtb partitions in rel-28.5 to the tx2 module in rel-28.3.1, and it seems to be working properly. If so, I can continue using version rel-28.3.1 without worrying about upgrading the version. I’m not sure if there are any unknown risks to this operation? Please try to analyze it for me,thanks
I cannot guarantee this as we don’t test this internally. Please just use it. I don’t think it would cause error.
OK, thanks for your reply.
