PtWorldPos Precision Bug
The PtWorldPos AOV precision drops significantly as it moves away from the origin. Possibly due to it being half float but I’m not entirely sure why. See code and screenshots bellow.
The difference between these two images is only the sphere’s and camera’s placement in the scene. The first is from the origin with the sphere centered. The second the sphere and camera is moved to [-500, 500, 500].
Please take a look and let me know if I am incorrect or if there is a fix for this as it makes this aov unusable.
Capture_1
Capture_2
import omni
import omni.isaac.core.utils.stage as stage_utils
import numpy as np
await stage_utils.create_new_stage_async()
distance = 500
cube_scale = 5
camera = rep.create.camera(position=(-distance + 10, distance, distance), rotation=(0, 0, 0), focal_length=20, projection_type="pinhole")
sphere = rep.create.sphere(position=(-distance, distance, distance), scale=cube_scale)
rp = rep.create.render_product(camera, (512, 512))
rep.settings.set_render_pathtraced()
world_position = rep.annotators.get("PtWorldPos")
world_position.attach(rp)
await rep.orchestrator.step_async()
ray_world_pos_data = world_position.get_data()
Another bug. Enabling depth32BitAov will destroy the depth aov. Seems like 32 to 16 bit overflow?
import omni
import numpy as np
import carb
carb.settings.get_settings().set("/rtx/pathtracing/depth32BitAov", True)
distance = 500
cube_scale = 5
world_position = rep.annotators.get("PtZDepth", device="cpu")
I was able to “fix” the PtZDepth by re-registering it with the annotator registry however I would still classify this as a bug. I am still unable to find a solution to the first question about the PtWorldPos aov.
import omni
import numpy as np
import carb
from omni.replicator.core.scripts.annotators import AnnotatorRegistry
AnnotatorRegistry.register_annotator_from_aov("PtZDepth", output_data_type=np.float32, output_channels=4)
distance = 500
cube_scale = 5
pos = (-distance, distance, distance)
    position=(pos[0] + 10, pos[1], pos[2]), rotation=(0, 0, 0), focal_length=20, projection_type="pinhole"
sphere = rep.create.sphere(position=pos, scale=cube_scale)
depth_anon= rep.annotators.get("PtZDepth", device="cpu")  # PtZDepth
depth_anon.attach(rp)
depth_data = depth_anon.get_data()
Bumping. Still haven’t found a solution to the first bug.
Still no update on this. Seems like a serious bug.
Can I get some confirmation if this is a bug or if there is some way to fix this?
Bump! Trying to render world positions AOV for the Isaac Factory and getting
That seems un-expected – any points in the right direction would be fantastic
