Hello, I am working on obtaining segmented point clouds of objects by randomizing the pose of the object, the robot, and the camera.
However, I have discovered that the ground truth point cloud and the simulated point cloud from the camera do not match.
Here is a video of my setup. (You can skip it if you need)
I realized that a mismatch happens when I move the object rapidly.
In reality, I teleport the object & robot pose even faster.
The fundamental problem is that the point cloud acquisition module in the replicator behaves like a thread. I thought the code was blocking, but it seems not.
Here are my snippets. Could you please see the comments on the main function?
class PointCloudGenerator():
def __init__(self, object="001_chips_can"):
path = os.path.dirname(os.path.abspath(__file__))
self.object_name = object
self.object_usd_path = os.path.join(path, f"ycb/{self.object_name}/google_64k/_converted/textured_obj.usd")
self.robot_usd_path = os.path.join(path, "robot/Panda.usd")
self.full_pcd_path = os.path.join(path, f"ycb/{self.object_name}/google_64k/nontextured.ply")
self.full_pcd_array = self.load_point_cloud_from_ply(self.full_pcd_path)
self.full_pcd_array = self.downsample_point_cloud(self.full_pcd_array, 500)
def add_camera(self):
self.camera = self.stage.DefinePrim("/World/Camera", "Camera")
if not self.camera.GetAttribute("xformOp:translate"):
UsdGeom.Xformable(self.camera).AddTranslateOp()
if not self.camera.GetAttribute("xformOp:orient"):
UsdGeom.Xformable(self.camera).AddOrientOp()
self.render_product = rep.create.render_product(str(self.camera.GetPath()), (self.cam_intrinsic_width, self.cam_intrinsic_height))
self.rgb_annotator = rep.AnnotatorRegistry.get_annotator("rgb")
self.pcd_annotator = rep.AnnotatorRegistry.get_annotator("pointcloud", init_params={"includeUnlabelled": False})
self.rgb_annotator.attach([self.render_product])
self.pcd_annotator.attach([self.render_product])
rep.orchestrator.step()
horizontal_aperture = self.cam_intrinsic_fx / self.cam_intrinsic_width
vertical_aperture = self.cam_intrinsic_fy / self.cam_intrinsic_height
self.camera.GetAttribute("focusDistance").Set(self.cam_intrinsic_focus_distance)
self.camera.GetAttribute("focalLength").Set(self.cam_intrinsic_fx / self.cam_intrinsic_width)
self.camera.GetAttribute("horizontalAperture").Set(horizontal_aperture)
self.camera.GetAttribute("verticalAperture").Set(vertical_aperture)
self.camera.GetAttribute("clippingRange").Set((0.1, 1000))
self.camera.GetAttribute("clippingPlanes").Set(np.array([1.0, 0.0, 1.0, 1.0]))
def get_pcd(self):
# https://docs.omniverse.nvidia.com/extensions/latest/ext_replicator/annotators_details.html#point-cloud
return self.pcd_annotator.get_data(device="cpu") # "cuda" why don't work?
def main(self):
self.load_world()
self.add_light()
self.add_camera()
if self.debugging:
self._debug_create_point_1(self.full_pcd_array, points_path="/World/Points", color=(1, 0, 0))
self._debug_create_point_2(self.full_pcd_array)
self._debug_plot_point_clouds_init()
self.world.reset()
while simulation_app.is_running():
self.world.step(render=True)
if self.world.is_playing():
if self.world.current_time_step_index == 0:
self.world.reset()
else:
cam_spherical_pose = self.randomize_cam_spherical_position()
cam_position, cam_orientation = self.sperical_to_cartesian(cam_spherical_pose)
self.move_camera(cam_position, cam_orientation)
self.move_light(cam_position)
object_position = self.randomize_object_cartesian_position()
if self.enable_randomize_object_orientation:
object_orientation = self.randomize_orientation()
else:
object_orientation = np.array([1.0, 0.0, 0.0, 0.0])
self.move_object(object_position, object_orientation)
if self.enable_robot:
robot_position = object_position + np.array([0, 0, 0.1])
robot_orientation = self.randomize_hemisphere_orientation()
self.move_robot(robot_position, robot_orientation)
# 2. THEREFORE, I need to query them like self.take_pictures()
sim_pcd = self.get_pcd() # 1. HERE, THE FUNCTION IS NON-BLOCKING!
if not len(sim_pcd["data"]):
continue
sim_pcd_object = sim_pcd["data"][sim_pcd["info"]["pointSemantic"]==3, :]
if not len(sim_pcd_object):
continue
sim_pcd_robot = sim_pcd["data"][sim_pcd["info"]["pointSemantic"]==2, :]
if not len(sim_pcd_robot):
continue
if len(sim_pcd_object) > 500:
sim_pcd_object = self.downsample_point_cloud(sim_pcd_object, 500)
if len(sim_pcd_robot) > 500:
sim_pcd_robot = self.downsample_point_cloud(sim_pcd_robot, 500)
sim_rgb = self.get_rgb()
object_position, object_orientation = self.get_object_pose()
full_pcd = self.move_full_pcd(self.full_pcd_array, object_position, object_orientation)
self.data_saver.save_image(sim_rgb)
collect_data = {"sim_pcd_object": sim_pcd_object,
"sim_pcd_robot": sim_pcd_robot,
"full_pcd": full_pcd,
"cam_sperical_pos": cam_spherical_pose,
"cam_position": cam_position,
"cam_orientation": cam_orientation,
"object_position": object_position,
"object_orientation": object_orientation,
"fx": self.cam_intrinsic_fx,
"fy": self.cam_intrinsic_fy,
"cx": self.cam_intrinsic_cx,
"cy": self.cam_intrinsic_cy,
"focus_distance": self.cam_intrinsic_focus_distance,
"width": self.cam_intrinsic_width,
"height": self.cam_intrinsic_height,
self.data_saver.save_data(collect_data)
if self.debugging:
self._debug_update_point_1(full_pcd)
self._debug_update_point_2(sim_pcd_object)
self._debug_plot_point_clouds_update(sim_pcd_object, sim_pcd_robot, full_pcd)
self.data_saver.close()
simulation_app.close()
I have considered using a rendering time step (rending_dt) five times smaller than the physics time step (physics_dt), but I still see the potential for issues. Can I update the camera’s point cloud data and RGB data in a blocking manner at the time I want?
