I’ve tried to use pwm1 but fail, our carrier board use the same pin (H52) as pwm1 function too.
In our devicetree, I simply set &tegra_pwm1 { status = okay; }; and I can find it at /sys/class/devices.
The following steps for testing pwm1:
- cd /sys/class/pwm/pwmchip0
- echo 0 > export
- cd pwm0
- echo 1000000 > period
- echo 500000 > duty_clock
- echo 1 > enable
After that, I still don’t see any signals at my Oscilloscope(monitoring pin H52), please help us.
thanks,
hello evanic.chen,
according to NVIDIA Jetson AGX Xavier GPIO Header Pinout, you’re using GPIO27_PWM2.
could you please have an alternative way to control it as GPIO pin.
thanks
$ cd /sys/class/gpio
$ echo 393 > export
$ cd gpio393
Hi Jerry,
Do I need to set H52 back to gpio function ?
thanks,
Hi Jerry,
I didn’t set H52 back to gpio and I follow your step, I set direction as output and when I echo 1 to value,
it at low, when I echo 0 to value, it at high(3.3v)
thanks,
I tried the pwm-fan on demo carrier board, when the temperature rises to 50 degrees then fan start to run. So I check the register value of pwm4 by cat /sys/kernel/debug/tegra_pinctrl_reg | grep pwm4, I found the value of it was 0x00000400 but the value of soc_gpio54_pn1 was 0x00000054. Does it mean that pin H52 didn’t set to pwm function ?
I install busybox and use the following command to try to make the value of register of pwm1 as same as pwm4.
busybox devmem 0x02440020 32 0x00000400
And then I test the pwmchip0 as I describe before again, but I still can’t get any signals at my Oscilloscope.
Any update ?
thanks
hello evanic.chen,
please apply below two kernel patches in the attachment, Topic1049335_Apr17.tar.gz
thanks
Topic1049335_Apr17.tar.gz (1.51 KB)
evanic.chen,
I also wonder if you need to change the pinmux of soc_gpio54_pn1. It seems being set to rsvd in jetpack release.
pinmux.0x02440020 = 0x00000414; # soc_gpio54_pn1: rsvd0, pull-down, tristate-enable, input-disable
I’ve tried the new patch, it didn’t work.
Recent finds that if I set register 0x02440020 to 0x00000402, pwm function works. But if I modified the value of 0x02440020 at tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg. When kernel boot, the system will crash, I guess this pin can’t be set to pwm before kernel boot, maybe some driver use it as gpio ?
