Hello everyone,
I am working on an external FPGA-CSI2 camera to stream video using OV5693 driver. I was succeeded on TX1 running L4T 28.2 and I could get the video from the camera.
The problem is, TX1 is now obsolete and I am trying to do the same thing on TX2-4GB and because TX2-4GB is not supporting L4T 28.2, most of the things were changed in L4T 32.4.4 and I could not managed to do it.
Here’s what I changed:
Added RGB support in camera_common.c:
MEDIA_BUS_FMT_RGB888_1X24,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_RGB24,
In csi4_stream_init function of csi4_fops.c, I removed these lines:
csi4_stream_write(chan, port_num, INTR_MASK, 0x0);
csi4_stream_write(chan, port_num, ERR_INTR_MASK, 0x0);
And added these:
csi4_stream_write(chan, port_num, INTR_MASK, PH_ECC_MULTI_BIT_ERR | PD_CRC_ERR_VC0 | PH_ECC_SINGLE_BIT_ERR_VC0); csi4_stream_write(chan, port_num, ERR_INTR_MASK, PH_ECC_MULTI_BIT_ERR | PD_CRC_ERR_VC0 | PH_ECC_SINGLE_BIT_ERR_VC0); csi4_stream_write(chan, port_num, ERROR_STATUS2VI_MASK, CFG_ERR_STATUS2VI_MASK_VC0 | CFG_ERR_STATUS2VI_MASK_VC1 | CFG_ERR_STATUS2VI_MASK_VC2 | CFG_ERR_STATUS2VI_MASK_VC3);
In sensor_common.c, added rgb support in extract_pixel_format function
else if (strncmp(pixel_t, "rgb_rgb8", size) == 0) *format = V4L2_PIX_FMT_RGB24;
In ov5693.c, I made these functions do nothing and just return success:
ov5693_read_reg,
ov5693_write_reg,
ov5693_write_table,
ov5693_power_on,
ov5693_power_off,
ov5693_power_put,
ov5693_power_get,
ov5693_set_gain,
ov5693_set_exposure,
ov5693_set_exposure_short.
In tegra186-quill-p3489-0888-a00-00-base.dts, I removed support for camera modules and plugin manager and included my own camera’s device tree:
#include <t18x-common-platforms/tegra186-quill-common-p3489-1000-a00.dtsi> #include <t18x-common-platforms/tegra186-quill-power-tree-p3489-1000-a00-00.dtsi> //#include <t18x-common-platforms/tegra186-quill-camera-modules.dtsi> #include <t18x-common-modules/tegra186-display-e3320-1000-a00.dtsi> /* comms dtsi file should be included after gpio dtsi file */ #include <t18x-common-plugin-manager/tegra186-quill-p3489-1000-a00-plugin-manager.dtsi> #include <t18x-common-modules/tegra186-super-module-e2614-p2597-1000-a00.dtsi> #include <t18x-common-plugin-manager/tegra186-quill-display-plugin-manager.dtsi> #include <t18x-common-prod/tegra186-priv-quill-p3489-1000-a00-prod.dtsi> //#include <t18x-common-plugin-manager/tegra186-quill-camera-plugin-manager.dtsi> /* My camera support */ #include <tegra186-camera-e3326-a00.dtsi>
In device tree file “tegra186-camera-e3326-a00.dtsi”, which I included in the base dts file, I just modified the fields like what I did in the TX1:
#include "dt-bindings/clock/tegra186-clock.h"
#define CAM0_RST_L TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN TEGRA_MAIN_GPIO(R, 0)
host1x {
vi@15700000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
e3326_vi_in0: endpoint {
//vc-id = <0>;
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&e3326_csi_out0>;
nvcsi@150c0000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
e3326_csi_in0: endpoint@0 {
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&e3326_ov5693_out0>;
port@1 {
status = "okay";
reg = <1>;
e3326_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&e3326_vi_in0>;
i2c@3180000 {
ov5693_c@36 {
compatible = "nvidia,ov5693";
/* I2C device address */
reg = <0x36>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
/* Sensor output flip settings */
vertical-flip = "true";
status = "okay";
/* mclk-index indicates the index of the */
/* mclk-name with in the clock-names array */
clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
clock-frequency = <24000000>;
reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
vana-supply = <&en_vdd_cam_hv_2v8>;
vif-supply = <&en_vdd_cam>;
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = "";
* max_framerate = "";
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
mode0 { //OV5693_MODE_1280X720
mclk_khz = "74250";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no"; // degistirdim
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
mode_type = "rgb";
pixel_phase = "rgb";
csi_pixel_bit_depth = "8";
readout_orientation = "90";
line_length = "1980";
inherent_gain = "1";
mclk_multiplier = "1";
pix_clk_hz = "74250000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
framerate_factor = "1000000";
min_framerate = "45";/* 45 */
max_framerate = "60";/* 60*/ //
step_framerate = "1";
default_framerate = "50"; //
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "8334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_ov5693_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&e3326_csi_in0>;
e3326_lens_ov5693@P5V27C {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "2.67";
f_number = "2.0";
aperture = "2.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3326_front_P5V27C";
position = "rear";
orientation = "1";
status = "okay";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "ov5693 2-0036";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_c@36";
drivernode1 {
status = "okay";
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/e3326_lens_ov5693@P5V27C/";
After I try to get image from /dev/video0 by using this command,
gst-launch-1.0 v4l2src device=/dev/video0 ! videorate max-rate=50 ! videoconvert ! omxh265enc qp-range=30,50:30,50:30,50 control-rate=4 bitrate=3000000 ! "video/x-h265, stream-format=(string)byte-stream" ! rtph265pay mtu=1400 ! udpsink host=192.168.1.5 port=5700 sync=false async=false
I see that error on dmesg and get no video stream:
[ 202.839975] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 202.846549] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 203.895893] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 203.902330] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 204.951990] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 204.958568] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
What should I inspect first, what am I missing? Any suggestions?
