The fpga and the dtb can be used on nano. But it shows error PXL_SOF syncpt timeout! err = -11 on tx2nx,here is my dtsi:
host1x {
vi@15700000 {
num-channels = <1>;
status = “okay”;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0:port@0 {
status = “okay”;
reg = <0>;
e2832_vi_in0: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&e2832_csi_out0>;
nvcsi@150c0000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan0:channel@0 {
status = “okay”;
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0:port@0 {
status = “okay”;
reg = <0>;
e2832_csi_in0: endpoint@0 {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&e2832_out0>;
csi_chan0_port1:port@1 {
status = “okay”;
reg = <1>;
e2832_csi_out0: endpoint@1 {
remote-endpoint = <&e2832_vi_in0>;
i2c@3190000 {
e2832@2b {
compatible = “nvidia,lt6911uxc”;
/* I2C device address */
reg = <0x2b>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "e2832";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
/*post_crop_frame_drop = "0";*/
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
* num_of_exposure = "";
* Digital overlap(Dol) frames
* num_of_ignored_lines = "";
* Used for cropping, eg. OB lines + Ignored area of effective pixel lines
* num_of_lines_offset_0 = "";
* Used for cropping, vertical blanking in front of short exposure data
* If more Dol frames are used, it can be extended, eg. num_of_lines_offset_1
* num_of_ignored_pixels = "";
* Used for cropping, The length of line info(pixels)
* num_of_left_margin_pixels = "";
* Used for cropping, the size of the left edge margin before
* the active pixel area (after ignored pixels)
* num_of_right_margin_pixels = "";
* Used for cropping, the size of the right edge margin after
mode0 { // E2832_1920x1080_60Fps
mclk_khz = "27000";
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "rgb";
pixel_phase = "rgb888";
csi_pixel_bit_depth = "24";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "148500000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "16667"; /* us */
ports {
status = "okay";
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_out0: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&e2832_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e2832_ltx6911";
position = "bottom";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "e2832 2-002b";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3190000/e2832@2b";
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, lt6911uxc 3-002b
Bus info : platform:15700000.vi:2
Driver version: 4.9.253
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 2: no power)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘AR24’
Field : None
Bytes per Line : 7680
Size Image : 8294400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
fpga sends signals automatically. I use csi4 and 4lanes.
I don’t use
// #include "common/tegra186-super-module-e2614-p3509-0000-a00.dtsi"
// #include "common/tegra186-camera-lanai-rbpcv2-imx219.dtsi"
// #include "tegra186-p3636-plugin-manager.dtsi"
