tx2 csi2 receive yuv422 data error
Hi, all:
I have issue with our custom camera.
we use csi0-D0/csi0-D1/csi1-D0/csi0-D1, total 4 lane.
the cmos output is yuv422 8bit.
I use cammand:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10
the app log as below:
VIDIOC_DQBUF: failed: Input/output error
the kernel log as below:
[   42.493665] xiaolei --- ar0231_power_on
[   42.497633] ar0231_power_on: power on
[   42.511867] xiaolei --- ar0231_g_input_status
[   42.517838] xiaolei --- ar0231_power_off
[   42.522005] ar0231_power_off: power off
[   66.048640] xiaolei --- ar0231_power_on
[   66.052647] ar0231_power_on: power on
[   66.066541] xiaolei --- ar0231_set_fmt
[   66.070460] xiaolei --- ar0231_set_fmt
[   66.083846] xiaolei --- ar0231_get_fmt
[   66.093610] xiaolei --- ar0231_s_stream
[   66.097576] ar0231_s_stream++,enable:1
[   66.101363] ar0231_s_stream mode[0]
[   66.404942] xiaolei --- ar0231_write_table
[   66.409142] xiaolei --- ar0231_write_table
[   66.430529] tegra-vi4 15700000.vi: Status:  7 channel:00 frame:000A
[   66.436953] tegra-vi4 15700000.vi:          timestamp sof 72341553152 eof 72351173120 data 0x00000001
[   66.446352] tegra-vi4 15700000.vi:          capture_id 1 stream  0 vchan  0
[   67.418046] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[   68.422026] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[   68.428088] xiaolei --- ar0231_s_stream
[   68.432147] ar0231_s_stream++,enable:0
the trace as below:
# tracer: nop
# entries-in-buffer/entries-written: 44/44   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:1-58    [000] ...1    66.097960: rtos_queue_peek_from_isr_failed: tstamp:2250357107 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    66.097970: rtcpu_start: tstamp:2250359296
     kworker/0:1-58    [000] ...1    66.253991: rtos_queue_peek_from_isr_failed: tstamp:2255358060 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    66.462000: rtos_queue_peek_from_isr_failed: tstamp:2260358548 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    66.462012: rtcpu_vinotify_handle_msg: tstamp:2260674117 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:2260673536 data:0x00000001
     kworker/0:1-58    [000] ...1    66.462015: rtcpu_vinotify_handle_msg: tstamp:2260674371 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:2260673551 data:0x00000000
     kworker/0:1-58    [000] ...1    66.462017: rtcpu_vinotify_handle_msg: tstamp:2260679288 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:2260678850 data:0x08000000
     kworker/0:1-58    [000] ...1    66.462019: rtcpu_vinotify_handle_msg: tstamp:2260974770 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:10 vi_tstamp:2260974160 data:0x00000001
     kworker/0:1-58    [000] ...1    66.462021: rtcpu_vinotify_handle_msg: tstamp:2260975026 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:2260974160 data:0x00000000
     kworker/0:1-58    [000] ...1    66.617999: rtos_queue_peek_from_isr_failed: tstamp:2265359121 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    66.774025: rtos_queue_peek_from_isr_failed: tstamp:2270359625 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    66.929992: rtos_queue_peek_from_isr_failed: tstamp:2275360068 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.085993: rtos_queue_peek_from_isr_failed: tstamp:2280360573 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.242027: rtos_queue_peek_from_isr_failed: tstamp:2285361081 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.398003: rtos_queue_peek_from_isr_failed: tstamp:2290361646 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.554013: rtos_queue_peek_from_isr_failed: tstamp:2295362094 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.709993: rtos_queue_peek_from_isr_failed: tstamp:2300362602 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    67.866010: rtos_queue_peek_from_isr_failed: tstamp:2305363108 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    68.021977: rtos_queue_peek_from_isr_failed: tstamp:2310363616 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    68.177986: rtos_queue_peek_from_isr_failed: tstamp:2315364135 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    68.333994: rtos_queue_peek_from_isr_failed: tstamp:2320364629 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    68.440553: rtos_queue_peek_from_isr_failed: tstamp:2323399345 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    80.761935: rtos_queue_peek_from_isr_failed: tstamp:2707500156 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    80.761938: rtcpu_start: tstamp:2707501082
     kworker/0:2-247   [000] ...1    80.917944: rtos_queue_peek_from_isr_failed: tstamp:2712501002 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.081956: rtos_queue_peek_from_isr_failed: tstamp:2717501501 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.081961: rtcpu_vinotify_handle_msg: tstamp:2717728365 tag:CHANSEL_PXL_SOF channel:0x00 frame:113 vi_tstamp:2717727833 data:0x00000001
     kworker/0:2-247   [000] ...1    81.081961: rtcpu_vinotify_handle_msg: tstamp:2717728523 tag:ATOMP_FS channel:0x00 frame:113 vi_tstamp:2717727848 data:0x00000000
     kworker/0:2-247   [000] ...1    81.081962: rtcpu_vinotify_handle_msg: tstamp:2717730594 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:113 vi_tstamp:2717730193 data:0x08000000
     kworker/0:2-247   [000] ...1    81.081962: rtcpu_vinotify_handle_msg: tstamp:2718030245 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:113 vi_tstamp:2718029674 data:0x00000001
     kworker/0:2-247   [000] ...1    81.081963: rtcpu_vinotify_handle_msg: tstamp:2718030429 tag:ATOMP_FE channel:0x00 frame:113 vi_tstamp:2718029674 data:0x00000000
     kworker/0:2-247   [000] ...1    81.237958: rtos_queue_peek_from_isr_failed: tstamp:2722502027 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.393930: rtos_queue_peek_from_isr_failed: tstamp:2727502532 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.549945: rtos_queue_peek_from_isr_failed: tstamp:2732503020 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.705939: rtos_queue_peek_from_isr_failed: tstamp:2737503526 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    81.861986: rtos_queue_peek_from_isr_failed: tstamp:2742504083 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.017986: rtos_queue_peek_from_isr_failed: tstamp:2747504587 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.173965: rtos_queue_peek_from_isr_failed: tstamp:2752505092 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.330122: rtos_queue_peek_from_isr_failed: tstamp:2757505600 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.485981: rtos_queue_peek_from_isr_failed: tstamp:2762506105 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.642035: rtos_queue_peek_from_isr_failed: tstamp:2767506668 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    82.849953: rtos_queue_peek_from_isr_failed: tstamp:2772507076 queue:0x0b4a3c58
     kworker/0:2-247   [000] ...1    83.005942: rtos_queue_peek_from_isr_failed: tstamp:2777507583 queue:0x0b4a3c58
     kworker/0:1-58    [000] ...1    83.059635: rtos_queue_peek_from_isr_failed: tstamp:2780516172 queue:0x0b4a3c58
the dtsi as below:
#include <t18x-common-modules/tegra186-camera-ar0231-a00.dtsi>
#include "dt-bindings/clock/tegra186-clock.h"
#define CAM0_RST_L      TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN       TEGRA_MAIN_GPIO(R, 0)
#define CAM1_RST_L      TEGRA_MAIN_GPIO(R, 1)
#define CAM1_PWDN       TEGRA_MAIN_GPIO(L, 6)
#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
        host1x {
                vi@15700000 {
                        num-channels = <1>;
                        ports {
                                #address-cells = <1>;
                                #size-cells = <0>;
                                port@0 {
                                        reg = <0>;
                                        liar0231_vi_in0: endpoint {
                                                csi-port = <0>;
                                                bus-width = <4>;
                                                remote-endpoint = <&liar0231_csi_out0>;
                nvcsi@150c0000 {
                        num-channels = <1>;
                        #size-cells = <0>;
                        channel@0 {
                                reg = <0>;
                                ports {
                                        #size-cells = <0>;
                                        port@0 {
                                                reg = <0>;
                                                liar0231_csi_in0: endpoint@0 {
                                                        csi-port = <0>;
                                                        bus-width = <4>;
                                                        remote-endpoint = <&liar0231_ar0231_out0>;
                                        port@1 {
                                                reg = <1>;
                                                liar0231_csi_out0: endpoint@1 {
                                                        remote-endpoint = <&liar0231_vi_in0>;
        tegra-camera-platform {
                compatible = "nvidia, tegra-camera-platform";
                * Physical settings to calculate max ISO BW
                * num_csi_lanes = <>;
                * Total number of CSI lanes when all cameras are active
                * max_lane_speed = <>;
                * Max lane speed in Kbit/s
                * min_bits_per_pixel = <>;
                * Min bits per pixel
                * vi_peak_byte_per_pixel = <>;
                * Max byte per pixel for the VI ISO case
                * vi_bw_margin_pct = <>;
                * Vi bandwidth margin in percentage
                * max_pixel_rate = <>;
                * Max pixel rate in Kpixel/s for the ISP ISO case
                * isp_peak_byte_per_pixel = <>;
                * Max byte per pixel for the ISP ISO case
                * isp_bw_margin_pct = <>;
                * Isp bandwidth margin in percentage
                num_csi_lanes = <4>;
                max_lane_speed = <1500000>;
                min_bits_per_pixel = <10>;
                vi_peak_byte_per_pixel = <2>;
                vi_bw_margin_pct = <25>;
                max_pixel_rate = <750000>;
                isp_peak_byte_per_pixel = <5>;
                isp_bw_margin_pct = <25>;
                 * The general guideline for naming badge_info contains 3 parts, and is as follows,
                 * The first part is the camera_board_id for the module; if the module is in a FFD
                 * platform, then use the platform name for this part.
                 * The second part contains the position of the module, ex. "rear" or "front".
                 * The third part contains the last 6 characters of a part number which is found
                 * in the module's specsheet from the vender.
                modules {
                        module2 {
                                badge = "ar0231_center_liar0231";
                                position = "center";
                                orientation = "1";
                                drivernode0 {
                                        /* Declare PCL support driver (classically known as guid)  */
                                        pcl_id = "v4l2_sensor";
                                        /* Driver v4l2 device name */
                                        devname = "ar0231 30-006a";
                                        /* Declare the device-tree hierarchy to driver instance */
                                        proc-device-tree = "/proc/device-tree/i2c@c240000/ar0231_a@6a";
&gen2_i2c {
        status = "okay";
        ar0231_a@6a {
                compatible = "nvidia,ar0231";
                /* I2C device address */
                reg = <0x6a>;
                /* Define any required hw resources needed by driver */
                /* ie. clocks, io pins, power sources */
                clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
                                 <&tegra_car TEGRA186_CLK_PLLP_OUT0>;
                clock-names = "extperiph1", "pllp_grtba";
                mclk = "extperiph1";
                reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
                vana-supply = <&en_vdd_cam_hv_2v8>;
                vif-supply = <&en_vdd_cam>;
                vdig-supply = <&en_vdd_cam_1v2>;
                /* V4L2 device node location */
                devnode = "video0";
                /* Physical dimensions of sensor */
                physical_w = "3";
                physical_h = "3";
                avdd-reg = "vana";
                iovdd-reg = "vif";
                dvdd-reg = "vdig";
                /* Defines number of frames to be dropped by driver internally after applying */
                /* sensor crop settings. Some sensors send corrupt frames after applying */
                /* crop co-ordinates */
                /*post_crop_frame_drop = "0";*/
                /* if true, delay gain setting by one frame to be in sync with exposure */
                delayed_gain = "true";
                * A modeX node is required to support v4l2 driver
                * implementation with NVIDIA camera software stack
                * mclk_khz = "";
                * Standard MIPI driving clock, typically 24MHz
                * num_lanes = "";
                * Number of lane channels sensor is programmed to output
                * tegra_sinterface = "";
                * The base tegra serial interface lanes are connected to
                * discontinuous_clk = "";
                * The sensor is programmed to use a discontinuous clock on MIPI lanes
                * dpcm_enable = "true";
                * The sensor is programmed to use a DPCM modes
                * cil_settletime = "";
                * MIPI lane settle time value.
                * A "0" value attempts to autocalibrate based on mclk_multiplier
                * active_w = "";
                * Pixel active region width
                * active_h = "";
                * Pixel active region height
                * pixel_t = "";
                * The sensor readout pixel pattern
                * readout_orientation = "0";
                * Based on camera module orientation.
                * Only change readout_orientation if you specifically
                * Program a different readout order for this mode
                * line_length = "";
                * Pixel line length (width) for sensor mode.
                * This is used to calibrate features in our camera stack.
                * mclk_multiplier = "";
                * Multiplier to MCLK to help time hardware capture sequence
                * TODO: Assign to PLL_Multiplier as well until fixed in core
                * pix_clk_hz = "";
                * Sensor pixel clock used for calculations like exposure and framerate
                * inherent_gain = "";
                * Gain obtained inherently from mode (ie. pixel binning)
                * min_gain_val = ""; (floor to 6 decimal places)
                * max_gain_val = ""; (floor to 6 decimal places)
                * Gain limits for mode
                * min_exp_time = ""; (ceil to integer)
                * max_exp_time = ""; (ceil to integer)
                * Exposure Time limits for mode (us)
                * min_hdr_ratio = "";
                * max_hdr_ratio = "";
                * HDR Ratio limits for mode
                * min_framerate = "";
                * max_framerate = "";
                * Framerate limits for mode (fps)
                * embedded_metadata_height = "";
                * Sensor embedded metadata height in units of rows.
                * If sensor does not support embedded metadata value should be 0.
                mode0 { // AR0231_MODE_1920X1080
                        mclk_khz = "27000";
                        num_lanes = "4";
                        discontinuous_clk = "no";
                        dpcm_enable = "false";
                        cil_settletime = "0";
                        dynamic_pixel_bit_depth = "8";
                        csi_pixel_bit_depth = "8";
                        mode_type = "yuv";
                        pixel_phase = "yuyv";
                        active_w = "1280";
                        active_h = "720";
                        //pixel_t = "bayer_grbg";
                        line_length = "1280";
                        inherent_gain = "1";
                        mclk_multiplier = "25";
                        pix_clk_hz = "39125546";
                        min_gain_val = "1"; /* dB */
                        max_gain_val = "48"; /* dB */
                        min_hdr_ratio = "1";
                        max_hdr_ratio = "1";
                        min_framerate = "6";
                        max_framerate = "30";
                        min_exp_time = "110";
                        max_exp_time = "166577";
                        embedded_metadata_height = "0";
                ports {
                        #size-cells = <0>;
                        port@0 {
                                reg = <0>;
                                liar0231_ar0231_out0: endpoint {
                                        csi-port = <0>;
                                        bus-width = <4>;
                                        remote-endpoint = <&liar0231_csi_in0>;
Do you have any idea about this?
The trace log show the resolution (high) not as expect. “CHANSEL_SHORT_FRAME”
I modified the height and width, but still the same err info.
Can you explain in more detail?
You sensor output more line as your driver report.
You can reduce the high report by sensor driver one by one to try.
