Now TX2 CSI chrome sensor driver transmit color video data,if sensor resolution is 1920X1080 in RGGB mode,there are 1920X480 R data,1920X480 B data and 1920X960 G data transmit from sensor to tx2,and then isp in tx2 make bayer interpolation,then there are 1920X1080 RGB data,Do I have an exact understanding?
If right,My sensor is monochrome sensor,use method in the above can’t get right video,So what am I supposed to do?
that’s not correct.
ISP handle sensor bayer formats by having process. such as, demosaic, black level, len shading, tone map…etc.
then, ISP output fill-in buffers with YUV formats.
we don’t support ISP to directly output RGB planar formats,
so far (l4t-r32.2), we also don’t support monochrome sensor as ISP input sensors.
you may check below kernel drivers, please have implementation to extend the support formats. $l4t-r32.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
$l4t-r32.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
suggest you also check similar discussion thread, Topic 1036708 for reference.
thanks
Thank you for your reply, under your suggestion I read Camera Architecture Stack.
In the Camera Architecture Stack,Video data from sensor, goto V4l2 Device Driver frist.In userspace we can get the data from tegra Driver or V4l Mediacontroller,But if get data from V4l MediaController we can skip ISP.
So if I use v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10 --stream-to=test.raw .File test.raw is original sensor data without bayer interpolation?
according to Camera Architecture Stack, you can consider bypass [Camera Core] software block as ISP skipped.
both v4l2-ctl and v4l2src were accessing your camera device with low-level VI drivers.
suggest you could also check TX2’s VI kernel sources for reference,
for example, $l4t-r32.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi4_fops.c
I modify the drivers ov5693.c,so TX2 can grab data from FPGA by CSI.
Then use FPGA send video pixel data 0x00 0x10 0x20 0x30 0x40…0xF0 repeatedly and continuously.
Use v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw To grab a frame data.
The size of raw file is 4147200=192010802*8,it looks like a pixel is 16bit.
SoI use hexdump -C -n 1000 test.raw to view the raw data as follow
The data precies match the TX2 TRM NVIDIA Parker Series SoC 27.10.6 RAW Memory Formats for RAW10, RAW12 and RAW14", where RAW10 pixels are shown written in memory as
Thank you for your reply.
I think you may be misled by me.
Actually the data I sent use FPGA by csi is 10bit ,Just Becase I only use 8bit,so low 2bit always send 0.
And I think my bytes-per-line is right.If not TX2 should be received nothing because of the size of receive and send is different.
And the most important thing is the pixel value of recieved is match pixel value of send.
My image size is 1920X1080
I accidentally changed the CSI transmission frequency of the FPGA side from the original 900Mhz to 1200Mhz today, and the image received by the TX2 is completely normal. And regardless of the transmission frequency of the CSI, the image is normal in the Y direction. At 900Mhz, the image looks like the 1280 pixels in front of the X direction are interpolated 1.5 times, the last 720 pixels are lost, and the line length is still 1920. Of course, if the frequency is changed to 600Mhz, the image looks like the 960 pixels in front of the X direction are interpolated 1.5 times, the last 960 pixels are lost, and the line length is still 1920.
Why?
according to Sensor Software Driver Programming Guide, the sensor pixel clock must correct.
due to camera software stack uses the sensor pixel clock to calculate the exposure, frame rate, and also avoid potential issues.
your sensor device tree settings (i.e. active_w and active_h) also important for the camera stack to allocate the buffer for active pixels.
thanks
according to Sensor Software Driver Programming Guide, pixel_clk_hz = sensor data rate per lane (Mbps) * number of lanes / bits per pixel,My sensor data rate per lane (Mbps) is 800Mhz,in 2 lane mode ,and 10 bits per pixel ,so my pix_clk_hz = “160000000” is right.but In fact,the sensor data rate per lane should set to 1200Mhz,then I can get the right Image
we usually use these three different formulas to calculate the sensor pixel clock.
suggest you may also contact with your sensor vendor to ensure the settings of data-per-lane.
thanks
got it. so you’re able to make the sensor streaming working with data-per-lane=1200MHz.
anything else in this topic still waiting for clarification.
thanks
According to your statement, I changed the DTC file, but it seems that there is no change. In the modification of the CSI pixel clock, do I need to change other files?
According to your statement, I changed the DTC and ov5693.c file, but it seems that there is no change. In the modification of the CSI pixel clock, do I need to change other files?
Besides,
we also have kernel driver update to deprecate the pixel_t property.
please replace it with the following properties instead. mode_type, csi_pixel_bit_depth, and pixel_phase.
thanks
I use sudo ./flash.sh jetson-tx2 mmcblk0p1 update the whole flash.
In fact, because of the CSI-D built by the resistance bridge I used, the frequency of CSI can’t work at 1200Mhz for a long time, so I want to lower the frequency.
I have so many questions
1, is not it is not necessary to change ov5693.c, directly change the DTB file just fine
2, I use 2-lane, then pixel clock is multiplied by 2 for each lane, or not
Ok,Let me reorganize the process of modification.
I try use TX2 grad data from XILINX FPGA CSI-TX。
Change DTB file close plugin maneger and use main platform device tree file tegra186-quill-camera-modules.dtsi like this and I try ov5693 module work fine.I use 4 2-lane csi.
host1x {
vi@15700000 {
num-channels = <4>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_vi_in0: endpoint {
csi-port = <0>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_out0>;
port@1 {
reg = <1>;
status = "okay";
e7035_vi_in1: endpoint {
csi-port = <1>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_out1>;
port@2 {
reg = <2>;
status = "okay";
e7035_vi_in2: endpoint {
csi-port = <2>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_out2>;
port@3 {
reg = <3>;
status = "okay";
e7035_vi_in3: endpoint {
csi-port = <3>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_out3>;
nvcsi@150c0000 {
num-channels = <4>;
/*#address-cells = <1>;*/
/*#size-cells = <0>;*/
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_csi_in0: endpoint@0 {
csi-port = <0>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_ov5693_out0>;
port@1 {
reg = <1>;
status = "okay";
e7035_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&e7035_vi_in0>;
channel@1 {
reg = <1>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_csi_in1: endpoint@2 {
csi-port = <1>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_ov5693_out1>;
port@1 {
reg = <1>;
status = "okay";
e7035_csi_out1: endpoint@3 {
status = "okay";
remote-endpoint = <&e7035_vi_in1>;
channel@2 {
reg = <2>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_csi_in2: endpoint@4 {
csi-port = <2>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_ov5693_out2>;
port@1 {
reg = <1>;
status = "okay";
e7035_csi_out2: endpoint@5 {
status = "okay";
remote-endpoint = <&e7035_vi_in2>;
channel@3 {
reg = <3>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_csi_in3: endpoint@6 {
csi-port = <3>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_ov5693_out3>;
port@1 {
reg = <1>;
status = "okay";
e7035_csi_out3: endpoint@7 {
status = "okay";
remote-endpoint = <&e7035_vi_in3>;
i2c@3180000 {
status = "okay";
ov5693_a@38 {
compatible = "nvidia,ov5693";
/* I2C device address */
reg = <0x38>;
status = "okay";
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
/* Sensor output flip settings */
vertical-flip = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "2";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "2592";
active_h = "1944";
pixel_t = "bayer_bggr";
readout_orientation = "90";
line_length = "2688";
inherent_gain = "1";
mclk_multiplier = "6.67";
pix_clk_hz = "160000000";
min_gain_val = "1.0";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.816577";
max_framerate = "30";
min_exp_time = "34";
max_exp_time = "550385";
mode1 { //OV5693_MODE_2592X1458
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mode2 { //OV5693_MODE_1280X720
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
line_length = "1752";
min_framerate = "2.787078";
max_framerate = "120";
min_exp_time = "22";
max_exp_time = "358733";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_ov5693_out0: endpoint {
csi-port = <0>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_in0>;
ov5693_b@37 {
reg = <0x37>;
status = "okay";
devnode = "video1";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_b";
active_w = "2592";
active_h = "1944";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_ov5693_out1: endpoint {
csi-port = <1>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_in1>;
ov5693_c@36 {
reg = <0x36>;
status = "okay";
devnode = "video2";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
active_w = "2592";
active_h = "1944";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_ov5693_out2: endpoint {
csi-port = <2>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_in2>;
ov5693_d@35 {
reg = <0x35>;
status = "okay";
devnode = "video3";
avdd-reg = "vana";
iovdd-reg = "vif";
* mclk_khz = "";
* num_lanes = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* pix_clk_hz = "";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_d";
active_w = "2592";
active_h = "1944";
mclk_khz = "24000";
num_lanes = "2";
active_w = "2592";
active_h = "1458";
mclk_khz = "24000";
num_lanes = "2";
active_w = "1280";
active_h = "720";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
e7035_ov5693_out3: endpoint {
csi-port = <3>;
bus-width = <2>;
status = "okay";
remote-endpoint = <&e7035_csi_in3>;
e7035_lens_ov5693@P5V27C {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "2.67";
f_number = "2.0";
aperture = "2.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <8>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e7035_bottom_P5V27C";
position = "topleft";
orientation = "1";
status = "okay";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "ov5693 2-0038";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_a@38";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/e7035_lens_ov5693@P5V27C/";
module1 {
position = "top";
orientation = "1";
status = "okay";
drivernode0 {
devname = "ov5693 2-0037";
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_b@37";
drivernode1 {
module2 {
position = "bottom";
orientation = "1";
status = "okay";
drivernode0 {
devname = "ov5693 2-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_c@36";
drivernode1 {
module3 {
position = "topright";
orientation = "1";
status = "okay";
drivernode0 {
devname = "ov5693 2-0035";
proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_d@35";
drivernode1 {
Then I modify OV5693.c,skip some OTP fuction,so kernel can load the driver.
I use the ./v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test0.raw
I can get a Image,and that look almost right,Except for being enlarged in the X direction.
As you can see from the DTB file, I actually didn’t define the resolution of 1920*1080, but when I used ./v4l2-ctl --all,
default Width/Height is 1920/1080
you’ll need a sensor driver to register the video node (/dev/video0), power-on/off sequence controls, and also I/O controls for sensor streaming.
the answer is yes if you’re based-on ov5693.c to customize your own bridge drivers (i.e. XILINX FPGA CSI-TX).
you’ll need to report the pixel rate of the sensor device.
pixel clock configuration means the total active pixels sending to CSI/VI engine.
did your bridge driver actually sending 1920x1080 sensor streaming?
if yes, suggest you also share the raw files or the image for review the abnormal results.
BTW,
you should also modify the modes property to report correct active regions of each sensor mode.
for example,
ov5693 had three sensor modes by default,
