Hi All,
We are trying for Hdmi 2 csi adapter and wrote the sensor driver.
When testing, got the errors as:
PXL_SOF syncpt timeout! err = -11
The logs as:
[ 1160.828700] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_s_power()
[ 1160.935815] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1160.942342] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1160.953756] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1160.960319] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1160.966678] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_g_input_status():
[ 1160.974300] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_g_input_status: status = 0x0
[ 1160.981945] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_g_input_status():
[ 1160.988281] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_g_input_status: status = 0x0
[ 1160.995819] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1161.002294] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.009351] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.016046] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.042952] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1161.051128] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.057625] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.064395] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1161.070861] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.077478] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_frameintervals()
[ 1161.084190] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_enum_framesizes()
[ 1161.090379] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt():
[ 1161.098077] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt(): width=1920, height=1080, code=0x0000100A, field=1
[ 1161.108560] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_set_fmt():
[ 1161.114248] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt():
[ 1161.119785] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt(): width=1920, height=1080, code=0x0000100A, field=1
[ 1161.129649] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_set_fmt():
[ 1161.135166] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt():
[ 1161.140686] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt(): width=1920, height=1080, code=0x0000100A, field=1
[ 1161.150622] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_set_fmt():
[ 1161.156137] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_set_fmt(): format->which=1
[ 1161.178632] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt():
[ 1161.184224] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_get_fmt(): width=1920, height=1080, code=0x0000200F, field=1
[ 1161.194192] fpga_hdmi2csi 0-003c: sensor_common_parse_control_props:gain_factor:property missing
[ 1161.204151] fpga_hdmi2csi 0-003c: sensor_common_parse_control_props:gain_factor:property missing
[ 1161.213400] fpga_hdmi2csi 0-003c: sensor_common_parse_control_props:gain_factor:property missing
[ 1161.222264] fpga_hdmi2csi 0-003c: sensor_common_parse_control_props:gain_factor:property missing
[ 1161.232080] tegra-vi4 15700000.vi: Create Surface with imgW=1920, imgH=1080, memFmt=203
[ 1161.240888] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 1161.249124] nvcsi 150c0000.nvcsi: csi port:0
[ 1161.253434] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 1161.758882] tegra_mipi_cal 3990000.mipical: Mipi cal timeout,val:8771, lanes:300000
[ 1161.766643] tegra_mipi_cal 3990000.mipical: Fixed clk 68MHz
[ 1161.772258] tegra_mipi_cal 3990000.mipical: MIPI_CAL_CTRL 0x04 0x2a000010
[ 1161.780612] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS 0x0c 0x00008771
[ 1161.788913] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS_2 0x10 0x00000000
[ 1161.797265] tegra_mipi_cal 3990000.mipical: CILA_MIPI_CAL_CONFIG 0x18 0x00200000
[ 1161.805565] tegra_mipi_cal 3990000.mipical: CILB_MIPI_CAL_CONFIG 0x1c 0x00200000
[ 1161.813916] tegra_mipi_cal 3990000.mipical: CILC_MIPI_CAL_CONFIG 0x20 0x00000000
[ 1161.822214] tegra_mipi_cal 3990000.mipical: CILD_MIPI_CAL_CONFIG 0x24 0x00000000
[ 1161.830565] tegra_mipi_cal 3990000.mipical: CILE_MIPI_CAL_CONFIG 0x28 0x00000000
[ 1161.838890] tegra_mipi_cal 3990000.mipical: CILF_MIPI_CAL_CONFIG 0x2c 0x00000000
[ 1161.847242] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG 0x3c 0x00000200
[ 1161.855556] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG 0x40 0x00000200
[ 1161.863919] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG 0x44 0x00000200
[ 1161.872211] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG 0x48 0x00000200
[ 1161.880571] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG0 0x5c 0x00000000
[ 1161.888862] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG1 0x60 0x00000000
[ 1161.897215] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG2 0x64 0x00010010
[ 1161.905505] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG_2 0x68 0x00000002
[ 1161.913846] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG_2 0x6c 0x00000002
[ 1161.922127] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG_2 0x74 0x00000002
[ 1161.930466] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG_2 0x78 0x00000002
[ 1161.938758] nvcsi 150c0000.nvcsi: csi4_start_streaming ports index=0, lanes=4
[ 1161.945962] nvcsi 150c0000.nvcsi: csi4_stream_init
[ 1161.950777] nvcsi 150c0000.nvcsi: csi4_stream_config
[ 1161.955760] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[ 1161.963746] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 1161.968475] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[ 1161.974257] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_s_stream():
[ 1162.978960] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1163.982968] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1164.987002] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1165.990968] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1166.994945] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1167.999008] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1169.002950] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
In trace, we did not see information about the CSI and VI.
Trace logs:
kworker/5:0-35 [005] …1 1379.436713: rtos_queue_peek_from_isr_failed: tstamp:43406487172 queue:0x0b4a3c58
kworker/5:0-35 [005] …1 1379.592742: rtos_queue_peek_from_isr_failed: tstamp:43411487682 queue:0x0b4a3c58
kworker/5:0-35 [005] …1 1379.748708: rtos_queue_peek_from_isr_failed: tstamp:43416487977 queue:0x0b4a3c58
kworker/5:0-35 [005] …1 1379.904726: rtos_queue_peek_from_isr_failed: tstamp:43421488503 queue:0x0b4a3c58
Any ideas.
-Thanks.
