Is there any way to get the distributed PyTorch running or do I need to build it from source? I installed the latest version from the documentation at Installing PyTorch for Jetson Platform - NVIDIA Docs but now I get
>>> import torch
>>> torch.distributed.is_available()
False
When I try to install PyTorch from the torch website then CUDA becomes unavailable.
Also in that documentation the whl file download URL gives a 404.
IIRC the last pre-built PyTorch wheel for JetPack with USE_DISTRIBUTED was PyTorch 1.11:
PyTorch v1.11.0
For newer PyTorch versions that that, you would need to build it from source (instructions are in this source )
AliceW
May 16, 2023, 11:48am
5
Ah that sucks. I’ll try to build the latest version for CUDA 12.1 with all the distributed stuff enabled then.
system
Closed
June 7, 2023, 3:06am
8
