Qemu and other errors when installing jetpack 4.5.1 on Tx2
Hi
After a lot of attempts, i finally started installation. Things were going well till about 30%, after which i got some errors which caused the installation to terminate
The errors are listed below
22:30:28 SUMMARY: CUDA on Host - host: Install completed successfully.
22:30:28 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
22:30:28 SUMMARY: VisionWorks on Host - host: Install completed successfully.
22:30:28 SUMMARY: VPI on Host - host: Install completed successfully.
22:30:28 SUMMARY: VPI Cross Compile Package on Host - host: Install completed successfully.
22:30:28 SUMMARY: NVIDIA Nsight Graphics - host: Install completed successfully.
22:30:28 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
22:33:38 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
22:42:55 ERROR: File System and OS - target_image: qemu: Unsupported syscall: 278
22:43:24 ERROR: File System and OS - target_image: invoke-rc.d: could not determine current runlevel
22:43:33 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
22:43:39 ERROR: Flash Jetson TX2 - flash: command terminated with error
22:43:39 SUMMARY: Device Mode Host Setup in Target SDK - target: Depends on failed component
This is probably not the answer, but do you have package “qemu-user-static” installed? I’m thinking that if this is missing it might be an issue. See:
dpkg -l | egrep 'qemu-user-static'
dpkg -l | egrep ‘qemu-user-static’
ii qemu-user-static 1:2.5+dfsg-5ubuntu10.51 amd64 QEMU user mode emulation binaries (static version)
Incidentally i ran “sudo dpkg-reconfigure qemu-user-static” as per your other post and am running the installer again.
Running the above command didn’t seem to help, installation stops with the following errors
23:21:07 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
23:30:12 ERROR: File System and OS - target_image: qemu: Unsupported syscall: 278
23:30:39 ERROR: File System and OS - target_image: invoke-rc.d: could not determine current runlevel
23:30:44 SUMMARY: File System and OS - target_image: Install completed successfully.
23:30:47 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
23:30:53 ERROR: Flash Jetson TX2 - flash: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh; [error]:
23:30:53 ERROR: Flash Jetson TX2 - flash: command terminated with error
23:30:53 SUMMARY: Flash Jetson TX2 - flash: First Error: Installation failed.
Here is a copy paste of the last fragments of terminal output of the sdk manager.
23:30:47 INFO: Flash Jetson TX2 - flash: fi
23:30:47 INFO: Flash Jetson TX2 - flash: sleep 20
23:30:47 INFO: Flash Jetson TX2 - flash: **********************
23:30:47 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
23:30:47 INFO: Flash Jetson TX2 - flash: sudo ./nvautoflash.sh
23:30:47 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode … OK.
23:30:47 INFO: Flash Jetson TX2 - flash: *** Checking target board connection … 1 connections found.
23:30:47 INFO: Flash Jetson TX2 - flash: *** Finding configuration … jetson-tx2-devkit found.
23:30:47 INFO: Flash Jetson TX2 - flash: *** Finding boot device … Boot device mmcblk0p1 found.
23:30:47 INFO: Flash Jetson TX2 - flash: /home/srinath/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/flash.sh jetson-tx2-devkit mmcblk0p1
23:30:47 INFO: Flash Jetson TX2 - flash: ###############################################################################
23:30:47 INFO: Flash Jetson TX2 - flash: # L4T BSP Information:
23:30:47 INFO: Flash Jetson TX2 - flash: # R32 , REVISION: 5.1
23:30:52 INFO: Flash Jetson TX2 - flash: Error: probing the target board failed.
23:30:52 INFO: Flash Jetson TX2 - flash: Make sure the target board is connected through
23:30:52 INFO: Flash Jetson TX2 - flash: USB port and is in recovery mode.
23:30:52 INFO: Flash Jetson TX2 - flash: *** ERROR: flashing failed.
23:30:52 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
23:30:53 INFO: Flash Jetson TX2 - flash: [host] [ 12.00 KB used. Disk Avail: 663.47 GB ]
23:30:53 INFO: Flash Jetson TX2 - flash: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 6s ]
23:30:53 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
23:30:53 SUMMARY: Multimedia API - target: Depends on failed component
23:30:53 SUMMARY: TensorRT on Target - target: Depends on failed component
23:30:53 SUMMARY: VisionWorks on Target - target: Depends on failed component
23:30:53 SUMMARY: VPI on Target - target: Depends on failed component
23:30:53 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
23:30:53 SUMMARY: cuDNN on Target - target: Depends on failed component
23:30:53 SUMMARY: OpenCV on Target - target: Depends on failed component
23:30:53 SUMMARY: NVIDIA Nsight Systems - target: Depends on failed component
23:30:53 SUMMARY: DateTime Target Setup - target: Depends on failed component
23:30:53 SUMMARY: Device Mode Host Setup in Target SDK - target: Depends on failed component
I guess enough has changed since the reconfigure topic that this is no longer sufficient. I couldn’t tell you though what is the cause of the failure.
