SDK Installation
Hi NVIDIA,
I need to flash a Jetson TX2 via my company Linux computer (has proxy server).
There is this error during installation:
VPI on Host: Failed to query debian packages details [host]
I would appreciate your advice on how to resolve this error.
Thank you, Alex
  • 20:29:02 SUMMARY: Drivers for Jetson: Install completed successfully.
  • 20:29:02 SUMMARY: File System and OS: Install completed successfully.
  • 20:29:02 SUMMARY: CUDA on Host: Install completed successfully.
  • 20:29:02 SUMMARY: CUDA Cross Compile Package on Host: Install completed successfully.
  • 20:29:02 SUMMARY: VisionWorks on Host: Install completed successfully.
  • 20:29:02 SUMMARY: NVIDIA Nsight Graphics: Install completed successfully.
  • 20:29:02 SUMMARY: NVIDIA Nsight Systems: Install completed successfully.
  • 20:29:08 SUMMARY: VPI on Host: Failed to query debian packages details [host]
  • 20:29:31 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
  • 20:34:17 SUMMARY: Flash Jetson TX2: Install completed successfully.
  • 20:42:39 SUMMARY: Device Mode Host Setup in Target SDK: Install completed successfully.
  • 20:42:40 SUMMARY: DateTime Target Setup: Install completed successfully.
  • 20:43:30 SUMMARY: CUDA Toolkit for L4T: Failed to install debian package [target]
  • 20:43:30 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
  • 20:43:30 SUMMARY: Multimedia API: Depends on failed component
  • 20:43:30 SUMMARY: DeepStream: Depends on failed component
  • 20:43:30 SUMMARY: TensorRT on Target: Depends on failed component
  • 20:43:30 SUMMARY: VisionWorks on Target: Depends on failed component
  • 20:43:30 SUMMARY: VPI on Target: Depends on failed component
  • 20:43:32 SUMMARY: OpenCV on Target: Failed to execute commands with GenericInstaller
  • 20:43:32 SUMMARY: VPI on Target: Depends on failed component
  • 20:45:36 SUMMARY: cuDNN on Target: Install completed successfully.
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
Hi alexandra,
Can you please provide the full log for more investigation? The log files are available in ~/.nvsdkm/ directory.
me too
Versions and SDKM itself have changed since then. You’ll probably want to start a new thread and note which JetPack/SDKM version is used, along with any log of the failure. You’d also need to specify if it is host PC side or Jetson side which failed. If Jetson, then you should additionally state whether ssh login from PC to Jetson works.
