Hi All,
I was able to flash my Jetson TX2 with the Ubuntu OS and when I proceed with Installing SDK Components, there are below errors in the logs and it fails to install NViDiA container runtime and Multimedia API on Target device.
Below are the Errors for these two:
(NVidia container runtime)
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dpkg: dependency problems prevent configuration of nvidia-docker2:
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : nvidia-docker2 depends on docker.io (= 18.09.2-0ubuntu1~18.04.1); however:
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Version of docker.io on system is 18.09.7-0ubuntu1~18.04.3.
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dpkg: error processing package nvidia-docker2 (–install):
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dependency problems - leaving unconfigured
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Errors were encountered while processing:
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Unhandled error when running sudo dpkg -i /opt/nvidia/deb_repos/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exit status 1
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ Package Install Finished with Error ]
18:28:46 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : NV_DOCKER_TARGET_POST_INSTALL_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh” finished with error
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ 92.00 KB used. Disk Avail: 35.04 GB ]
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ NV_DOCKER_TARGET_POST_INSTALL_COMP Install took 45s ]
18:28:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_DOCKER_TARGET_POST_INSTALL_COMP.sh” finished with error
18:28:46 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
Multimedia API:
:30:17 INFO : Multimedia API : Linking: camera_jpeg_capture
18:30:17 INFO : Multimedia API : main.o: In function ArgusSamples::ConsumerThread::threadInitialize()': 18:30:17 INFO : Multimedia API : main.cpp:(.text+0xb4): undefined reference to EGLStream::FrameConsumer::create(Argus::OutputStream*, Argus::Status*)’
18:30:17 INFO : Multimedia API : collect2: error: ld returned 1 exit status
18:30:17 INFO : Multimedia API : Makefile:60: recipe for target ‘camera_jpeg_capture’ failed
18:30:17 INFO : Multimedia API : make[1]: *** [camera_jpeg_capture] Error 1
18:30:17 INFO : Multimedia API : make[1]: Leaving directory ‘/usr/src/tegra_multimedia_api/samples/09_camera_jpeg_capture’
18:30:17 INFO : Multimedia API : Makefile:53: recipe for target ‘all’ failed
18:30:17 INFO : Multimedia API : make: *** [all] Error 1
18:30:17 INFO : Multimedia API : exit status 2
18:30:17 INFO : Multimedia API : [ Package Install Finished with Error ]
18:30:17 ERROR : Multimedia API : NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh && rm -f ~/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh” finished with error
18:30:17 INFO : Multimedia API : [ 2.06 GB released. Disk Avail: 37.10 GB ]
18:30:17 INFO : Multimedia API : [ NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP Install took 1m31s ]
18:30:17 INFO : Multimedia API : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh && rm -f ~/tmp_NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP.sh” finished with error
18:30:17 ERROR : Multimedia API : command terminated with error
Please recommend what should be done in this case.
