我在烧录QSPI中途设备断电意外了,然后再次烧录就失败了
命令是:./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
[ 11.7774 ] 54 reserved 129536 129919
[ 11.7774 ] 55 worm 129920 130303
[ 11.7774 ] 56 BCT-boot-chain_backup 130304 130431
[ 11.7774 ] 57 reserved_partition 130432 130559
[ 11.7774 ] 58 secondary_gpt_backup 130560 130687
[ 11.7775 ] 59 B_VER 130688 130815
[ 11.7775 ] 60 A_VER 130816 130943
[ 11.7775 ]
[ 11.7775 ] Start flashing
[ 11.7781 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 11.7785 ] Bootloader version 01.00.0000
[ 11.8090 ] Erasing spi: 0 ......... [Done]
[ 12.8166 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 12.8215 ] [................................................] 100%
[ 12.8220 ] 000000004d4d2c01: E> NV3P_SERVER: Failed to initialize partition table from GPT.
[ 13.0558 ]
[ 13.0559 ]
Error: Return value 1
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing generic.
串口日志如下:
I> MB2 (version: 0.0.0.0-t234-54845784-c6a05a9f)
I> t234-A01-1-Silicon (0x12347)
I> Boot-mode : RCM Flash
I> Emulation:
I> Entry timestamp: 0x01e6babc
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: SE error check
I> Task: MB2 Params integrity check
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: PSC mailbox init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Boot device init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : pllc_out0
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273801000)
W> Cannot find any partition table for 00030000
W> PARTITION_MANAGER: Failed to publish partition.
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Enter 3p server
I> USB configuration success
I> Populate storage info
I> Erasing device 3: 0
I> QSPI: Erasing entire device
I> Writing device 3: 0.
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273901000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273901000)
