paul216
November 2, 2023, 11:16pm
1
I already had a working SSD with a different SoM on a custom carrier board, so I just needed to flash the QSPI on the new module so that it would boot the existing SSD.
Here’s the command I used to flash the QSPI:
sudo NO_RECOVERY_IMG=1 ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
It worked (seemingly) the first time. But then the board never booted, HDMI-attached monitor stayed blank.
I tried that same command a 2nd time and it failed with the following error:
[ 7.9761 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 7.9769 ] [................................................] 100%
[ 7.9802 ] 000000004d4d2c01: E> NV3P_SERVER: Failed to initialize partition table from GPT.
I attached full host & uart loags for this.
Any help is super welcome!
Thanks,
Paul
command.log (74.8 KB)
uart.log (15.0 KB)
Please try initrd flash instead:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 jetson-orin-nano-devkit nvme0n1p1
It does look like some bug, and we are aware of it and tracking it, but it’s hard to proceed since it can only be re-produced on brand new modules, which we don’t quite have.
That method was able to flash the SoM’s QSPI.
Not sure if it would help root-causing the bug, but in my case, the carrier board does not have an EEPROM. I initially omitted to modify the MB2 BCT to reflect it, as instructed in Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux Developer Guide documentation
That said, once the module was in that state, only l4t_initrd_flash.sh
was able to flash it, even after I fixed the MB2 BCT dtsi file
system
Closed
November 17, 2023, 6:27pm
5
